Re: [bolger] Re: Weldwood vs. Titebond II?
I recall that the package says "water resistant" and refers to a
water
resistance test of some sort. It also says "not for use below
the waterline" or something like that. Regular carpenter's glue is
water soluble. I used to use it as part of a system to hold a magnet
over a reed switch until it got wet. The glue was supposed to wash
off
in a day or so.
--- Inbolger@egroups.com, Roger Dewhurst <dewhurst@w...> wrote:
> >> snip
> >> Is Titebond an EVA or yellow carpenters' glue?
> >It (Titebond II)looks and handles very much like yellow
carpenter's
> >glue. Regular Titebond IS yellow carpenter's glue.
> Is Titebond ll more waterproof than ordinary Titebond? Am I right
in
> thinking that yellow carpenters' glue is very strong but not
waterproof?
> Roger.
> snip
It (Titebond II)looks and handles very much like yellow carpenter's
>> snip
Is Titebond ll more waterproof than ordinary Titebond? Am I right in
thinking that yellow carpenters' glue is very strong but not waterproof?
Roger.
At 11:05 17/04/00 -0000, you wrote:
>In England it is nigh on impossible to find Weldwood... The Titebond
>sounds like our local equivilant.."Hard as Nails" and looks like
>glorified Elmers... I have just started using a product by Humbrol
>(big UK adhesives co.)called Cascamite.
Is Cascamite much the same thing as Aerolite the urea-formaldehyde glue that
was used to stick Mosquito fighter-bombers together in WW2? Aerolite 308
(melamine-urea-formaldehyde) is available here. It requires a hardener
GBP.X or GBQ.X. It is described as a gap filling water resistant adhesive
which is also resistant to heat, moulds and fungi and tolerates some
exposure to weathering. There is also Aerolite FFD (previously Aerolite 300
and possibly the original aircraft glue) and Aerodux which is a Resorcinol
wood glue for exterior use and boat building; described as "superstrong".
There a at least two Resorcinol glues here. Each requires a hardener.
