Re: [bolger] Methods for placing & spreading putty in fillets?
sounds like you may have a little bit too much thickner and not enuf epoxy
D.W.Johnson
D.W.Johnson
Don't put so much thin goodge on at first and then, let it gel before trying
to add the thick filleting material. Saves a lt of frustration. I get in a
hurry too.
hurry too.
To: <bolger@egroups.com>
Sent: Friday, April 28, 2000 6:31 AM
Subject: [bolger] Methods for placing & spreading putty in fillets?
> In the various books and articles on stitch-and-glue boatbuilding
> that I've read, the spreading of putty in fillets is always made to
> seem fairly easy -- smear it in, smooth it out, give it a nice round
> radius, etc. Only, when I attempt this, especially after having first
> painted the adjacent surfaces with thin epoxy (which then lets the
> putty slide around), I get all sorts of wild uncontrollable globs and
> bumps -- nothing remotely resembling the uniform fillets shown in
> illustrations.
> I apply the putty (somewhat lumpily) with a tongue depressor, go to
> smooth the curvature in it, and half the putty jumps up alongside the
> depressor, and then needs to be corralled back into the fillet. Some
> of it doesn't smooth into a continuous fillet, but breaks and pulls
> along with the tongue depressor into separate globs. I curse and
> dance around, hoping body English will somehow urge the putty back in
> line. I curse some more. I spatter myself with epoxy. I bathe in
> white vinegar. I try mixing my putty more densely or thinly, but
> still get the same frustrating experience. I wind up sanding a lot of
> lumps away, and my fillets look pretty wavy.
> Does anyone have a silver bullet solution to this? I imagine using
> something like a cake frosting squeeze applicator to provide the
> initial uniform (controllable) bead that can then be smoothed out. Is
> there a cheap, disposable item that would work? How do you all do it?
> Any advice appreciated.
> All best,
> Garth
> GET WHO WANTS TO BE A MILLIONAIRE FREE! GET THE OFFICIAL COMPANION
> TO TELEVISION'S HOTTEST GAME SHOW PHENOMENON PLUS 5 MORE BOOKS FOR
> $2. Click for details.
>http://click.egroups.com/1/3014/6/_/3457/_/956921516/
Garth Battista wrote:
have never had the problem you describe. The reason it is happening is that
the epoxy is not clinging to the material I presume.
My first thought was that your mixture is way , way too dry but then you
said that you had tried different levels of filler/ epoxy mix. I would
suggest trying it very runny so that you may have to go back and reshape for
sags and see how you do.
Normally I just scoop in a pile and spread it down the seam with whatever I
am shaping the curve with. It just flows out in front of the shaping tool.
It is thin enough that it doesn't have the tensile strength to pull itself
along. Any tendency to ball up would indicate to me that it was too dry.
I have used silica, wood flour, chopped strand and micro balloons for
fillers.
_ _ _ _ _
% Harry,welshman@...
> In the various books and articles on stitch-and-glue boatbuildingI have built several boats using some or all liquid joinery techniques and I
> illustrations.
> All best,
> Garth
fillers.
_ _ _ _ _
1. let prime set up just a little
2. use plastic spoon, works fine. end for sharp corners, side for
more
open corners
3. mix epoxy before thickener, unless you want your boat to suffer
same fate as my friend's model airplane wing where he mixed in the
filler first. CRACK! pause! THUD!
4. use only finest fillers (I'm talking texture here, not snob
appeal)
I've had good luck with wood flour from GlenL, and also, if I recall
correctly, from Raka, but there are probably plenty of other good
things to use
5. Mix in a little silica (i.e. cabosil), maybe 10% or 20% of your
filler, more is harder to sand but ok
5 and a half. consistency somewhere between mayonnaise and peanut
butter (the petrochemical kind, like Skippy, not the natural stuff)
6. Put on the tape as soon as the filler stiffens up just a little,
or
maybe sooner. THen you don't have to sand, you can just push the tape
with a glove or brush until it fits. I have a project boat that
someone else started, epoxy and tape over bondo, and they have voids
because they didn't have smooth filler in the corners. (Actually, the
voids belong to me now but I hate to admit it.) Sanding filler is a
pain.
more
open corners
appeal)
things to use
or
pain.
--- Inbolger@egroups.com, "Orr, Jamie" <jorr@o...> wrote:
>snip
> -----Original Message-----
> From: Garth Battista [mailto:garth@b...]
> Sent: Friday, April 28, 2000 4:32 AM
> To:bolger@egroups.com
> that I've read, the spreading of putty in fillets snip
> Does anyone have a silver bullet solution to this? snip
> All best,
> Garth
Hi Garth,
I have had the best results using a piece of tubing. I bend the
tubing so it has enough curve that the end is almost parallel to the
corner. If it is pulling up, or curling and coming out, lessen your
angle and press it into the corner with more pressure.
I hope this helps,
Stan Micro Tugger, Snow Goose.
I hope this helps,
Hi
Check the shop tips at the Chesapeake Light Craft site -- they explain it
very well. However, sounds to me like your putty is too hard and the
pre-wetting is too wet -- maybe let it sit until tacky, then put on putty.
Personally I have the putty only stiff enough to stay in place without
drooling, and I only pre-coat very lightly, if at all. Putting tape on
right away will help combat drooling by sloppy putty, too.
Jamie Orr
illustrations.
All best,
Garth
Jamie Orr
illustrations.
All best,
Garth
I have used plastic spoons and flexible spreaders cut from plastic ice cream
tub lids. Still, I can have a bad day! The most foolproof way is to set
the tape in the wet fillet, then smooth the whole combnation with (gloved)
fingers.
Don Hodges
dhodges@...
http://www.ecoastlife.com
fingers.
Don Hodges
dhodges@...
> illustrations.
> All best,
> Garth
Let the wetting out coat setup or start to set up. With Sys Three at least,
you can still make a chemical bond for a couple of days after the first coat
sets up. Reuel Parker uses a zip lock plastic bag with a corner cut off for
a disposable cake decorating thing. I haven't tried this yet. You can clean
up and shape, partially setup fillets with a rag, soaked with denatured
alcohol as the alcohol evaporates very quickly. Clyde Wisner PS: besure to
clean epoxy off the door knobs, telephone and water faucet handels and life
with signif. other becomes easier.
> illustrations.
