Re: Resin Curing Problem
If you want to see a nifty device for getting a good mix of your
epoxy, look at my article in Duckworks titled Epoxy Ratio Scale.
--- Inbolger@yahoogroups.com, "txsailor37" <txsailor37@y...> wrote:
> Thanks Guys! I was hoping that this wasn't too abnormal. I will
> clean it well and then scuff before I go on.
> BOBBY
BOBBY
BOBBY
--- Inbolger@yahoogroups.com, "Bill Kreamer" <kreamer@a...> wrote:
> Wash with soap and water well, before scuffing, otherwise you risk
just
> "scuffing it in," and you won't be getting rid of it. After that,
you can
> rough it up a bit. - Bill
> _____
> From: Will Samson [mailto:willsamson@y...]
> Sent: Sunday, April 10, 2005 2:40 PM
> To:bolger@yahoogroups.com
> Subject: Re: [bolger] Resin Curing Problem
> This is perfectly normal. It's probably just 'amine blush' - the
extent of
> which depends on curing temperature, humidity and so on. It can be
washed
> off with soapy water.
> If it's been cured more than a day or so it's a good idea to scuff
it all
> with sandpaper before applying the next layer.
> Bill
> From: txsailor37
> Sent: Sunday, April 10, 2005 7:26 PM
> Subject: [bolger] Resin Curing Problem
> I tasped all the seams on my Bobcat the other day. The next day
when I
> checked it, some of the resin had kicked just fine but in some
places
> it is still "tacky" to the touch. It has hardened but the
surface is
> sticky. Is this normal? Can I continue on ang glass over this?
Or do
> I nedd to sand it all off and start over?
posts
01930, Fax:
> (978) 282-1349
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
posts
01930, Fax:
> (978) 282-1349
> _____
> * To visit your group on the web, go to:
> <http://docs.yahoo.com/info/terms/> Service.
Wash with soap and water well, before scuffing, otherwise you risk just
"scuffing it in," and you won't be getting rid of it. After that, you can
_____
This is perfectly normal. It's probably just 'amine blush' - the extent of
which depends on curing temperature, humidity and so on. It can be washed
If it's been cured more than a day or so it's a good idea to scuff it all
Bill
_____
Bill
I tasped all the seams on my Bobcat the other day. The next day when I
checked it, some of the resin had kicked just fine but in some places
it is still "tacky" to the touch. It has hardened but the surface is
sticky. Is this normal? Can I continue on ang glass over this? Or do
(978) 282-1349
(978) 282-1349
_____
This is perfectly normal. It's probably just 'amine blush' - the extent of which depends on curing temperature, humidity and so on. It can be washed off with soapy water.
If it's been cured more than a day or so it's a good idea to scuff it all with sandpaper before applying the next layer.
Bill
Bill
