Re: Fibre-glass technique question
--- Inbolger@yahoogroups.com, "robert pyfrom" <neetra@c...> wrote:
> BTW this is supposed to be a bare bones group. I pay $18.00 gal.
for resin.
> What is the cost for epoxy? Ask Dynamite Payson what he uses.
Depends on which brand of epoxy......more importantly however,is
that epoxy is a glue and 99%(or thereabouts)waterproof.Polyester
resin is not a glue and not nearly as"waterproof" as epoxy.
And where does it say this is a "bare bones group" anyway? ;-)
Peter Lenihan........
BTW this is supposed to be a bare bones group. I pay $18.00 gal. for resin.
Bob
Sent: Monday, March 07, 2005 9:29 PM
Subject: Re: [bolger] Re: Fibre-glass technique question
> Usually I work with polyester and always prime surface with base coat of
> laminating resin "no wax" before laying on fabric. Then wet surface to be
> covered and lay up fabric dry and then slosh on resin and roll with ribbed
> roller until I feel there are no more bubbles. Hope this helps.
> Bob
> From: "gbship" <gbship@...>
> Sent: Monday, March 07, 2005 9:13 PM
> Subject: [bolger] Re: Fibre-glass technique question
> > I've done both and prefer the dry method with squeegee application.
> > The only trick to to watch for dry spots as some of the epoxy goes
> > through the cloth and into the wood. Not hard to see, or to spot if
> > there's too much epoxy leading to cloth "float." Never had any come
> > off on the 3 boats I've done this way. It's hard to do the wet method
> > unless you have a helper, or are only doing a small area.
> > Gary
> > --- Inbolger@yahoogroups.com, "camalexander2002" <calex@e...> wrote:
> > > I have resumed work on my Bantam stretch after a medical lay-off,
> > > and I have a reasonably large amount of fibre-glassing to do. I am
> > > going to cover all external surfaces with 6 oz cloth as "zipper"
> > > prevention. I have always used the dry cloth method - laying
> > > the glass on the dry wood surface, then squee-geeing the expoxy
> > into
> > > the cloth - and been successful in the past. Reading has show that
> > > others of great experience, Renn Tolman for example, uses the wet
> > > method - rolling on a wet coat of epoxy, rolling the cloth onto the
> > > wet surface, the rolling on more epoxy. I've had problems with
> > cloth
> > > float when I did not use a squeegee to pull the cloth relatively
> > > dry. I also hate to handle cloth after it has been wetted out.
> > Are
> > > these methods interchangable, or am I missing something by using
> > the
> > > dry method? Please comment, oh great group wisdom.
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
Fax:
> (978) 282-1349
> > Yahoo! Groups Links
(978) 282-1349
Bob
> Gary
> into
> cloth
> Are
> the
(978) 282-1349
Gary
into
cloth
Are
I have read the book and as a professional boat renovater "not restorer"
have used many of his methods sucessfully. I may not agree with many of his
practices, washing hands with acetone, I still think many of his ideas are
applicable to many people using frp in any form.
Bob
Sent: Monday, March 07, 2005 7:47 PM
Subject: Re: [bolger] Fibre-glass technique question
> rob Have you read this book? It involves nailing mat and cloth to
> the hull of older wooden boats and then putting on resin to preserve.
> Put glass cloth on wet or dry as you prefer, but almost set epoxy if
> working on vertical or over your head surfaces. Clyde
> > Might I suggest Allan H. Vaitses' excellent book on covering wooden
boats
> > with fiberglass? Most of the applications using polyester also apply to
> > epoxy.
> > Comboat
> > From: "Gary Lepak" <gnjlepak@...>
> > ADVERTISEMENT
> > click here
<http://us.ard.yahoo.com/SIG=1294bu7n9/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705065791:HM/EXP=1110320656/A=2593423/R=0/SIG=11el9gslf/*http://www.
netflix.com/Default?mqso=60190075>
> > Yahoo! Groups Links
> > * To visit your group on the web, go to:
> > http://groups.yahoo.com/group/bolger/
> > * To unsubscribe from this group, send an email to:
> > <mailto:bolger-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/>.
(978) 282-1349
> - Unsubscribe: bolger-unsubscribe@yahoogroups.com
> - Open discussion: bolger_coffee_lounge-subscribe@yahoogroups.com
boats
> > epoxy.
> > Comboat
> > ADVERTISEMENT
> > click here
> > Yahoo! Groups Links
(978) 282-1349
> Might I suggest Allan H. Vaitses' excellent book on covering wooden boats
> epoxy.
> Comboat
> ADVERTISEMENT
> click here
> <http://us.ard.yahoo.com/SIG=1294bu7n9/M=298184.6018725.7038619.3001176/D=groups/S=1705065791:HM/EXP=1110320656/A=2593423/R=0/SIG=11el9gslf/*http://www.netflix.com/Default?mqso=60190075>
epoxy.
Comboat
Sent: Monday, March 07, 2005 12:56 AM
> I use both wet and dry methods depending on the situation. I just glassed
> the bottom of my boat with two layers of 6 oz by first resining the ply,
> then cure and sand, then lay on the glass dry and squeegee on the resin.
> The next day sand the seams and high spots and lay on another layer dry.
> But on the cedar strip chines that I just glassed on the concave inside, I
> did it wet as I had to putty unevenness in the strips and didn't want to
> sand it. I resined the cedar strips then immediately puttied where I had
> too, then rolled out the precut 15" wide cloth off pieces of pvc pipe,
with
> the non-selvedge edges taped with masking tape, into the wet resin,
> saturated that with a squeegee and layed on the second layer while the
first
> was still wet. I like working dry better for ease of arranging the cloth,
> but if vertical surfaces are involved the wet resin can help hold the
glass
> in place. If I putting cloth into wet resin I just have to be very
careful
> not to pull the cloth out of shape. It almost always seems to get some
> wrinkles though, but they flatten out in the resin.
> So I would say I do it dry when that's easier and wet when I want to avoid
> difficult sanding work between layers. I prefer dry if I have a choice,
but
> usually resin the wood first and let it cure to avoid it sucking resin out
> of the glass and starving it when I am not looking.
> Gary
(978) 282-1349
too, then rolled out the precut 15" wide cloth off pieces of pvc pipe, with
saturated that with a squeegee and layed on the second layer while the first
but if vertical surfaces are involved the wet resin can help hold the glass
in place. If I putting cloth into wet resin I just have to be very careful
difficult sanding work between layers. I prefer dry if I have a choice, but
Gary
the glass on the dry wood surface, then squee-geeing the expoxy into
wet surface, the rolling on more epoxy. I've had problems with cloth
dry. I also hate to handle cloth after it has been wetted out. Are
these methods interchangable, or am I missing something by using the
