Re: Fairing lead?
--- Inbolger@yahoogroups.com, Fred <derflingdol@y...> wrote:
I wound up using a Surform tool for the actual fine shaping (with a
bit of sanding at the end to smooth out the rasp grooves), but what
really did the trick for cutting down the overpour was a power plane.
Ten minutes of power planing did more than an entire evening of
manual rasping.
Unfortunately, I still managed to underestimate the curve of the
faired daggerboard when I cut the bottom of my daggerboard slot, and I
was only able to get it down about six inches or so last week. Fixing
that is today's task....
Susan Davis <futabachan@...>
> When fairing lead the best way to remove the most is to use abody workers rasp.
manual rasping.
When fairing lead the best way to remove the most is to use a body workers rasp. They can be had in both flexable and rigid body. They are also available in flat, concave, and convex shapes as well as various lengths. Just remember to keep a file card handy and use it often. But if it gets too clogged up with the material before you notice it, a slow heat and an even slowwer cooldown will help clean it out. Fred
Do You Yahoo!?
http://mail.yahoo.com
Do You Yahoo!?
What I figured out, after the fact, is that I'd have been a lot better off
if I'd put a top on the lead cavity. Feed it with a riser to supply lead as
the main body cools. Include vents at the corners of the lid. Only the
sprues need planing down.
> We finally had a successful pour for _Shrike_'s keel on Saturday, on
> our third attempt. We poured a bit too much, though, and I have about
> an eighth of an inch of lead to fair down to get the daggerboard to
> fit through the slot. It's also all bumpy and unfair and whatnot.
> What's the best way to fair lead? I've found that it eats belt sander
> belts, and the chisel that I used to get the flashing off is far too
> slow to be practical for trimming down the whole casting area....
While I'll agree that most folks have read about the dangers of
lead, I've found that when casting with the stuff they'll use care
with the melted lead, but seem to forget the dangers of fairing with
it for some reason. So I always point it out.
Bill H.
+magazine&w4=Great+outdoors&c=4&s=83&.sig=r49p2sdeaMdE-HKp6VsBvQ>
g+magazine&w4=Great+outdoors&c=4&s=83&.sig=DMVKSdfVjcXwtIGevXt4yA>
ng+magazine&w4=Great+outdoors&c=4&s=83&.sig=4i1edadVuO4gEFWwcL_-EQ>
+magazine&w4=Great+outdoors&c=4&s=83&.sig=9lzoUcWE8Vy43nP6bzMgMQ>
Bill H.
> At the risk of sounding redundant... Most likely everyone readingthis
> is aware of the hazards of lead, but I think people who buildboats or
> even think about building boats are special and would hate toimagine
> that anyone might cause him/herself harm due to being uninformedabout
> lead. Lead is a cumulative poison which attacks the nervoussystem
> among other things. It absorbs well in the lungs either in dustor
> vapor form. There was an affliction in decades past which befellaround
> plumbers. Lead used to be used to join all types of metal pipe,
> including the big stuff in some cases, to make sealing flanges
> pipe penetrations through walls and for just about anything wherean
> easy flowing, easily melted, cheap filler could be used. This wasplumbers'
> before people realized how dangerous lead is. It was the
> cure-all, apparently. I forget the name of the condition, akin tomad
> hatter's disease with tanners and mercury. I know a few old timerawful
> plumbers who have said it was before their time but they've heard
> stories of the physically and mentally crippling results. I wouldurge
> anyone working with lead that any chance of breathing ANY lead istoo much.
>lead
> Bruce Hallman wrote:
> > On 7/25/05, Bill Hamm <griff10us@y...> wrote:
> > > Sanding and grinding lead is dangerous to your health, makes
> > > dust that's easy to breath, really bad thing.so heavy.
> > Actually, I am not sure that the dust disperses very far, being
> >horses
> > A risk not mentioned: you should wash your hands before eating
> > or smoking, [actually smoking is a bad idea anyway.]
> > - no cursing, flaming, trolling, spamming, or flogging dead
> > - stay on topic, stay on thread, punctuate, no 'Ed, thanks,Fred' posts
> > - Pls add your comments at the TOP, SIGN your posts, and snipaway
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,01930,
> > Fax: (978) 282-1349t=ms&k=Boating+safety&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating
> > SPONSORED LINKS
> > Boating safety
> > <http://groups.yahoo.com/gads?
> > Alaska outdoorst=ms&k=Alaska+outdoors&w1=Boating+safety&w2=Alaska+outdoors&w3=Boatin
> > Boating magazinet=ms&k=Boating+magazine&w1=Boating+safety&w2=Alaska+outdoors&w3=Boati
> >t=ms&k=Great+outdoors&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating
> > Great outdoors
> > YAHOO! GROUPS LINKSsubject=Unsubscribe>
> > * Visit your group "bolger
> > <http://groups.yahoo.com/group/bolger>" on the web.
> > * To unsubscribe from this group, send an email to:
> > <mailto:bolger-unsubscribe@yahoogroups.com?
> >of
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms
> > Service <http://docs.yahoo.com/info/terms/>.-------
Let's not make this into an epidemic. Sand outside and wear a
dustmask and you will be fine. I have not had a problem reducing a
lead overpour with a random orbital sander and fairly coarse
sandpaper like 60 grit. It sands about as fast as plywood if it's
pure lead. It may take a little longer if it contains tin or
antimony. If it's pure lead, you can also use a hand plane.
this
boats or
imagine
about
system
or
around
an
plumbers'
mad
awful
urge
too much.
lead
so heavy.
horses
Fred' posts
away
01930,
> > Fax: (978) 282-1349
> > SPONSORED LINKS
> > Boating safety
> > Alaska outdoors
> > Boating magazine
> > Great outdoors
> > YAHOO! GROUPS LINKS
At the risk of sounding redundant... Most likely everyone reading this
is aware of the hazards of lead, but I think people who build boats or
even think about building boats are special and would hate to imagine
that anyone might cause him/herself harm due to being uninformed about
lead. Lead is a cumulative poison which attacks the nervous system
among other things. It absorbs well in the lungs either in dust or
including the big stuff in some cases, to make sealing flanges around
pipe penetrations through walls and for just about anything where an
before people realized how dangerous lead is. It was the plumbers'
cure-all, apparently. I forget the name of the condition, akin to mad
plumbers who have said it was before their time but they've heard awful
stories of the physically and mentally crippling results. I would urge
anyone working with lead that any chance of breathing ANY lead is too much.
> On 7/25/05, Bill Hamm <griff10us@...> wrote:
> > Sanding and grinding lead is dangerous to your health, makes lead
> Actually, I am not sure that the dust disperses very far, being so heavy.
> Fax: (978) 282-1349
> SPONSORED LINKS
> Boating safety
> <http://groups.yahoo.com/gads?t=ms&k=Boating+safety&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating+magazine&w4=Great+outdoors&c=4&s=83&.sig=r49p2sdeaMdE-HKp6VsBvQ>
> Alaska outdoors
> <http://groups.yahoo.com/gads?t=ms&k=Alaska+outdoors&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating+magazine&w4=Great+outdoors&c=4&s=83&.sig=DMVKSdfVjcXwtIGevXt4yA>
> Boating magazine
> <http://groups.yahoo.com/gads?t=ms&k=Boating+magazine&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating+magazine&w4=Great+outdoors&c=4&s=83&.sig=4i1edadVuO4gEFWwcL_-EQ>
> Great outdoors
> <http://groups.yahoo.com/gads?t=ms&k=Great+outdoors&w1=Boating+safety&w2=Alaska+outdoors&w3=Boating+magazine&w4=Great+outdoors&c=4&s=83&.sig=9lzoUcWE8Vy43nP6bzMgMQ>
> YAHOO! GROUPS LINKS
--- Bruce Hallman <bruce@...> wrote:
lead, add going to the bathroom. Wash your hands both
before and after.
Phil Smith
> On 7/25/05, Bill Hamm <griff10us@...> wrote:In addition to all of THOSE hazardous practices with
> health, makes lead
> before eating
before and after.
Phil Smith
> Sanding and grinding lead is dangerous to your health, makes leadActually, I am not sure that the dust disperses very far, being so heavy.
Sure-form file works pretty well and is relatively quick.
Bill H.
Bill H.
> We finally had a successful pour for _Shrike_'s keel on Saturday,on
> our third attempt. We poured a bit too much, though, and I haveabout
> an eighth of an inch of lead to fair down to get the daggerboard tosander
> belts, and the chisel that I used to get the flashing off is fartoo
> Susan Davis <futabachan@y...>
Hi Susan
Cheap electric handplane. Fairing a Micro keel I tried rasps, surforms,
handplanes, grinders, sanders &c. All slow or of limited effect.
Eventually after hours of messing around I gave in and bought a cheapo
electric handplane for less than the cost of a half day rental, and finished
the job in [literally] minutes. The power plane isn't my favourite tool for
anything else, but I've rough dimensioned wood with it since and the lead
doesn't appear to have even significantly dulled the blades. Unlike with the
hand-powered edged tools there was no tendency for the lead to 'stick',
grabbing the blade. If you are going to use a traditional plane I'd try to
get the biggest lump of iron you can find - the extra inertia seemed to help
when compared to a little blockplane.
cheers
Derek
cheers
Derek
--- Inbolger@yahoogroups.com, eheins@c... wrote:
fine tuning nor sharpening.That is what bodyshops used at one time I
know. You can get surform planes and rasps in several sizes.
Charcoal mask and good glove are manditory IMHO.
> I can attest that a hand plane makes the job pretty easy.I would try a surform first. Cheaper and easier to use as there is no
I can attest that a hand plane makes the job pretty easy. I performed
exactly the same funtion on the lead insert in the Chebacco centerboard.
In hindsight I spent more time ruminating about the best method than the
handplane required to accomplish the job. If it's a big job I'd not
hesitate to buy one of the cheap 20 buck electric planers you can get from
any of the "truckload" tool sales that always seem to crop up at the
American Legion hall.
> < What's the best way to fair lead?
> < Susan Davis
> Bumps can be smashed flat with a hammer.
> I have found that cutting with a Skilsaw can
> be helpful on the edges.
> But for the 'flat', I am guessing here, and if it were
> me, I would try an electric plane, maybe even
> a hand plane.
> (978) 282-1349
> SPONSORED LINKS
> Boating safety
> Alaska outdoors
> Boating magazine
> Great outdoors
> YAHOO! GROUPS LINKS
> Visit your group "bolger" on the web.
In a "how-to" in Sailing World about fairing the keel on a J-22, they
recommended a power plane for gross lead removal. Eye protection is
manditory and I'd strongly suggest at least a good quality dust mask.
JB
JB
Sent: Monday, July 25, 2005 11:30 AM
Subject: [bolger] Fairing lead?
I would suggest that you refer to books on wood cabinetry. Somewhere
there will be a discussion about planing wide boards and grinding the
blade so that the corners of the blade don't dig in. It would be cheap
enough to buy a blade to dedicate to this purpose. It amounts to
grinding a very slight radius on the blade. You would be, in effect,
scooping out lead. the corners of the blade would be above the bed (if
that's the word) of the plane so would not dig in. It would be more
complicated to prepare an electric plane but would be a whole lot
faster. One of those japanese rasp/planes might serve also.
Bob Chamberland
Bob Chamberland
--- Inbolger@yahoogroups.com, "Bob Chamberland" <cha62759@t...> wrote:
> Handplane.
> Bob Chamberland
> What's the best way to fair lead?Bumps can be smashed flat with a hammer.
> Susan Davis
a hand plane.
Handplane.
Bob Chamberland
Bob Chamberland
