Re: Foam flotation Teal
Sorry, I should have checked my upload. It is there now.
Bob
-- Inbolger@yahoogroups.com, "Nels" <arvent@h...> wrote:
Bob
> --- Inbolger@yahoogroups.com, "Bob Chamberland" <cha62759@t...> I
> have added a file to Bolger5 named Teal.
> Hi Bob
> I looked in the Teal Folder and it is empty.
> Nels
Hi Bob
Hi Bob
-I can't really answer your questions direct however I would suggest
going to your local building supply and getting a sheet of styrofoam
insulation. The only real disadvantage of styrofoam is that it
disappears when dipped in gasoline. Not a likely occurrence in your
Teal. I have added a file to Bolger5 named Teal. You can see I fitted
styrofoam fore and aft held in place with shockcord. I could have
constructed a more permanent installation but this approach worked.
Teal is rather cramped as is without adding bulk along the gunwales I
would think.
Bob Chamberland
would think.
Bob Chamberland
> I am trying to find some polyethylene foam to create flotation just
> outboard and below the gunwhales on my Teals (I have a pair).
> I have thought of using "pool noodles" as they are cheap and available
> but the volume of each is only 1.88 liters. Using 4 of them (5' long)
> lashed to the gunwhale would bring the total flotation to 7.5 liters.
> Does someone know if that would be enough to bring the gunwhales out
> of the water to start bailing the boat?
> I think the ideal shape would be a foam sausage of square section (or
> other extrusion shape) of approx. 5" diameter by 10' length. This
> would bring about 48 liters of flotation on each side.
> Does someone have an idea where to find that at a reasonable cost or
> which industry would use that kind of material?
> Cheers
> Thierry
Cheers
Thierry
Cheers
Thierry
