Re: [bolger] Telescoping Mast
To: <bolger@egroups.com>
They have them on some elevators. Also they make antenna mast that
extend with air pressure. Some of these are sturdy enough to use as
mast. An inquiry on the amateur radio antennas news groups would
probably turn one up.
I would still worry about failure in heavy seas setting off a cascade of
events with very negitive outcome.
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
>bottom
> Perhaps someone could design a hydraulic mast. Pump some oil in the
> and the top goes up like a car jack! It would need some decent oil sealsRoger,
> though. Tell me if you find one please.
Gordon
A Folding mast would be a lot easier to make and more reliable
thantelescoping. You would have a hard
spot in a telescoping
mast where the two sections over lap and you would
have
to make a hard spot to pin the mast.
A hinge wouldn't be as pretty but it would be a lot easier
fix when it stuck than a telescoping mast.
A hinge near the base and sockets up the mast
might
be the easiest.
I could worry about a telescoping mast failing and
going
through the bottom of the boat.
Gordon W5RED
G. C. Cougergcouger@... Stillwater, OK
----- Original Message -----From:Jeff GilbertSent:Friday, April 21, 2000 9:40 AMSubject:[bolger] Telescoping MastDear List members,has anybody espied a successful (or otherwise) design for a telescoping mast.?I'm thinking of the order of three 10ft sections, not a massive unit.For use in trailering, negotiating low bridges, fixing jammed halyards etc etc.Thanks in advance.Jeff GilbertDown Under, where Winter approaches,although this doesn'tseem to worry the Tasmanians who are busy plyingBass Strait inthe 12th running of the Examiner Three PeaksSailing/MountainRunning Race (reports on http://www.threepeaks.org.au/ )
Roger Dewhurst.
>Dear List members,mast.?
>I'm thinking of the order of three 10ft sections, not a massive unit.Perhaps someone could design a hydraulic mast. Pump some oil in the bottom
>Thanks in advance.
>Jeff Gilbert
Roger Dewhurst.
