Re: [bolger] Re: Sand blasting for epoxy prep
In a message dated 8/15/05 10:50:54 PM Central Daylight Time,
stephensonhw@...writes:
> It seems to me that sanding is meant to selectively wear away the high
> spots so as to achieve a smooth surface.
This is one objective of sanding, but not the only one. J.E. Gordon, in "The
New Science of Strong Materials" relates an account of how inconsistent
adhesive performance in glued plywood used on WW II gliders was remedied by
sandblasting. The objective was not to achieve a cosmetically smooth surface, but an
adhesive-friendly one.
Ciao for Niao,
Bill in MN
spots so as to achieve a smooth surface. How can sand-blasting do that?
Howard
--- Inbolger@yahoogroups.com, "moose2much" <moose2much@y...> wrote:
> It seems one of the great burdens of taped seam construction or
> sheathed bottoms is the large expanses to sand. If the bottom and
> maybe the seams could be carefully sand blasted before adding new
> layers or paint time might be saved.
If sand is too aggressive, walnut shells are used on delicate surfaces; e.g.
taking the paint off of aircraft aluminum skin.
> layers or paint time might be saved. I have a friend who has a
> monuement (gravestone) company and it would be easy to get a hull
> done. I would want to try it on a sample piece first. The sand may
> not eat the resin as fast as you would expect, rubber stencils are used
> for the lettering.
> Suffering From Post Bovine Traumatic Shock Disorder.
for the lettering.
