Re: [bolger] Re: Teal frustration
On Mon, 24 Apr 2000, DGO wrote:
> That is one of the areas of concern. Once the deck is on, I will have
> no access to the stem/stern areas. Needless to say I am super-gooping
> the area beforehand.
I recommend epoxy-set fiberglass tape on the outside and inside of the
stem and stern on the Teal. This makes it essentially a bulletproof
joint, where you *really* need it. Wouldn't cost too much, and would
extend the life of the boat substantially.
> What kind of grinding, and where, do you have to do?
I used a coarse disk on an angle-grinder to put the foil shapes in
rudder and leeboard. 36-grit disk. The wood turns into very fine
dust
very quickly. I also used it to flatten off the gunwale and
stem/stern
posts in the area that I am drifting off the plans. (I am makeing
floatation chambers between where the temporary bulkheads are and the
ends of the boat).
>I just used
> nails and Weldwood glue, and everything went together just fine. I
> had a very minor leak in the stern. It only weeped when I was
aboard;
> the leak was out of the water when empty. I just poured some really
> thick Weldwood glue in there, and that fixed her.
DGO
> It's a shame about the oil leak on the Patuxent (I live in
> Annapolis, Md.). I heard that it was a real mess. WAMU, one of the
> local NPR stations covered it pretty well, as did the Washington
> Post. I hope PEPCO is working diligently to clean it up.
> This, unfotunately, this is part of the price we pay to run all
> our electrical devices, including circular saws and grinders. It
> makes us all uncomfortable, no doubt, when we're confronted by it.
> Good luck with your project.
> Take care,
> Pete Reynolds
> --- Inbolger@egroups.com, "DGO " <oswald@c...> wrote:
> > Well,
> > Got the sailing bits built on the TEAL, and starting that final
> round
> > of "Caulking" with thickened expoxy before I seal it up. I highly
> > recommend OHSA-approved particulate filters if you are using an
> angle
> > grinder as a wood-eraser. Basically making fast progress, and
> will
> > be ready for flat-water testing soon.
> > What is truely furstrating is that a local power company pumped
> > about $ 1/4 MILLION DOLLARS worth of fuel oil into the river
where
> > I had intended to sail her. Right across the river from the boat
> > ramp. Unfortunatly, the local news stations
> > are out of DC, who was hosting the world trade stuff. Appearently
> > Police beating protesters sells ads faster than oil-soaked ospry.
> > There is still 80% of that oil that has not been cleaned up. So
> much
> > for testing on the Patuxent before braving the Bay..
> > DGO
Dear DGO,
Good luck with your project. Teal was the first boat I ever built.
It performs very well, despite of Bolger's misgivings in his book.
You'll have a blast with her.
What kind of grinding, and where, do you have to do? I just used
had a very minor leak in the stern. It only weeped when I was aboard;
Take care,
Pete Reynolds
> Well,
round
angle
will
> about $ 1/4 MILLION DOLLARS worth of fuel oil into the river where
much
> DGO
Well,
Got the sailing bits built on the TEAL, and starting that final round
recommend OHSA-approved particulate filters if you are using an angle
grinder as a wood-eraser. Basically making fast progress, and will
There is still 80% of that oil that has not been cleaned up. So much
DGO
