RE: [bolger] Re: Weldwood vs. Titebond II?
> In England it is nigh on impossible to find Weldwood... The Titebond
> sounds like our local equivilant.."Hard as Nails" and looks like
> glorified Elmers...
Same here in New Zealand, however in talking with one of the company
representatives (Bostiks)he gave some very useful advice.
He thinks from the website description of Titebond II that it is a modified
PVA glue. There is now a second generation of glues that are called
"EVA's". The Bostik product he recomended in this type is "Bostik 33LV"
(sometimes marketed in consumer size packs as "Cling-on. The price of this
glue is NZ$40 for 5 litres (about US$20 per 1.3 us gallons).
This rep has worked extensively with the boat building industry and although
the particular product has not been tested or certified for marine use his
recomendation is good.
He thinks the EVA's have signifigant benefits over modified PVA's including:
- Better water resistance
- Higher level of solids = better gap filling
- Greater flexibilty = greater capacity to absorb shrink/expand cycles of
wet/dry wood.
Regards - Foster
> glorified Elmers... I have just started using a product by Humbrol
> (big UK adhesives co.)called Cascamite.. Other European builders
> might find this useful. It is easy to find, comes as a powder and
> mixes with water.. Even says on container.. Suitable for
> Boatbuilding!! It costs about $24 for 1.5kg of powder (about a third
> of price of epoxy).
> I have used Epoxy on my Micro for the Hull, Bulkheads and saved some
> to glue together the keel and stick in lead plug. The Cascamite is
> being used for decks etc...
> It sounds like my Cascamite is identical to Weldwood.. Can I use it
> to glue my 25' mast together???
> Whatever you want, chances are you'll find it at one of the hundreds
> of sites in The PointClick Network--like Disney.com, eCost.com,
> FogDog.com and many more. You get paid as you shop and an additional
> 10% off any purchase, anytime.
>http://click.egroups.com/1/2994/6/_/3457/_/955969520/
My dad used weldwood exclusively in his mast building. This was long before
the days of plastic glues. I know of a couple of his masts that were still
going strong 40 years after building and this was in SF Bay winds.
There is a whole different level of fit required how ever. That kind of
joinery was easy for the pro's of his generation, as an amateur, I do not
find it so easy. Also lots and lots of clamps needed. I personally use
either epoxy or the new polyurethane's.
_ _ _ _ _
% Harry James,welshman@...
