Re: [bolger] Re: Construction Methods for Trailer Sailing
I built a 26' plywood on frame modified Pacific Dory. The bottom and
chine seams were fiberglassed the rest was just painted. The boat was
fished in Norton Sound AK, living on a trailer in the winter in
temperatures down to -50 F (-45 C). It was used commercially sometimes
packing Three tons of fish, twenty years after it was built, it was
still being used. It never leaked except when I forgot to put the drain
plug in.
plug in.
Nels wrote:
>--- Inbolger@yahoogroups.com, "s4a9m8" <sammi13@f...> wrote:
> Setting aside
>>the issue of the skill required to produce such a vessel, which of
>>the construction methods (carvel, lapstrake, plywood, etc.) is most
>>suitable for trailer sailing? In particular which method is most
>>tolerant of being in the water one or two days a week and spending
>>the remainder on a trailer in a garage?
>Hi
>Plywood and wood framing is the cheapest and if you tape the outside
>seams with glass tape and use good exterior grade paint, a boat will
>last for years sitting most of the time on a trailer. The greatest
>threat is rainwater that might get into the interior. So you need a
>good cover if left outside.
>Some plywoods tend to "check" and the grain raises up through the
>paint. If you cover the outside with glass cloth the grain will not
>show through the paint, and it will stand up to weather better.
>Which books have you studied? Do you have any or Dynamite Payson's?
>He is sort of the guru of instant boat building. His book and
>catalogue are must haves.
>http://instantboats.com/
>Where in Finland do you live? There is a very famous Finnish
>Bolgersita called "Martti the Finn". He build the very first Micro!
>He is an expert on adhesives and such from Helsinki I believe and
>therefore his boat was very well built.
>Cheers, Nels
>Yahoo! Groups Links
much safer to turn it over and store it upside down than cover it.
Don't ask how I found that out;-)
Cheers, Nels
> The greatestI should have added that if it is a smaller open boat, it is always
Cheers, Nels
Cheers, Nels
>Setting aside
> the issue of the skill required to produce such a vessel, which ofHi
Cheers, Nels
> Plywood!If you don't want a boxy boat, the glued lapstrake with plywood plan
works well. Bolger has used it for the lap Chebacco, for example.
Plywood!
Ron Fossum
Ron Fossum
Sent: Sunday, February 20, 2005 6:12 AM
Subject: [bolger] Construction Methods for Trailer Sailing
As I sit here in the land of ten-thousand frozen lakes, much of my
spare time this winter has been spent beginning my education about
the world of small (under twenty feet) homemade boats. Setting aside
Yahoo! Groups Sponsor
Get unlimited calls to
U.S./Canada
Everyone has opinions; here are mine.
The problem with a drysailed wooden boat is that wood is not a stable material--it expands and contracts as it absorbs or loses water content. This expansion /contraction is very powerful and is capable of breaking glue lines if big pieces of wood are involved.
The four solutions are to build with with pieces of wood which are too small to expand enough to break a glue line (plywoo/-coldmolding, or strip construction), to thoroughly encapsulate the wood in fiberglass (stripper canoes and wood cored fiberglass are examples), a construction approach which allows the planking to move (natural wood lapstrake), or the use of some material between double planking.
Trailing aboat shakes it and, over time, the rivets holding lapstake planks together get loose. Most successful homemade trailer sailers are plywood, strip, or cold molded.
John T
John T
Sent: Sunday, February 20, 2005 9:12 AM
U.S./Canada
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 266.1.0 - Release Date: 2/18/2005
No virus found in this outgoing message.
