Re: [bolger] Re: I'm not dead!
IIRC you used to be a squirt boater. Maybe you should just teach her to do
pivot turns, splats, mystery moves, screw-ups, and cartwheels. ;-)
JB
Sent: Thursday, July 07, 2005 11:24 AM
Subject: Re: [bolger] Re: I'm not dead!
> I took my daughter and the Klamyak (tm) down to the lake for a test
> run. I wanted to see how it floated her before undertaking the time and
> expense of finishing it (carpentry was but a few ours and some odd
> scraps of wood; glassing, painting etc always take me twice as long and
> costs twice as much as anticipated.)
> It turns out I cut the lines too fine. It floated her, but just barely.
> Sleek looking indeed (as I had wanted), but with only an inch of
> freeboard, as she gained the confedence to take more authoritatitve
> strokes, she'd dip the rail, eventually swamping the boat.
> As looked at her floating empty and admired her rakish lines, I
> realized what I had done. I drew the boat from the water line up, with
> no hull below the water to float her when loaded. I wonder if this is
> typical beginner's mistake?
> At any rate, Maggie much enjoyed the Klamyak (tm), even if it was a
> rather unforgiving little boat. I'm going to re-built, but rather than
> raising the sheer, I'm going to try lowering the chine. About two
> inches should do it (that'll be another cubic foot of displacement.)
> Not bad for a first try!
> YIBB,
> David
> On Jun 30, 2005, at 11:38 PM, Bruce Hector wrote:
> > --- Inbolger@yahoogroups.com, David Ryan <david@c...> wrote: "I'm past
> > dejected about the I60."
> > Don't slip into a terminal depression about someone else's problems.
> > Finishing the I60 plans is PB&Fs problem, not yours.
> > Yours is what to do until they arrive.
> > All things come to those who wait, and send begging & bitching letters
> > with great regularity.
> > In the meantime, build something else.
> > Don't sweat the little things. Your biggest problem ever comes once you
> > have the plans and actually have to build it.
> > Bruce Hector
> > Whose been depressed many times, but just plods on with it and a little
> > help from some good anti-depressants now and again.
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
> > Fax: (978) 282-1349
> > Yahoo! Groups Links
(978) 282-1349
> Bruce Hector
> Fax: (978) 282-1349
Well David keep the faith and I promise that if I can break away
from my writing and tools I would come back east and help you build
the boat just supplying my labor, experience and the tools you do
not have. All I ask is a space to sleep and cook my meals. I am
sure we can go twice a fast in the correct building of the I-60 you
want. And if Susan needs help we can help her also. So have no
fear you can have my help
John Cupp
past
problems.
letters
once you
> Bruce Hector
little
Bruce Hector
I have to confess that at this point I'm past dejected about the I60.
Never mind the money (which is trivial in comparison to the cost of
building the boat, but a rather stiff bill for disappointment) there's
the time and enthusiasm that we set aside for this project; some of it
salvaged, but some lost forever. That (in part) explains my long
absence from a community of which being a part has enriched my life.
>> No good news on the Insolent 60. Nothing I do seems to be able to
>> motivate Mr and Mrs Bolger to finish the design, and I've all but
>> given up on it.
> FWIW, I have a letter ready to go to PCB&F asking for the latest Micro
> Navigator draft; perhaps that will give them a prod. At the very
> least, perhaps there might be a newer draft for the bow section and/or
> spars that might let at lest a little bit of work proceed?
> given up on it.
Susan Davis <futabachan@...>
FBBB,
I've just finish another Gull, put together from pieces leftover from
Sue and my Gullapalooza a few years ago. It's paint red, just like the
first one.
I carved a couple of oars for it out of a lumberyard 2x6 and they
didn't come out half bad.
I also just build a 1/2 (96"x 15") scale Klamyak (tm) for my daughter.
It's a sharpie/piro/kayak hybrid of my own design. Encouraged by the
oars, I made her a little double bladed paddle out of hunk of clear
cedar that's been taking up space in the backyard.
motivate Mr and Mrs Bolger to finish the design, and I've all but given
up on it. I thought we'd be under construction Summer of '03, and now
here's the Summer of '05 slipping away.
