Re: [bolger] Gluing plywood sheets
> I'm not an expert, but I did watch an expert (Derek Kelsall) vacuum bag
> composite hull where he only keep the vacuum on for approx. 20 minutes in
70
> degree temp. Now he was using the old resin (don't remeber the tech
name),
> vs. epoxy, but why would the vacuum need to be on overnite with epoxy?
Seems
> like overkill.
> Also, we drilled several holes in the vacuum tube to keep the vacuum from
> overheating.
The time is dependent on the time it takes the epoxy to cure. Generaly
you use slow cure times so you have plenty of time to do the lay up.
The really high tec guys use pre impragnated cloth (prepeg) the cures
at elevated temperture. System 3's vacuum bagging system uses
a resin that needs to be heated to 130 degrees to achive full strength.
If foam is involved you have to be careful that you don't compress the
foam by pulling too hard a vacuum on it.
Gordon W5RED
www.couger.com/gcouger
