Re: [bolger] Gluing plywood sheets
> Vacuum bagging pulls a head. Now I guess I'll have to build something
> else in order to try it. (Oh, darn.)
I have been thinking about splashing a hull off a canoe to make
a really light weight canoe. A couple of layers of Kevler and
an layer of glass and then stiffen it up with Kevler or Carbon
over a little foam corrigation.
I would use the canoe as a male plug.
Gordon W5RED
www.couger.com/gcouger
>How 'bout you Roger? What are you going to do?
Having a look at aluminium! If all the panel measurements are known much of
the cost of aluminium construction is eliminated. Good stuff. It does not
rust and the dents can be knocked out easily. Aluminium resells too.
Plywood does not unless it is well pasted with epoxy and called "cold
moulded"! However I have not given up on the idea of wood frames clad with
several layers of 7mm plywood.
Roger.
>1.6 Million Digital Images!
>Download one Today from Corbis.com
>http://click.egroups.com/1/3356/6/_/3457/_/955689929/
I vote for vacuum bagging where possible also. I don't know what
visqueen is, but you can make a serviceable bag with heavy
polyethylene and automotive strip caulk. Paper towels will work for
bleeder material, tho you might need something more. Try web surfing,
I think a lot of the model airplane guys have articles on this. Not
sure about leaving a shop vac on 24 hrs tho (necessary with slow
epoxy).
As far as screws go, I like the self drilling screws that have
something like a mini drill bit on the end. They cause less splitting.
--- Inbolger@egroups.com, "Gary Lepak" <gnjlepak@p...> wrote:
> From: Roger Dewhurst <dewhurst@...>
> To: <bolger@egroups.com>
> Sent: Tuesday, April 11, 2000 2:06 PM
> Subject: [bolger] Gluing plywood sheets
> > Can anyone offer suggestions on the use of a tacker/stapler to
hold
> > sheets of plywood together while glue (epoxy, polyurethane or
> > rescorcinol) is setting? Is this an effective way of maintaining
> > sufficient contact pressure?
> The best way to hold large sheets together is vacuum bagging, which
is
> really a lot easier than it might seem. Just envelope the sheets
in
> visqueen bag and suck the air out with a shop vac. Works great.
Gives a
> lot more pressure evenly distributed than mechanical fasteners.
The
> Gougeons have a good pamphlet on it and you can find out more doing
a search
> on "vacuum bagging"
> It's fun too.
> Gary Lepak
> Can anyone offer suggestions on the use of a tacker/stapler to hold
The best way to hold large sheets together is vacuum bagging, which is
really a lot easier than it might seem. Just envelope the sheets in a
visqueen bag and suck the air out with a shop vac. Works great. Gives a
lot more pressure evenly distributed than mechanical fasteners. The
Gougeons have a good pamphlet on it and you can find out more doing a search
on "vacuum bagging"
It's fun too.
Gary Lepak
Drywall screws are much better - just be careful not to strip them out as
you tighten them. Back 'em out and patch the holes after your glue is set.
Don Hodges
dhodges@...
http://www.ecoastlife.com
Sent: Tuesday, April 11, 2000 4:06 PM
> For all your Home Improvement and Home Services needs stop by
> OurHouse.com. You'll receive $10 off on your first order too.
>http://click.egroups.com/1/1736/6/_/3457/_/955494004/
