[bolger] Re: Dr. Vincent Reddish
>> I suspect that the ultra simple and effective sprit sails of Long
>> Micro are still the best choice for most. What is your problem
>> with that rig after all?
>The problem is the same as with the Micro Navigator. It would not
>clear a pilot house and it would not reef as easily. Most of Bolger's
>designs that have a pilot house have either a gaff or lug rig.
You can use a sprit boom on a gaff or standing lug. Works well. Munroe's
sharpies has sails with a short gaff and a sprit boom which actually had
the snotter at the outboard end.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
> It would not clear a pilot house and it would not reef as easily.
Sorry to have come across so down on your idea, I actually
think your Long Micro modifications are promising!
Are you positive that the sprit sail wouldn't fit around the
cabin? I have spent a couple hours already detailing
the sprit sail rig on the Navigator (clearances to the pilot house etc.)
I have concluded that it would actually work. Reefing would
be with a braile line, similar to the Leg-o-mutton rig for
Birdwatcher. Of course the truth would be in testing,
and I am very close to deciding to whip up a mast and
polytarp sail prototype as a test.
>> <quote>"But the urge to attribute some particular magic wisdom to
> the eastern ancients that 'shall not be tampered with' is in the
class
> with George Harrison going to India to find 'his Guru' - hip, at
that
> time, and probably with good intentions, but apparently not
necessarily
> the universal key to enlightened proceedings afterwards. "</quote>
Having watched the George Harrison commemoration special on PBS with
Ravi Shankar's daughter performing on sitar, I really believe George
was not far off. But then I also practiced TM for about 35 years:-)
> As far as a Chinese Gaff rig on a Long Micro, maybe PB&F will
> support it. But the reason they put that rig on Micro Navigator
was that
> operation of the rig was required from *inside* the cabin, with no
> cockpit *and* safety was needed in Roaring Fourties offshore
conditions.
> That same reason is not in play with a Long Micro, as it has a
cockpit,
> [Roaring Forties, I don't know.]
Long Micro has no cockpit as designed, just a larger hold than Micro.
And yes PCB&F have stated that a Long Micro Navigator would be a
better off-shore boat than the shorter Micro Navigator. But they have
not pursued it because there has been little interest shown and they
are busier with other things. Also the mods for the Micro Navigator
can easily be applied to a Long Micro which already has a tabernacle,
end plate on the rudder and enclosed bow.
What I really want to have is the inside comfort to get out of the
sun and/or cold at times and still be able to see all around me, and
with the LM you get stand up headroom inside. (The hull is deeper.)
Also I plan to do some part-time living aboard and still have the
capability to trailer relatively easy. I can use the very same
trailer and cradle and motor that I already have with Lestat. Just I
won't have the same level of workmanship:-)
Cheers, Nels
> qualify nicely for an either Bolger style gaff rigg or an Vincent
> Reddish kind of junkrig. Of course there´s a little guessing involved
> here. What do you guys think?
> Wolfgang
FWIW, I think that Bolger, [and also I think Altenberger]
are sceptical about junk rigs, [based mostly on their
comments on the junkrig for AS29]. see:
http://groups.yahoo.com/group/bolger/message/1256
This comment about beliefs in Junk Rigs catches my eye:
the eastern ancients that 'shall not be tampered with' is in the class
with George Harrison going to India to find 'his Guru' - hip, at that
time, and probably with good intentions, but apparently not necessarily
support it. But the reason they put that rig on Micro Navigator was that
cockpit *and* safety was needed in Roaring Fourties offshore conditions.
That same reason is not in play with a Long Micro, as it has a cockpit,
IOW, if it ain't broke, why fix it?
Hi Nels, hi everybody,
I think it might be a good idea for you and everybody else, who might
be interested in Long Micro/navigator/chinese gaff upgrade to send a
fax to PCB. Just to alert him about the rising intrest on the scene.
I would happily share costs for an authorized upgrade.
Personally i would go for a version with a fixed mast right in front
of the hatch, which would a nice space for the anchor gear and a
good access to the and all falls and sheets, just in case something
needs attention. Also in my humble opinion this mast position would
Cheers
Wolfgang, who´s at the moment suffering of a violent sunburn
