RE: [bolger] Re: Chebacco anyone?
I'm mistaken, my rudder does follow the hull angle, pretty much. No top
plate either, just a bottom end plate. - Bill
_____
Bill Kreamer
Sent: Monday, October 10, 2005 1:32 PM
To: Jamie Orr
Subject: [bolger] Re: Chebacco anyone?
Hi Jamie,
Thanks I can work with that picture, and I found
http://www.chebacco.com/articles/016/8/article.htm.
Yahoo kindly truncated Chuck's email. Can you email me chuck's email so I
can get to him off-group? I found yours through Google.
My rudder top edge is horizontal, but for the reason that it has end plates
on both top and bottom. I couldn't say whether this is better than having
the rudder run clear up to the hull. I guess your rudder has enough overhead
clearance not to touch the hull when it's hard over?
Thanks, Bill
_____
Jamie Orr
Sent: Monday, October 10, 2005 1:28 AM
Bill, I've posted a picture of Chuck Gottfried's Full Gallop flying a
jib in Bolger 6. You should contact him directly at cgottfried@...
for better information.
Randy Wheating also uses a jib, the one
shown on the sail plan, with a 5' foot.
Chuck is a member of this group, I expect Randy is too but I haven't
looked yet and if I do before I send this I will have to re-type it!
Good pictures of Samantha/Lois. In the one at anchor, the top of the
rudder is visible -- it looks like it is level, rather than sloping
up. Is that the case? The plans show the rudder should rise, not
quite with the slope of the hull because it would catch, but in that
direction. If yours is flat, then it may be less effective as water
will be flowing over the top more than if it was sloped. I don't
know just how much difference that would make, and I may be wrong
about the lack of slope anyway....
Jamie
--- Inbolger@yahoogroups.com, "Bill Kreamer" <kreamer@a...> wrote:
> Hi Jamie,
> I put some images in Bolger6 Files (Bill's Chebacco). The boat's
builder,
> Paul Thober named her "Samantha;" she is now "Lois."
> Quoting Paul:
> "This boat is a modified Chebacco - it varies from the design in
> following ways: It has a shallow draft keel rather than a
centerboard, the
> cabin is longer, wider and taller allowing a full length double
berth and
> facing settees with a fold-down table. The cockpit is shorter by
the amount
> the cabin is longer. She is gaff-rigged."
> And:
> "I thought the cabin far too small for cruising comfort. In my
opinion the
> standard Chebacco is really a day sailor that can be used for camp
cruising.
> My solution was to lengthen and widen the cabin and to raise the
cabin roof.
> I also raised the sheer by 4". I eliminated the centerboard in
favor of the
> keel shown on the cruising version of the Chebacco in Boats With an
Open
> Mind."
> A quirk of the boat, perhaps because it has a lot more windage than
> standard Chebacco, is that it quickly loses way when tacking in a
15 knot
> breeze. I have to get up a good head of steam and put the helm over
just so,
> no more and no less, to tack through. It is not always successful,
so I'll
> run the engine in an anchorage as insurance.
> Jamie, the mizzen has two sheets as you suggest, but one sheet to a
boomkin
> would seem simpler, maybe foul the outboard less, and give flatter
sheeting?
> I do take your point on reefing early.
> Can you give me any urls of Chebacco jib pictures?
> Thanks for your help,
> Bill
> _____
Behalf Of
> Jamie Orr
> Sent: Friday, October 07, 2005 10:38 PM
> Hi Bill,
> Interesting comments. Sound like you've got an unusual amount of
> weather helm, could it be due to the keel? Could you change the
> profile, I wonder?
> The mizzen can be made self tending by putting a fairlead on either
> quarter, and using two sheets. You only need to adjust the sheets
> once each, then leave them alone.
> Going downwind, I've had to reef in order to ease the steering, but
> the wind was well past the point where I would have reefed if I was
> going the other way, so it was time anyway. It didn't make much
> difference to the speed.
> I don't use a jib, but a couple of the guys fly them from short
> bowsprits and like them. Definitely added some speed in under 15
> knot winds, over that the advantage disappeared, at least on the
last
> outing.
> Speed is relative, I guess. I frequently sail over 5 knots, and I
> thought that was okay, without being able to get up on plane.
Again,
> could the keel be making a difference, more drag?
> Is your's what they call the "glass house" version? Can you post
> some pictures for us?
> Cheers,
> Jamie Orr
> > On the plus side, my 20 foot Chebacco sails itself to windward
OK,
> when not
> > pinched. Mine has optional solid keel, no centerboard, and
extended
> cabin,
> > so there is lots of room below. Keep in mind this is a
comfortable
> cruiser,
> > not a "fast boat."
> > On the minus side, extending the cabin cramped the cockpit, where
> one spends
> > the most time. So as configured, it's a boat for two adults, or
me
> and the
> > grandkids. I could chop the cabin back just a dite. Nah, too much
> like work.
> > The hull form makes the helm sensitive to heel angle, and it
> develops
> > weather helm in puffs.
> > There's a bit too much weather helm overall, and since I never
> sheet the
> > mizzen in, I've taken to leaving it home. I could install an
offset
> boomkin
> > to make the mizzen self tending, and add a bowsprit and self
tending
> > balanced jib to fix the weather helm. The boat could use more
> area up
> > forward and down low.
> > Still on the topic of weather helm, on a downwind run in heavy
air
> the
> > shallow rudder just hasn't got enough area, winglets
> notwithstanding. But
> > hey, this is a catboat. Hmm, a nice deep kick up rudder might be
> good
> > project. - Bill
> > _____
> Behalf Of
> > dnjost
> > Sent: Wednesday, October 05, 2005 6:09 PM
> > Subject: [bolger] Chebacco anyone?
> > Hi folks,
> > I'm back after a short stay in prefab boating. the Marshall cat
is
> > sold and I am itching to build anew.
> > I am thinking of a 20 foot Chebacco as it is easy to rig and
> trailer,
> > and looks very sharp as well!
> > does anyone know how it sails? After all, windward is a place
that
> > must be gone to eventually despite the old adage of "gentlemen
> don't
> > sail to windward" well, if that's the case...I'm no gentleman.
> > David Jost
> > boatless in Massachusetts
> > - no cursing, flaming, trolling, spamming, respamming, or
flogging
> dead
> > horses
> posts
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> 01930, Fax:
> > (978) 282-1349
> > _____
> > YAHOO! GROUPS LINKS
> > * Visit your group "bolger
> <http://groups.yahoo.com/group/bolger> "
> > on the web.
> > * To unsubscribe from this group, send an email to:
> > <mailto:bolger-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo!
> > <http://docs.yahoo.com/info/terms/> Terms of Service.
> > _____
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> SPONSORED LINKS
> Boating
> <http://groups.yahoo.com/gads?
t=ms&k=Boating&w1=Boating&w2=Boat+design&w3=St
> orage&w4=Outdoors&c=4&s=57&.sig=6EUy-ILu0AAWqIQMDKUZzQ>
> Boat
t=ms&k=Boat+design&w1=Boating&w2=Boat+design&w
> 3=Storage&w4=Outdoors&c=4&s=57&.sig=jxvsfwyqTnvGgyLmJhdU3w> design
> Storage
t=ms&k=Storage&w1=Boating&w2=Boat+design&w3=St
> orage&w4=Outdoors&c=4&s=57&.sig=TSKhYcGNa3g7zVn_n0zkcQ>
> Outdoors
t=ms&k=Outdoors&w1=Boating&w2=Boat+design&w3=S
> torage&w4=Outdoors&c=4&s=57&.sig=NICDzMxP49G7fMZxAKiu6g>
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
horses
(978) 282-1349
_____
YAHOO! GROUPS LINKS
* Visit your group "bolger <http://groups.yahoo.com/group/bolger> "
on the web.
_____
horses
(978) 282-1349
SPONSORED LINKS
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating+magazine&w1=Boating+magazine&w2
=Alaska+outdoors&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=F6_uQijqw
2ScmVAPehRO4A> magazine
Alaska
<http://groups.yahoo.com/gads?t=ms&k=Alaska+outdoors&w1=Boating+magazine&w2=
Alaska+outdoors&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=plfUV3CmlK
k-hgZREfzBBQ> outdoors
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating+safety&w1=Boating+magazine&w2=A
laska+outdoors&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=r8ql9_kKXb4
ghiPn48fOvA> safety
Great
<http://groups.yahoo.com/gads?t=ms&k=Great+outdoors&w1=Boating+magazine&w2=A
laska+outdoors&w3=Boating+safety&w4=Great+outdoors&c=4&s=83&.sig=9l9RE2t51Cb
VVIxFXYgE4A> outdoors
_____
YAHOO! GROUPS LINKS
on the web.
_____
It will make a lot of difference. Mine is as tight a fit as I could
get, and I have not problems steering running downwind. Even when
overpowered.
> for better information. Randy Wheating also uses a jib, the one
haven't
that
water
> Jamie
> > Hi Jamie,
> builder,
> > Quoting Paul:
> the
> centerboard, the
> berth and
> the amount
> > And:
> opinion the
camp
> cruising.
> cabin roof.
> favor of the
an
> Open
> > Mind."
than
> a
> 15 knot
over
> just so,
successful,
> so I'll
> boomkin
flatter
> sheeting?
> > Bill
> > _____
> Behalf Of
> > Jamie Orr
> > Hi Bill,
> > profile, I wonder?
either
sheets
but
was
> last
> > outing.
I
> Again,
> > Cheers,
> > Jamie Orr
> OK,
> > when not
> extended
> > cabin,
> comfortable
> > cruiser,
> > > not a "fast boat."
where
> > one spends
> me
> > and the
much
> > like work.
> > develops
> > sheet the
> offset
> > boomkin
> tending
> sail
> > area up
> air
> > the
be
> a
> > good
> > > project. - Bill
> > > _____
> > Behalf Of
> > > dnjost
> > > Hi folks,
cat
> is
> > trailer,
> that
> > don't
> > > David Jost
> > > Bolger rules!!!
> flogging
> > dead
> > > horses
Fred'
> > posts
away
> > 01930, Fax:
> > > (978) 282-1349
> > > - Open discussion: bolger_coffee_lounge-
> > > _____
> > > YAHOO! GROUPS LINKS
> > > on the web.
> > > _____
flogging
> dead
> > horses
> posts
> 01930, Fax:
> > (978) 282-1349
> > SPONSORED LINKS
> > Boating
> > Boat
design
> > Storage
> > Outdoors
> > _____
> > YAHOO! GROUPS LINKS
> > on the web.
> > _____
Mine has standard hull and rudder/centerboard, but the mast is moved
forward 6-8 inches.
Light weather helm if I drop the board all the way, but it is easily
canceled out by NOT dropping the centerboard all the way.
> In the flush deck update of Chebacco, Bolger moves the mast forward
a good
> foot and eliminates the rake to combat reports of excessive weather
helm. He
> also adds a balanced rudder to lighten the helm even futher. Look
in the
> yahoo group bolger_study_plans_only for a drawing.
> From: "Roger Derby" <derbyrm@e...>
> Sent: Friday, October 07, 2005 6:37 AM
> Subject: Re: [bolger] Chebacco anyone?
> > Heading up in the puffs is a good way to get to windward
quickly. I guess
> > it's a matter of degree.
> > Could the weather helm be helped by decreasing the mast rake?
Might be a
> > relatively simple fix, particularly if you've got the tabernacle
> arrangement
> > (whittle a bit on the heel and pad the lockdown bar).
> > (Or maybe just peak the gaff higher?) (Or maybe just flatten the
sail's
> > draft with the luff and foot tensions?) I'm curious as to what
you've
> tried
> > that didn't work, even tho the CB version shouldn't have the same
> problems.
> > Increasing the rudder area might also help the weather helm.
Don't some
> of
> > PCB's designs uses a bow "center" board and the rudder to develop
all the
> > lateral area? That kind of rig could be tuned to whatever helm
you
> wanted.
> > Roger (still building on a 20' lapstrake CB cruising conversion
version)
> > derbyrm@N...
> >http://home.earthlink.net/~derbyrm
> > From: "Bill Kreamer" <kreamer@a...>
OK, when
> > > not
extended
> cabin,
comfortable
> > > cruiser,
> > > not a "fast boat."
where one
> > > spends
me and
> the
much like
> > > work.
develops
sheet the
offset
> > > boomkin
tending
sail area
> up
air the
notwithstanding.
> But
be a good
> > > project. - Bill
> > > _____
Behalf
> Of
> > > dnjost
> > > Hi folks,
cat is
trailer,
that
don't
> > > David Jost
> > > Bolger rules!!!
flogging dead
> > > horses
Fred' posts
away
01930,
> Fax:
> > > (978) 282-1349
> > > _____
> > > YAHOO! GROUPS LINKS
> > > on the web.
> > > _____
> > > Bolger rules!!!
flogging dead
> > > horses
Fred' posts
away
01930,
> Fax:
> > > (978) 282-1349
> > > Yahoo! Groups Links
flogging dead
> horses
posts
01930, Fax:
> (978) 282-1349
> > Yahoo! Groups Links
Hi Jamie,
Thanks, Bill
_____
Jamie Orr
Jamie
> Hi Jamie,
builder,
> Quoting Paul:
centerboard, the
berth and
the amount
> And:
opinion the
cruising.
cabin roof.
favor of the
Open
> Mind."
15 knot
just so,
so I'll
boomkin
sheeting?
> Bill
> _____
Behalf Of
> Jamie Orr
> Hi Bill,
> profile, I wonder?
last
> outing.
Again,
> Cheers,
> Jamie Orr
OK,
> when not
extended
> cabin,
comfortable
> cruiser,
> > not a "fast boat."
> one spends
me
> and the
> like work.
> develops
> sheet the
offset
> boomkin
tending
> area up
air
> the
> good
> > project. - Bill
> > _____
> Behalf Of
> > dnjost
> > Hi folks,
is
> trailer,
that
> don't
> > David Jost
flogging
> dead
> > horses
> posts
> 01930, Fax:
> > (978) 282-1349
> > _____
> > YAHOO! GROUPS LINKS
> > on the web.
> > _____
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> SPONSORED LINKS
> Boating
> Boat
> Storage
> Outdoors
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
horses
(978) 282-1349
_____
YAHOO! GROUPS LINKS
on the web.
_____
flying a
> jib in Bolger 6.
The more I see of these Chebaccos the more alluring they become!What
a misery to find myself deep in construction bliss with Windermere
while playfully entertaining thoughts of my next boat,which for the
moment would be the AS-29.However she is being given a good threat
from the Red Zinger and lately,now,...darnit....looming just over
horizon comes the Chebacco.
I'd better hurry up and finish Windermere so that I can finally move
aboard and have more bucks available for multiple building
orgasms/pleasures :-)
Thanks for great picture Jamie!
Peter Lenihan,who still misses his Micro LESTAT despite some scary
thoughts about all the fun I could have with a
Chebacco...yikes!....from along the shores of the St.Lawrence,as it
were..............
Jamie
> Hi Jamie,
builder,
> Quoting Paul:
centerboard, the
berth and
the amount
> And:
opinion the
cruising.
cabin roof.
favor of the
Open
> Mind."
15 knot
just so,
so I'll
boomkin
sheeting?
> Bill
> _____
Behalf Of
> Jamie Orr
> Hi Bill,
> profile, I wonder?
last
> outing.
Again,
> Cheers,
> Jamie Orr
OK,
> when not
extended
> cabin,
comfortable
> cruiser,
> > not a "fast boat."
> one spends
me
> and the
> like work.
> develops
> sheet the
offset
> boomkin
tending
> area up
air
> the
> good
> > project. - Bill
> > _____
> Behalf Of
> > dnjost
> > Hi folks,
is
> trailer,
that
> don't
> > David Jost
flogging
> dead
> > horses
> posts
> 01930, Fax:
> > (978) 282-1349
> > _____
> > YAHOO! GROUPS LINKS
> > on the web.
> > _____
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> SPONSORED LINKS
> Boating
> Boat
> Storage
> Outdoors
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
Thanks Rob. That would be a question for the builder, Paul Thober, who is
now building another boat. - Bill
_____
Robin Badenoch
Sent: Sunday, October 09, 2005 9:05 AM
Hi Bill,
Now that looks like a very nice 20' cruiser. Do you have any
drawings of the mods you made.
Rob B
Oz
> On the plus side, my 20 foot Chebacco sails itself to windward OK,
when not
extended cabin,
> so there is lots of room below. Keep in mind this is a comfortable
cruiser,
> not a "fast boat."
one spends
> the most time. So as configured, it's a boat for two adults, or me
and the
like work.
develops
sheet the
offset boomkin
tending
> balanced jib to fix the weather helm. The boat could use more sail
area up
> Still on the topic of weather helm, on a downwind run in heavy air
> hey, this is a catboat. Hmm, a nice deep kick up rudder might be a
good
> project. - Bill
> _____
Behalf Of
> dnjost
> Hi folks,
is
trailer,
that
don't
> David Jost
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
horses
(978) 282-1349
_____
YAHOO! GROUPS LINKS
on the web.
_____
Bill-- Have you tried trimming the mizzen to reduce weather helm? If you
ease it, the center of effort should move forward and reduce weather helm.
Re the off center vortex: I read an article which addressed a similiar
vortex on Viking long ships and their derivatives. The article argued that
said vortex reduced drag and improved performance. The hull shapes of long
boats and Chebacco's are different. But you can't do anything about the
vortex, so you might want to claim it as a performance enhancing feature
produced by PCB's genius. (If you don't know how to pronounce a word,
pronounce it loudly!)
John T
Sent: Friday, October 07, 2005 10:05 PM
Subject: RE: [bolger] Chebacco anyone?
> Thanks for the reply Roger. I should have said it develops _excess_
> weather
> helm as the wind increases. There's no rake to remove, and the gaff is
> peaked nearly vertical now. I'm not inclined to try a bow centerboard, and
> I
> don't want to move the mainmast forward either - too much deck re-work -
> but
> adding a jib might do the trick. Then I could actually let the mizzen work
> a
> bit. And slacking or dropping the main would be an option in a blow, when
> tying in a reef was neglected.
> Converting the rudder to a kick up type wouldn't be all that hard. It
> could
> even have a bit of balance area forward of the hinge line when all the way
> down.
> Another question. Has anyone seen a trail of vortex bubbles off the stern
> when the boat is pressed? It is off center a foot or more, and changes to
> the windward side on either tack. The off center part leads me away from
> the
> rudder as the culprit. But could it be suction from hull leeway pulling
> air
> in at the rudder stock hole?
> -Bill
> _____
> Roger Derby
> Sent: Friday, October 07, 2005 6:38 AM
> Heading up in the puffs is a good way to get to windward quickly. I guess
> Could the weather helm be helped by decreasing the mast rake? Might be a
> arrangement
> (Or maybe just peak the gaff higher?) (Or maybe just flatten the sail's
> draft with the luff and foot tensions?) I'm curious as to what you've
> tried
> problems.
> Increasing the rudder area might also help the weather helm. Don't some
> of
> PCB's designs uses a bow "center" board and the rudder to develop all the
> lateral area? That kind of rig could be tuned to whatever helm you
> wanted.
> Roger (still building on a 20' lapstrake CB cruising conversion version)
>derbyrm@...
> horses
> (978) 282-1349
> Checked by AVG Anti-Virus.
> Version: 7.0.344 / Virus Database: 267.11.9/118 - Release Date: 10/3/2005
Hi Bill,
Rob B
Oz
when not
extended cabin,
cruiser,
> not a "fast boat."
one spends
and the
like work.
develops
sheet the
offset boomkin
tending
area up
good
> project. - Bill
> _____
Behalf Of
> dnjost
> Hi folks,
is
trailer,
that
don't
> David Jost
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
Hi Jamie,
I put some images in Bolger6 Files (Bill's Chebacco). The boat's builder,
Quoting Paul:
"This boat is a modified Chebacco - it varies from the design in the
following ways: It has a shallow draft keel rather than a centerboard, the
cabin is longer, wider and taller allowing a full length double berth and
facing settees with a fold-down table. The cockpit is shorter by the amount
And:
"I thought the cabin far too small for cruising comfort. In my opinion the
standard Chebacco is really a day sailor that can be used for camp cruising.
My solution was to lengthen and widen the cabin and to raise the cabin roof.
I also raised the sheer by 4". I eliminated the centerboard in favor of the
keel shown on the cruising version of the Chebacco in Boats With an Open
Mind."
A quirk of the boat, perhaps because it has a lot more windage than a
standard Chebacco, is that it quickly loses way when tacking in a 15 knot
breeze. I have to get up a good head of steam and put the helm over just so,
no more and no less, to tack through. It is not always successful, so I'll
Jamie, the mizzen has two sheets as you suggest, but one sheet to a boomkin
would seem simpler, maybe foul the outboard less, and give flatter sheeting?
Bill
_____
Jamie Orr
Hi Bill,
profile, I wonder?
knot winds, over that the advantage disappeared, at least on the last
outing.
thought that was okay, without being able to get up on plane. Again,
Jamie Orr
when not
> pinched. Mine has optional solid keel, no centerboard, and extended
cabin,
cruiser,
> not a "fast boat."
one spends
and the
like work.
develops
sheet the
> mizzen in, I've taken to leaving it home. I could install an offset
boomkin
> to make the mizzen self tending, and add a bowsprit and self tending
area up
good
> project. - Bill
> _____
Behalf Of
> dnjost
> Hi folks,
> I'm back after a short stay in prefab boating. the Marshall cat is
trailer,
> does anyone know how it sails? After all, windward is a place that
don't
> David Jost
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
horses
(978) 282-1349
SPONSORED LINKS
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating&w2=Boat+design&w3=St
Boat
<http://groups.yahoo.com/gads?t=ms&k=Boat+design&w1=Boating&w2=Boat+design&w
Storage
<http://groups.yahoo.com/gads?t=ms&k=Storage&w1=Boating&w2=Boat+design&w3=St
Outdoors
<http://groups.yahoo.com/gads?t=ms&k=Outdoors&w1=Boating&w2=Boat+design&w3=S
_____
YAHOO! GROUPS LINKS
on the web.
_____
stern
changes to
from the
pulling air
Bolger has described something like this with Long Micro. He ascribed
it to the low aspect ratio keel. Hard for me to imagine the keel on
Chebacco could do, though.
Hi Bill,
profile, I wonder?
outing.
Jamie Orr
when not
cabin,
cruiser,
> not a "fast boat."
one spends
and the
like work.
develops
sheet the
boomkin
area up
good
> project. - Bill
> _____
Behalf Of
> dnjost
> Hi folks,
trailer,
don't
> David Jost
dead
> horses
posts
01930, Fax:
> (978) 282-1349
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
Thanks for the reply Roger. I should have said it develops _excess_ weather
peaked nearly vertical now. I'm not inclined to try a bow centerboard, and I
don't want to move the mainmast forward either - too much deck re-work - but
adding a jib might do the trick. Then I could actually let the mizzen work a
Converting the rudder to a kick up type wouldn't be all that hard. It could
down.
the windward side on either tack. The off center part leads me away from the
rudder as the culprit. But could it be suction from hull leeway pulling air
-Bill
_____
Roger Derby
relatively simple fix, particularly if you've got the tabernacle arrangement
draft with the luff and foot tensions?) I'm curious as to what you've tried
that didn't work, even tho the CB version shouldn't have the same problems.
Increasing the rudder area might also help the weather helm. Don't some of
lateral area? That kind of rig could be tuned to whatever helm you wanted.
Sounds like a Black Skimmer to me with the tabernacle mast
dnjost wrote:
>John,
>I could not find the study plans in the Bolger group you mentioned, I
>have written to Mr. Bolger with my questions regarding the design, and
>hopefully he will respond with some answers and ideas.
>The requirements are:
>1. sprawling room for my wife to get a tan
>2. small cuddy to get out of the rain and keep lunch dry (one night
>overnight possibility)
>3. must be easy to launch
>4. capable of sailing well. (I am an ex-dinghy sailor that likes a
>little adrenaline rush every now and then.)
>David Jost
It's in there (mind the wrap):
http://groups.yahoo.com/group/bolger_study_plans_only/files/Chebacco%20%23540/Chebacco%20%23540%20RD%20%28raised%20deck%29/
Sent: Friday, October 07, 2005 9:06 AM
> John,
> David Jost
horses
(978) 282-1349
John,
In the flush deck update of Chebacco, Bolger moves the mast forward a good
foot and eliminates the rake to combat reports of excessive weather helm. He
also adds a balanced rudder to lighten the helm even futher. Look in the
arrangement
tried
problems.
wanted.
>derbyrm@...
> From: "Bill Kreamer" <kreamer@...>
> > On the plus side, my 20 foot Chebacco sails itself to windward OK, when
> > not
cabin,
> > cruiser,
> > not a "fast boat."
> > On the minus side, extending the cabin cramped the cockpit, where one
> > spends
> > the most time. So as configured, it's a boat for two adults, or me and
> > grandkids. I could chop the cabin back just a dite. Nah, too much like
> > work.
> > The hull form makes the helm sensitive to heel angle, and it develops
> > There's a bit too much weather helm overall, and since I never sheet the
> > boomkin
> > balanced jib to fix the weather helm. The boat could use more sail area
up
> > Still on the topic of weather helm, on a downwind run in heavy air the
> > shallow rudder just hasn't got enough area, winglets notwithstanding.
But
> > hey, this is a catboat. Hmm, a nice deep kick up rudder might be a good
> > project. - Bill
> > _____
Of
> > dnjost
> > Hi folks,
> > I am thinking of a 20 foot Chebacco as it is easy to rig and trailer,
> > must be gone to eventually despite the old adage of "gentlemen don't
> > David Jost
> > horses
Fax:
> > (978) 282-1349
> > _____
> > YAHOO! GROUPS LINKS
> > on the web.
> > _____
> > horses
Fax:
> > (978) 282-1349
> > Yahoo! Groups Links
horses
(978) 282-1349
> not
> pinched. Mine has optional solid keel, no centerboard, and extended cabin,
> cruiser,
> not a "fast boat."
> spends
> the most time. So as configured, it's a boat for two adults, or me and the
> work.
> boomkin
> balanced jib to fix the weather helm. The boat could use more sail area up
> shallow rudder just hasn't got enough area, winglets notwithstanding. But
> project. - Bill
> _____
> dnjost
> Hi folks,
> David Jost
> horses
> (978) 282-1349
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
> horses
> (978) 282-1349
On the plus side, my 20 foot Chebacco sails itself to windward OK, when not
so there is lots of room below. Keep in mind this is a comfortable cruiser,
not a "fast boat."
On the minus side, extending the cabin cramped the cockpit, where one spends
grandkids. I could chop the cabin back just a dite. Nah, too much like work.
mizzen in, I've taken to leaving it home. I could install an offset boomkin
project. - Bill
_____
dnjost
Hi folks,
horses
(978) 282-1349
_____
YAHOO! GROUPS LINKS
on the web.
_____
I've never gotten a really good reading on how the Chebacco compares
to the Marshall cats on the racecourse? Anyone have any insight? My
guess is the Chebaccos have success downwind and in light air.
Hi David
I just can't resist it when someone asks about a Chebacco!
Jeez, where to start? I've been sailing mine now for over five years,
and have been totally satisfied. She goes well to windward, will ghost
along on a breath of wind, and is reasonably fast on any point of sail.
My only race experience was the Shipyard Raid this summer.
(http://www.shipyardraid.ca/)There were two Chebaccos and we both did
better in stronger winds, although Chuck's carried a fairly large jib
on a bowsprit that gave him extra speed over me in lower winds. Over
15 knots, though, I think the luff sag cancelled out any advantage. We
had several days of very little wind, so rowing played a big part in
the event. A Chebacco is a heavy boat to row, and our standings
reflect that.
But it was instructive. The Light Schooner sails faster, but it won't
go to windward as well, so has to make more tacks. The modified
(stretched?) Drascombe Peterboat (carries a serious jib) was fast in
all conditions, but both Chebaccos finished ahead of it when the wind
piped up (over 15 knots) from dead ahead. The Peterboat owner disputes
this, since he lost time looking for his hat when it blew away. We've
agreed to meet and do some research into it, with a dozen beer riding
on the result. Of course, then we'll have to settle the respective
merits of Canadian vs US beer....
I suppose you've had a look at www.chebacco.com? There are accounts of
sailing in various conditions in there that might help you. You don't
sail a Chebacco like a sloop with a headsail on a tight headstay, and
if you pinch her she'll just go slower. But when you're in the groove
you can feel her pick right up.
So don't hold back from a Chebacco for fear that it won't sail well.
You won't have any complaints there.
Jamie Orr
--- Inbolger@yahoogroups.com, "dnjost" <davidjost@v...> wrote:
> Hi folks,
> David Jost
Hi folks,
