Re: New photos of Miro with Junk rig
Nels, Answers in line.
window which now only opens a inch but still vents the boat ok. )
I made a new mast step on the base of the well and a new structure
to hold the mast. I made it all removeable so if the experiment
went wrong I could be true to PB's lans.
mast. Ideally I need a thinker one, but beggars....
same as the original rig with one reef. That way I was sure I was
not going to over do the sail area. One thing I would do is make
the top panels out of thicker cloth and have stronger battens at the
top so I could take more wind when reefed.
was worried about was the sheeting angles. I need not have worried
I have plenty of room and the sheeting works well. I have noticed
that the top two panels have lots of twist and no control, so may be
three panels would have been better. As to a steeper angle. I
stuck to the book and it seems to work. One thing I would change is
the battens which are canes and they bend nicely but they do not
have enough weight to come down on some points of wind and the
downhauls just bend them and do not work.
I will try to get some pictures of the mast setup as there is no
mast at the moment it will show the layout well.
live 9 miles from the East Coast of England and I had never been to
sea as I was too nervous to reef the sprit boom sail as all that
happened was an under-powered boat and a dangerously low boom. I
know I could have pushed the boom forward this then gives a very
uncontrolled sprit which in a chop sways vigourously. So with the
Junk rig I was able to go to sea last weekend and was confident that
I could reef and ben in control.
Downwind I was able to keep ahead of some larger marconi rigged
boats, upwind was slow on a reach she was a dream. Set the sails
and relax. She was balanced as much as she had been under the
original rig, what more could I ask for.
The next day the chop was up, officially 'moderate' seas and she
faired very well. The hull stops in the short chop but I was still
impressed. The sail moved around a lot in the swell, but no damage
done. Back on the river with a force 4-5 she went great and with
the tide helping she pointed well and she gave me the best sail I
have ever had.
Martin
> How have you located your mast? ..The mast in on the centre line just infront of the vent ( I have a
> How tall is the mast anyway?The mast is 21ft and 2 3/4 inches at the base. It was a second hand
> If you were to make a new sail would you make it to the same areaas
> shown or have you not tested enough to decide?New Sail? I would go with roughly what I have. It is exactly the
> I am wondering if the top panel ...The design of the sail was very hard to judge. The main criteria I
> It seems really handy to have that amount of reefing capability.The reefing has changed my confidence in the boat altogether. I
have ever had.
Martin
I have uploaded one of the photos to the file section.
--- Inbolger@yahoogroups.com, "Paul" <kayaker37@h...> wrote:
> Can you upload these to the files section? The photo section reduces
> all your lovely 215k photos or so to about 10k losing a lot of
detail.
> Thanks,
> Paul
> > I have just uploaded two photos of b=my micro with its Junk rig.
all your lovely 215k photos or so to about 10k losing a lot of detail.
Paul
Paul
--- Inbolger@yahoogroups.com, "Martin Roberts"
<martin.me.roberts@b...> wrote:
Fantastic and inspiring. I have not been following your progress on
this development and have a couple of questions.
How have you located your mast? Is it centered over the cabin air vent
opening, or off to one of the aft corners of the bow well? And is the
mast resting on the bottom of the well as shown in the illustation?
If you were to make a new sail would you make it to the same area as
I am wondering if the top panel could not be made a bit larger in area
and the yard topped up a bit more? This would perhaps even increase
light wind perforance even more and make the two top panels perhaps
eaual in area?
Thanks for sharing,
Nels.
> I have just uploaded two photos of b=my micro with its Junk rig.Hi Martin,
> Sadly this was just a few days before my mast cracked for the second
> time. Will be back on water soon.
>http://tinyurl.com/7jcwe
> Martin
eaual in area?
Thanks for sharing,
Nels.
Martin
Martin
