Re: [bolger] Light Schooner Motor Well Slot Cover
Rob--I hinged the slot cover at its aft end and held the forward end down
with a sliding bolt barrel latch (? the sort of latch you frequently find
on gates) to hold it in place. With the cover flipped up, you coud mount a
small motor, though I never got around to buying one. Bolger claims that he
often leaves details to builders because they often come up with a better
solution than he can.
John T
Sent: Thursday, June 02, 2005 10:37 AM
Subject: [bolger] Light Schooner Motor Well Slot Cover
> Hey folks,
> On the Light Schooner, the motor well is inboard, in front of the
> rudder. Bolger doesn't show you how to cover the slot, hoping the
> builder will figure out a good way to do it. But he does assure us that
> it much be done, or the hole becomes a geyser at speed.
> Well, I made a plywood drop-in door that'll seal it just fine. But it
> seems like it'll be a royal pain in the butt to get removed and
> replaced around the motor's lower unit.
> I thought of covering the whole thing with 1/16" rubber, held to the
> bottom with metal strips, and slit down the middle for the lower unit
> to slip through. The idea is that the rubber would spring closed to
> keep most of the water out.
> Anybody have any thoughts on that?
> Thanks,
> --Rob
(978) 282-1349
> Checked by AVG Anti-Virus.
> Version: 7.0.322 / Virus Database: 267.3.0 - Release Date: 5/30/2005
Hey folks,
--Rob
