Re: "Step" Sneakeasy
There are also pics of a Sneakeasy in Alaska w' a PCB sketched
forward cockpit. That is a flatbottom version. Combining the pit w'
the step version may not be wise given they step reduces flotation
fwd.
IMO, a widening to 5 ft would be a different boat with far different
characteristics that the original.
Don Schultz
--- Inbolger@yahoogroups.com, G Carlson <ghartc@p...> wrote:
> No, we've had 6 more than once, and 4 is easy...
> > Thanks Gregg,
> > All I intended was to keep the plumb sides, but increase beam
to 5'0".
> > I wasn't sure how long ago the piece in BWOM had been written and
if PCB
> > had drawn up plans in the mean time. What's the max. on
passengers? 2?4?
> >Bruce
> Thanks Gregg,
> All I intended was to keep the plumb sides, but increase beam to 5'0".
> I wasn't sure how long ago the piece in BWOM had been written and if PCB
> had drawn up plans in the mean time. What's the max. on passengers? 2?4?
>Bruce
> ghc <ghart-@...> wrote:
>original article:http://www.egroups.com/group/bolger/?start=421
>> I ordered the "square" plans from Payson, and completed the "step"
>>versions
>> using the book. I believe the book says there are (were?) no expansions
>> available for the step type.
>> There seems to be plenty of room in my boat, 3 a breast gets cozy, but not
>> oo bad. Hard to know what you mean by "hurt", but you are suggesting
>> increasing the boat size by 25%, plus wetted area. Or, if you mean to
>> flare the sides, then you have changed the boat in more ways than one...
>> Gregg C.
>> At 04:17 PM 10/3/1999 -0700, you wrote:
>> > Is the "step" version of Sneakeasy a separate set of plans? I
>> >received the study plan from HHP, but makes no mention of the "step"
>> >variation. If you want to build one, do you just use the information in
>> >BWOM or contact PCB? Also would it hurt the design if the upper portion
>> >were widened to 5'0" in order to gain a little more elbow room for the
>> >occupants?
>eGroups.com home:http://www.egroups.com/group/bolger
Thanks Gregg,
Bruce
> I ordered the "square" plans from Payson, and completed the "step" versions
> Gregg C.
> >occupants?
Gregg C.
>occupants?
occupants?
