Re: folding schooner
> Hi Jerry,
> either way that is real boating history you're sailing! To think,
I
> may have a picture of your actual boat on the cover of a book
> published 31 years ago! Do you plan any schooner racing later in
> August?
> I think you could fold/unfold that boat on the trailer if you had
> help - two, but three of you would be better. FS as designed is
only
> a light, empty, 15' 6" skiff with a bit of foam in the bow after
> all. A line off the bow led well to the front, or rear as the case
> may be, would allow the third person to control the raised half
> through quite an arc near the veticle. This would give time for
> other two to move a few steps from a lifting position to a
lowering
> position. I think the cautions not to perform the folding
operations
> on the trailer arise from concern that an individual may try it by
> themselves. Bolger did it solo for a dare. Both he and the boat
> survived, but only just. It would be better to do this, and then
be
> able to launch/retrieve the boat already rigged at most ramps.
> "Mostly Harmless" style boxed-in side decks would allow the
folding
> operations to be done on her beam ends in shallow water after
first
> launching in the folded position without requiring a large bailing
> job upon righting. Without the side tanks I don't see how this
beam
> ends process could be easily reversed for trailer recovery.
> Have you considered a parking lot dolly of some kind? Like as used
> by racing classes on the rigging deck, and for launch/recovery.
> Basically just a cradle for the boat, on wheels, very low to the
> ground, and for FS you wouldn't have a pulling/steering handle up
> front. For FS a cradle may need only extend a few feet at most
> either side of the hinge point - the assembled hull would sit in
it,
> balanced. You might get away with just one pair of wheels right
> under the balance point -- this would make parking lot and launch
> ramp manouverability and steering very easy.
> This would have to beat carrying the FS piece by piece some
distance
> to the ramp and assembling it there. The procedure would be to put
> the dolly on the ground close to the parked FS trailer, lift the
> entire unfolded boat or pieces into the dolly cradle, assemble and
> rig on the dolly, load any extra gear, push FS to the water, float
> FS off the dolly, moor FS, return the dolly to the trailer and
> secure, return to the boat and sail away.
> Just how different is the latching on your FS from that shown in
> books? As I understand it you also have some pieces fastening
> across the bottom, is that right? Could you post a photo or two of
> them?
> HTH
> Graeme
> --- Inbolger@yahoogroups.com, "zensailor2005" <jrwelch3@> wrote:
> >> Graeme.......
> > The hull plate on my schooner is DEDABFDPM73F, I have emailed
> Dynamite
> > Payson for confirmation that this boat is one of 3 prototypes he
> built
> > in 73-74, but have not yet gotten a reply.....
> > Thanks,
> > Jerry
Graeme.........the keel bracket on the bottom of my FS is just a
simple metal deal with 2 holes which are to line up with holes on
the other half / keel, which is not easy to do when the boat is in
the water, for obvious reasons (you can't see it!)....thanks for all
your input / advise on launching / unfolding, etc......since I have
only had the boat a short time, and only had her in the water once
so far (due to work I was doing on it for the past 4-5 weeks!), I am
sure I will experiment further with better and easier methods for
the whole launching / unfolding, etc........the dolly idea might be
useful, but the ramps I usually go to, you can't linger long because
there are usually many boats in line waiting for their turn.....
It would be great if I could find someplace locally to keep the boat
in the water for a time, so I could do more sailing trials, etc....
Will try and get some pictures of the bracket and post them soon!
Thanks all, for great input / suggestions on this historic and very
interesting Bolger / Payson schooner!!
Jerry
> Hi Jerry,
I
> August?
only
lowering
operations
be
folding
first
beam
it,
distance
> them?
> HTH
> Graeme
> >> Graeme.......
> Dynamite
> built
> > Thanks,
> > Jerry
Jerry
<jon@...> wrote:
> Hi Bruce and Zensailor,
When on the wind, we typically have
> the main sheeted in only slightly off the centerline, with the foresail
> out further and brought in until just before it starts to backwind the
> main. I'm sure it's similar in schooner with a headsail. Also, try
> falling off a little. You'll go faster and likely more than make up
> anything you'd gain by pointing higher. It's also possible your sails
> aren't cut well, despite the origin of the boat.
> Jon Kolb
Hi Jon,
Any photos of you sailing your schooner?
Also would love to see a larger photo of the one of you in the Bolger
Long Dory that appeared in WB Launchings. What finish choices did you
use for it? Incredible how the water reflections appear as a pattern
on the hull. At first I thought it was applied as a part of the paint job!
...snip...
> Certainly, the tricks and techniques
> of sailing a schooner rig must be learned. Who among us sails a
> schooner? Susan, and who else?
Does a cat-schooner count? My advice is to sheet for the main first,
then the foresail, then the jib. When on the wind, we typically have
Jon Kolb
Hi Jerry,
either way that is real boating history you're sailing! To think, I
August?
help - two, but three of you would be better. FS as designed is only
through quite an arc near the veticle. This would give time for the
other two to move a few steps from a lifting position to a lowering
position. I think the cautions not to perform the folding operations
survived, but only just. It would be better to do this, and then be
"Mostly Harmless" style boxed-in side decks would allow the folding
operations to be done on her beam ends in shallow water after first
job upon righting. Without the side tanks I don't see how this beam
either side of the hinge point - the assembled hull would sit in it,
This would have to beat carrying the FS piece by piece some distance
Just how different is the latching on your FS from that shown in the
them?
HTH
--- Inbolger@yahoogroups.com, "zensailor2005" <jrwelch3@...> wrote:
>> Graeme.......
Dynamite
built
> Thanks,
> Jerry
--- I'm in the dark, as to why it's so bad to unfold on the trailer
as well. Really it would seem to make sense to unfold and at least
partly rig the schooner out of the water. I've seen at least 2 photo
sequences where the schooner is unfolded on the trailer, (using a
gin pole arrangement), but non where it's unfolded in the water. The
only thing I can think it might be is the balance of it, ie; as much
off the trailer as is on it, but it's only a guess. It may make a
difference when unfolding and using the water to cushion the front
hull, but what difference would it make to folding it back up,
except maybe you get very wet, and entertain onlookers. Could this
be a case of use the method you feel most happy with??.
Kev
Inbolger@yahoogroups.com, Patrick Crockett <pcrockett@...> wrote:
> Not sure why they recommend against unfolding on the trailer --
because
> it is inconvenient to control the process or because of strain on
> hulls or trailer. In any event, if one is going to do the
connection in
> the water, why bother with a hinge? Why not carry both hulls
upright on
> the trailer, launch one then the other, float them together, and
fasten
> with two long pins going through gudgeons along the sides?
> Patrick
> zensailor2005 wrote:
> > Thanks, Seem.......had seen the pics here and the other website
you
> > mentioned......my trailer has no such pole rig attachment set
up, and
> > the bracket on my early boat is different than some of the later
> > subsequent models, for connecting the 2 keels / boat halves.....
> > Also, both Payson and Bolger do not recommend unfolding the
schooner
> > on the trailer, when I recently corresponded with them about
this.
> > But I will need to try some other ways than what I did last
weekend,
> > which was cumbersome at best!
> > Thanks for your input!!
> > Cheers,
> > Jerry
Not sure why they recommend against unfolding on the trailer -- because
it is inconvenient to control the process or because of strain on the
hulls or trailer. In any event, if one is going to do the connection in
the water, why bother with a hinge? Why not carry both hulls upright on
the trailer, launch one then the other, float them together, and fasten
Patrick
> Thanks, Seem.......had seen the pics here and the other website you
> mentioned......my trailer has no such pole rig attachment set up, and
> Also, both Payson and Bolger do not recommend unfolding the schooner
> on the trailer, when I recently corresponded with them about this.
> But I will need to try some other ways than what I did last weekend,
> Cheers,
> Jerry
> Cheers,
> Jerry
Since I have the plans, I would be interested in what they recommended?
I just happen to have a good spot on the rear of my trailer to bolt on
a bracket without having to drill through the frame. I think it could
be built from some spare pressure treated plywood and lumber I have
from making the cradle for my other boat.
I envision getting the lowering mechanism all connected up before
backing down the launch ramp and stopping before the trailer tires
even get wet. Then lowering the bow section down onto the water, so
the bow floats, closing the connectors and then backing up until it
floats off the trailer.
If the ramp is not busy one could probably install the masts before
floating it off the trailer.
Only in my dreams right?
> > Hello....
> > I recently acquired a 1973 Payson built Bolger folding schooner,
> > which had been kept in storage by previous owners for many
years....
> > Couple of questions;
> > 1) Any recommendations about upgrading the keel bracket on the
> > bottom, which seems pretty difficult to use when it is under
water,
> > and you are trying to put 2 bolts in place?
> > 2) Is there some easier way to "unfold" this boat, than doing
what I
> > did with one helper last weekend during my first sail / outing,
> > which was to take the hinge "rod" off and separate the 2 halves,
> > launch separately, then put back together.....seems a bit
unwieldy
> > to try and unfold with just one other person....have people used
> > a "gin pole" or a mast with block / tackle successfully?
> Congratulations! Perfect boat for a zensailor:-)
> I will respond to item 2 first:
> Check out the photo album entitled: "folding schooner Waltzing
Matilda"
>http://ph.groups.yahoo.com/group/bolger/photos/browse/e372
> It shows two methods. Unfolding it after launch or unfolding it
while
> still on the trailer. I would prefer the second method. The second
> larger photo #5 shows a good view of the set-up.
> Looks to me like there is a bracket permanently installed on the
> trailer which also serves as a guide post for retrieval as well
> perhaps? (May have another on the other side as well.)
> The vertical post on the bracket is likely open at the top and
accepts
> either a gin pole or one of the masts. How it functions is
> self-explanatory in the photos.
> My plan would be to also have an addition on the bracket to hold a
> small hand winch with a brake.
> Back to item one. You tighten down the bolts prior to sliding it
into
> the water.
> When it comes to sailing these boats you might also check out Tim
> Flatchen's site in addition to getting information from Sue.
>http://www.ace.net.au/schooner/index.htm#start
> Hope this helps.
> Seem
Jerry
> > which had been kept in storage by previous owners for many years....
> Is this Folding Schooner not the protoype? FS #0?
> What month of 1973?
> Graeme
Graeme.......
The hull plate on my schooner is DEDABFDPM73F, I have emailed Dynamite
Payson for confirmation that this boat is one of 3 prototypes he built
Jerry
What month of 1973?
> Hello....
> bottom, which seems pretty difficult to use when it is under water,
> 2) Is there some easier way to "unfold" this boat, than doing what I
> launch separately, then put back together.....seems a bit unwieldy
Check out the photo album entitled: "folding schooner Waltzing Matilda"
It shows two methods. Unfolding it after launch or unfolding it while
The vertical post on the bracket is likely open at the top and accepts
Back to item one. You tighten down the bolts prior to sliding it into
the water.
Hope this helps.
Seem
Wow, I am eager to hear answers to you questions. I have not sailed a
Folding Schooner before, (except for a hundred times in my
imagination). I can say that I have seen plenty of photos of the
folding/unfolding operation done with the 'gin pole', and it looks
workable. Also, I can say that after decades of sailing nothing but
sloops, my transition to another rig (in my case, a cat yawl) involved
re-learning how to sail again. Certainly, the tricks and techniques
Hello....
3) Is upwind performance improved markedly by adjusting the
daggerboards for various points of sail? Sailing the boat for the
first time, in 10-15 knots of wind, she seemed a bit sluggish upwind
and got stuck in irons when coming about....not sure if I need to
experiment more with the daggerboard trim....
Any thoughts?
Thanks for any input!
Re: Leander's Folding Schooner ... I bought top-grade fir dimensional
lumber and marine mahogany for a Folding Schooner last summer. Cost was
three times what he's asking for a complete one with motor and trailer
and sort-of sails. What a bargain!
(I finished the forward hull of my schooner about half-way before
Charley came and blew the doors of my shop open [no damage except to
the plans, which were papier mache.] Charley stole my O'Day 23 moored
at the mouth of the Peace River and hasn't returned it, and a few other
excuses, like fixing up an old San Juan 21 to replace the O'Day for
PHRF racing and cruising. Expect to get back to the schooner in a few
more weeks.)
-- Will
Leander tells me the Folding Schooner price has
been reduced to $1500 or best offer for boat, trailer, trolling motor,
battery, suit of polytarp sails, and enough real sail cloth to make a
second suit of sails.
Email me, and i'll put you in touch.
