Re: Centreboard weighting
> I located a small beer brewery close to my home, and the brewer, a
> one-man-band, kindly let me have a jam-jar-full of concentrated
> isinglass, which he uses for fining beer, if it too cloudy!
DON'T use isinglass! It is not what you want, even if it sounds like
water glass.
http://www.infoplease.com/ce6/society/A0825591.html
http://www.infoplease.com/ce6/sci/A0851590.html
-Peter Belenky
Grateful thanks to John, Roger, Paul, Bill and Clyde for all the
helpful advice.
The centreboard has had a coat and when it is thoroughly dry, I shall
do a bit of lead melting. Provided that my wife is well out of the
way, of course.
Another nice example of the freemasonry of home boat builders, and the
kindliness of our kibbutzers!
Alvan Eames.
> My problem is that I need to protect the wood from the heat of the
> lead.
I just poured 160 pounds of lead into the daggerboard of my
Singlehanded Schooner, with no trouble. Apart from some minor
scorching immediately adjacent to the lead, the pour shouldn't hurt
your centreboard.
> The suggestion is that ISINGLASS is painted on to the exposed
> surfaces. Isinglass is unobtainable here in the UK these days,
Try a brewer's supply shop -- Isinglass is used as a fining agent to
remove cloudiness from beer. It's routinely available in North
America; I'd expect it to be the same in the UK.
Susan Davis <futabachan@...>
Put the centerboard on a flat surface with poly under it, and fill with
lead shot and pour epoxy into the shot to fill. You might want to
enlarge to square because it won't be solid lead but you can always
enlarge it later if the board doesn't sink properly. Clyde
> I am in the closing stages of fitting out a Cartopper. The recommended
> weighting of the centreboard is by pouring molten lead into a four ins
> square hole in the plywood.
> lead. The suggestion is that ISINGLASS is painted on to the exposed
> although I remember it being used for the preservation of eggs in the
> 30's!
> Does any member of the Forum have any suggestion as to an available
> substitute for the Isinglass?
> Fax: (978) 282-1349
> SPONSORED LINKS
> Alaska outdoors
> <http://groups.yahoo.com/gads?t=ms&k=Alaska+outdoors&w1=Alaska+outdoors&w2=Boating+magazine&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=yX2hIRaAaZ2gyk6hnDdobg>
> Boating magazine
> <http://groups.yahoo.com/gads?t=ms&k=Boating+magazine&w1=Alaska+outdoors&w2=Boating+magazine&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=fUSwwDYyU3pWaG8-PTCw9w>
> Boating safety
> <http://groups.yahoo.com/gads?t=ms&k=Boating+safety&w1=Alaska+outdoors&w2=Boating+magazine&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=KUX84hVBUAJOjiZ4u84Amw>
> Great outdoors
> <http://groups.yahoo.com/gads?t=ms&k=Great+outdoors&w1=Alaska+outdoors&w2=Boating+magazine&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=uAmYtxU-jpykdYS_JRw0eA>
> YAHOO! GROUPS LINKS
> * Visit your group "bolger
> <http://groups.yahoo.com/group/bolger>" on the web.
As has been mentioned, there isn't alot of damage done to the wood by
molten lead, since it melts at such a low temperature, as I remember
right around 700 degrees. This is too low of a temperature to burn
wood. You do though want to insure that the wood is dry, any moisture
present can cause spattering with molten lead which can be dangerous.
Bill H.
recommended
ins
> 30's!
Hi Alvan,
I, too, am just finishing a cartopper. I poured the lead without any
protection of the plywood. The piece of ply that I backed the hole
with got quite charred, but the centerboard ply didn't seem to burn
much. Seehttp://daviswiki.org/PaulThoberabout half way down the page
to see the end result.
Interesting; there are at least three Cartoppers being built by group
members. Maybe someone should host a regatta.
Paul
I didn't use any protection and had no significant charring. Wood is a
common material for protecting steel beams from fire (or was in the 1930s).
A little discoloring but, in my case, that is hidden under the fiberglass.
See the last (bottom) picture at
http://home.earthlink.net/~derbyrm/Dayawl.html
Roger (I found waterglass at the pharmacy of a drug store in 1950 if that
helps.)
> Try looking for "water glass" or "sodium silicate". It is most certainly
> still available, but I don't know where you'd find it at retail.
> From: "AlvanEames" <ALVAN_EAMES@...>
>> 30's!
>> Bolger rules!!!
>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:
> (978) 282-1349
>> Yahoo! Groups Links
> (978) 282-1349
Sent: Tuesday, August 23, 2005 2:56 PM
Subject: [bolger] Centreboard weighting
> 30's!
(978) 282-1349
30's!
