Re: [bolger] Re: Linoleum canoe!
In a message dated 3/26/05 3:03:47 PM Central Standard Time,
mplawson@...writes:
> Semi-trailers are covered with what look to be 6'x8' or 6'x10' sheets
> of thin fiberglass, riveted to aluminum frames.
Some years ago, my father gave away a Chris-Craft runabout that he thought
was past saving. The guy he gave it to sheathed the bottom of this with
manufactured fiberglass sheet, something like this, which he purchased at a local farm
supply store - apparently intended for use in dairy parlors or some similar
application. I haven't seen the boat on the water, so I suspect it wasn't a
successful idea. But I dunno.
Ciao for Niao,
Bill in MN
In a message dated 3/26/05 6:14:51 AM Central Standard Time,
davidjost@...writes:
> Back in 1965, or so...my father purchased an early generation canoe
> made that was constructed of "Royalex" it was a product invented by
> Uniroyal rubber corporation and was sheets of ultra flexible material
> that closely resembles linoleum.
Hi, Dave:
I don't have any personal experience with this stuff, but I think it
consisted of foamed layer of something (probably not "rubber") enclosed between
two sheets of plastic. Even with the foam core, it was pretty limp stuff as
far as stiffness goes - like an order of magnitude less than plywood of
equivalent thickness. The sheeting skins were synthetic stuff and much tougher than
"linoleum." Old Town canoe sold a canoe called the "Tripper" made of something
similar, if not identical. (They called the substance "Oltonar" or something
like that, but I doubt if Old Town developed the stuff independently.)
The stuff has its virtues, but it is a material that requires
full-scale heated molds and serious engineering to fabricate, i.e. its not of any use
to an amateur builder or any small-volume specialist firm. If you want a canoe
built of this stuff, you will be limited to the offerings of a few large
manufacturers. They were intended to compete with aluminum canoes, which also
require substantial plant to manufacture. A boat made of this stuff would probably
be the best choice for a "glory or death" wilderness trip, with an aluminum
canoe the second choice, but for anything other than that, they are heavy, limp
and blunt-ended.
Still, all in all, any canoe is better than most boats, and one that
doesn't require maintenance or indoor storage is probably the best boat that
most of us can have while we're still young enough to really enjoy it. I'd be
willing to bet that either you or your dad, or both of you, got his money's
worth out of that Royalex boat!
Ciao for Niao,
Bill in MN
I recall seeing this material on "teardrop trailers"websiteComboat51
Sent: Saturday, March 26, 2005 4:03 PM
Subject: [bolger] Re: Linoleum canoe!
> The thread reminds me of a question on materials I had the other day,
> driving the interstate.
> Has anyone built with this stuff? I would think multiple chines and an
> internal frame would be the thing.
> RE: royalex, I browsed canoe sites the other night and paddled canoes
> of many kinds. It consists of multiple laminations of plastic over a
> core, which expands to foam when heated, at which point they throw the
> hot, expanding sheet into a mold to harden up. Hard to scratch. Pops
> back into shape after a wrap. Dents pop out if you leave it in the
> sun. I wouldn't buy a canoe out of anything else, unless I wanted
> superlight kevlar.
> > that closely resembles linoleum. I think it actually has a plastic
> > outside and inside with a rubber composition as the middle layer.
> The
> > upshot is a material that gives when hitting objects like submerged
> > rocks, trees, stumps. It is a little unnverving at first as the
> > bottom really wobbles quite a bit, but the shape of the canoe is held
> > by the curves, remaining stiffness, and thwarts.
> > David Jost
(978) 282-1349
superlight kevlar.
The
> David Jost
outside and inside with a rubber composition as the middle layer. The
Tell us more please Mr Jost!
Gavin
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.8.2 - Release Date: 25/03/2005
