Re: [bolger] Need filler help
There are surely several approaches, but what I've seen recommended would
be:
- drill pilot holes thru the plywood into the transom to locate the screw
holes
- set the plywood aside and then
- drill oversize holes in the transom and floatation deeper than the screws
- fill these with epoxy thickened with silica thickener (and milled glass
fibers if you really want strength)
- redrill the screw pilot holes after the epoxy sets up
- scrub the transom down good and sand with coarse paper to scratch it up
- I'd thicken the "filler" epoxy with silica thickener (white) or wood
flour (brown)
OR
- use shorter screws that won't go thru the transom
- butter the area with 3M 5200 and wait a week or two after assembly before
you load up the trim tabs
(Note: this would be a permanent installation.)
> First my apologies for a non-Bolger boat question.
> I am going to put trim tabs on my boat and the transom is
> not flat where the tabs need to go. My thinking is that
> a plywood spacer and some kind of filler will make a
> flat surface on which to mount the tabs.
> The tabs themselves are attached with screws.
> The screws will go through the spacer and the glass transom
> into some sealed in floatation and I am very concerned about
> a water tight joint.
> So I have a need to fill the space between a flat piece of
> 2" x 8" plywood and some NOT flat gelcoat.
> Here is the plan for the spacer:
> Tape wax paper to the gelcoat.
> Thicken some epoxy to peanut butter consistancy.
> Apply filler to plywood and carefully press into place
> and hope all the gaps get filled.
> Questions:
> What is the best thickener for epoxy for an in
> the water whenever the boat is in the water
> application?
> Is there something else that would make a better
> spacer?
> Is there a better way to make flat attachment points
> for the tabs?
> When is the best time to remove the excess goop?
> What questions should I have asked but didn't?!
> Again sorry for the non-Bolger question, but I thought
> my best chance for an optimal answer was from this group.
> hal
> (978) 282-1349
Questions:
application?
spacer?
for the tabs?
hal
