Re: [bolger] Re-intro and Dovekie spinoff (long)
I was just in Port Angeles last week! I wish you had posted this before now,
I would have loved to see what you were up to.
JB, back in GA for the time being.
Sent: Monday, February 14, 2005 3:17 PM
Subject: [bolger] Re-intro and Dovekie spinoff (long)
> Hi Guys,
> I've been in this group before but it was a few years ago and have
recently
> rejoined, so thought I would re-introduce myself. I live in the Pacific
> Northwest in Port Angeles, on the Strait of Juan de Fuca. I've been a
> Bolger fan since the seventies and have all the books except 30-odd, which
> my brother has. Countless hours of entertainment and education and
> inspiration. I've built a few of the boats, the first was an Airex
version
> of the Dolphin from Small Boats, the 18' "whaleboat" design, which we used
> only for rowing, no rig. Then a Teal, a Skimmer, a Tortoise, and a Nymph.
> I've built a few other boats of other designs, some my own, starting in
1970
> with an 18' trimaran, and also a 46' Wharram cat, and 34' "Lepak" cat,
that
> we lived aboard and cruisedin the '70's abd 80's, and numerous small
boats,
> mostly ply, one cedar strip. Right now I own only 3 boats, Snake, a
17'x22"
> doublepaddle board built of blue foam, 3mm ply and glass, Silvergirl, a
16'
> double ended ply rowboat, and Stoaproa, a breakdown 16' ply outrigger
canoe
> with a Hobie Mirage pedal drive which is the most recent, a little over a
> year ago.
> I've had the urge to again have a boat large enough to sleep on, but
really
> simple, cheap, and easy to build. I like to row and "pedal" as well as
> sail, when there is no wind, which is a frequent condition here. I have
> distaste for outboards too, though I've owned many. I've always been
> fascinated by PCB's large rowboats with sails, his "Ocean crossing
rowboat"
> and the "cruising canoe". I was recently poring over BWAOM looking for a
> dream boat and got drawn into the "Cruising Rowboat". I like the size and
> hull shape, though it isn't suited for sailing at all, but it got my mind
> going in the direction of small and simple, as I had been planning for a
> year to build a 24' cruising proa. The proa would not have been very good
> for efficient muscle powering and as much as I like multihulls, I decided
it
> should be a mono this time. Looking through my other books for a suitable
> hull, I finally came to the obvious answer, Dovekie, as it was designed as
> sailboat with rowing as auxilliary power. I wasn't about to embark on a
> foam sandwich project, as I don't even have a heated or even an enclosed
> shop right now. I wanted something that would be finished for spring or
at
> least summer, 2005. I put together a little model of roughly the
dimensions
> I had in mind, including the minimum 35" headroom sleeping cabin. I
> envision it more as a rowboat that can be sailed, but hope that it will
> as well as Dovekie. I want an enclosed cabin, with rowing in the cockpit
> with good visibility. I'm making it with plumb sides and ends, 5' beam,
> with 6'8" length in both the cabin and cockpit for sleeping. I will
> probably try using a pedal unit, either the Mirage type, or a propeller
> type, as well as oars. Rather than leeboards, I am thinking of a
> daggerboard. I'll have water ballast too as I will be singlehanding a
lot.
> The unstayed mast will be stepped along the aftside of the cabin and
support
> a dipping lug, or perhaps a balance lug, sail. The bottom in the cabin
will
> be balsa core sandwich for stiffness without frames, for sleeping on. I
> started building in December, and have been rather obsessed with it. I
> threw up a carport style roof of scrap lumber and tarps alongside the
garage
> as a temporary shelter, and have been curing resin (System Three) in our
30*
> to 45* temps with heaters under the hull and plastic and sleeping bags
over.
> I have enough room in the garage for resining small parts, up to the size
> a sheet of ply, which I precoated. I'm using cedar strip construction to
> make 6" radius chines, though I considered the simple hard chine.
> I just posted some pictures in Bolger4 files section under the heading
> "Bufflehead" which is what I am calling it, after the black and white
ducks
> that are along the waterfront where I walk. These pics are up to date. I
> have my roll of fiberglass being delivered today and should have the
bottom
> glassed and ready to turn over by the end of the month.
> Gary Lepak
> Itching to get glassing
(978) 282-1349
Hi Guys,
I've been in this group before but it was a few years ago and have recently
inspiration. I've built a few of the boats, the first was an Airex version
I've built a few other boats of other designs, some my own, starting in 1970
with an 18' trimaran, and also a 46' Wharram cat, and 34' "Lepak" cat, that
we lived aboard and cruisedin the '70's abd 80's, and numerous small boats,
mostly ply, one cedar strip. Right now I own only 3 boats, Snake, a 17'x22"
doublepaddle board built of blue foam, 3mm ply and glass, Silvergirl, a 16'
double ended ply rowboat, and Stoaproa, a breakdown 16' ply outrigger canoe
year ago.
I've had the urge to again have a boat large enough to sleep on, but really
fascinated by PCB's large rowboats with sails, his "Ocean crossing rowboat"
for efficient muscle powering and as much as I like multihulls, I decided it
hull, I finally came to the obvious answer, Dovekie, as it was designed as a
shop right now. I wanted something that would be finished for spring or at
least summer, 2005. I put together a little model of roughly the dimensions
envision it more as a rowboat that can be sailed, but hope that it will sail
daggerboard. I'll have water ballast too as I will be singlehanding a lot.
The unstayed mast will be stepped along the aftside of the cabin and support
a dipping lug, or perhaps a balance lug, sail. The bottom in the cabin will
threw up a carport style roof of scrap lumber and tarps alongside the garage
as a temporary shelter, and have been curing resin (System Three) in our 30*
to 45* temps with heaters under the hull and plastic and sleeping bags over.
I have enough room in the garage for resining small parts, up to the size of
"Bufflehead" which is what I am calling it, after the black and white ducks
have my roll of fiberglass being delivered today and should have the bottom
Gary Lepak
