Re: FREE!ship 2.00 Released
--- "Jon & Wanda(Tink)" <windyjon@m...> wrote:
> Thanks for the update. Was trying to use the design surch and was
> woundering how much info you need to get designs back?
Hi Jon,
the search script right now reads the information directly from the
FREE!ship .fbm files. It can't read what is not in there. Martijn and
myself are in discussions about what additional information will be
stored in the file, so that it can be used for searches. I thought
that some of them would make it already in version 2.0, but then it
was delayed to the next release.
Right now you can search for Design name, Designer, min. and max
Design Length, Beam, Draft (in m and ft).
Means e.g. you enter "Bolger" as Designer and "max. 15 ft" and it will
return all Bolger Designs that are max. 15 ft long (of course only if
there is a file for it). The script can't do "OR" searches, but I
think this is rarely needed.
You will be soon able to get the results sorted (i.e. the modified
script is nearly finished, just needs some testing).
For the next release there might be issues like
- kind of propulsion
- empty weight (for trailering)
- min. draft
- kind of hull (round or number of chines)
- hull material
We are considering also at some time to include thumbnails in the
file, so that you would get an impression of the design, before you
even download and open the file.
You see, there are lots of ideas. We'll see how fast Martijn can
implement them. BTW: if somebody wants to contribute ... Martijn could
use some help with proof reading the manual that comes with each
release, including inserting hyperlinks in that document..... Required
skills: English language and Acrobat.
Does this answer your question?
Stefan
Jon
"Happy to announce ... FREE!ship Version 2.00"
(sorry for cross posting, but once in a while - like for this mile stone
release - I'd like to make sure that all potentially interested boaters get
the news)
Homepage:
http://freeship.sourceforge.netorhttp://www.freeship.org
FREE Download from:
https://sourceforge.net/project/showfiles.php?group_id=140466
New:
- lots of new features (see below)
- a searchable database of free designs athttp://freeship.sourceforge.net
(people willing to share their files pls. mail them todesigns@...)
- a tutorial will be out in a couple of days
(I have to make some changes for the new features)
Also, people who know that there are .hul files of their designs available
at some site in the Web (I have quite a collection), and who agree that
those files get converted to FREE!ship and hosted on that site, of course
with them duly specified as the designer, pls. inform me and/or Martijn,
the programmer of FREE!ship, so that we can fill that database - or just
mail whatever you've got to me and/or Martijn.
Have Fun!
Stefan
---- What's New ----
Version 2.0
Released October 06, 2005
* Added a database with FREE!ship designs to the website.
These designs may be freely downloaded from www.freeship.org/designs.
Users willing to share their own designs are kindly invited
to send their designs todesigns@...
* Added import functionality of chines from a textfile
(default meters, use either comma or period)
* Import markers from a textfile
* Modified input-format of offsets of rounded hulls
* Implemented controlcurves as a new feature
* Controlcurves are added to the chines of imported chine hulls
* Create one panel for bottom panels and transoms (and other surfaces)
that are flat
* Switch visibility of partnames on or off in developed plates dialog
* Export all controlpoint coordinates to a textfile
which can be imported in Rhino
* Modified the offsets output, also exports controlcurves
* The order of layers in the layer dialog can be modified.
Also developed plates appear in the same order as the layers
in the layer dialog
* View surface area, weight and COG from within
the layer properties dialog
* Insert multiple points in one pass by intersecting visible edges
with a 3D plane
* Lock/unlock points
* Modified the developability-shading procedure by lowering the value
used to test for developability so that it produces less noise
* Extended the current hydrostatic calculations
and modified the output format
