Re: [bolger] Free!Ship study of Shivaree
> Oh well,
The depth of the plank cut into the frame increases with the ratio of
1/cosine(angle)
so, 1 / cosine(15 degrees) = 1.03527618 = 3.5% increased thickness
You can plug it into Google to figure out
http://www.google.com/search?hl=en&lr=&safe=off&q=1%2Fcosine%2815+degrees%29&btnG=Search
http://tinyurl.com/9t98u
Frame bevels are relatively easy, it was the reduction of the frame for
plank thickness that I was curious about, starts to make a lot of
difference with plank thicknesses of 1/2 in or more.
Oh well, out with the Goudgeon Bros book next time I take up a big
project. Excellent section on lofting. They have a new update out by
the way.
Bruce Hallman wrote:
>>When the plank is at an angle the amount would be greater than plank
>>thickness. Been a while since I have read up on lofting, how do you do
>>this?
>I am not an expert, but the last time I did it [with Cartoon#5] I just
>made the frames square, and took the belt sander with a 36 grit belt
>to the frames and beveled them to 'eye', working up, one strake at a
>time. In the end, boat building isn't rocket science.
>- no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
>Yahoo! Groups Links
> this?
this?
>On 12/3/05, Harry James <welshman@...> wrote:
>>Are these bulkheads less the hull thickness?
>No, the 'skin' in FREE!ship is perfectly thin, so like with
>conventional lofting, you need to subtract the thickness of the plank.
By the way thanks for your pioneering efforts on this Bruce, when I
eventually get around to playing with freeship I already will have had a
tutorial courtesy of your commentary here.
>>inspire my question. Can the program make accurate cross sections for
>mold making and patterns? I am just now sorting through the books I
>ordered to learn how to translate lines into a 3D model.
>>Bruce in NJ
>Yes, Free!Ship can make accurate bulkheads, [using the
>Point!InsertPlane command]. It is a bit clunky, but I just did a test
>of it, and did get a developed bulkhead. Hint, the edges of the
>bulkheads must be made 'crease edges'. Hopefully, with practice, I
>can get over the learning curve trouble with this.
>Yahoo! Groups Links
> Bruce in NJ
On 11/30/05,echo172@...<echo172@...> wrote:
> I've spent months selecting a boat for my needs. After much research I decided on the 648. Having just recieved the plans from PB&F this week,
I am curious what the plans show. If the plans don't have dimensions
for frames, then at the very least you could make frames after
'lofting' the hull from the table of offsets.
> your images inspire my question. Can the program make accurate cross sections for mold making and patterns?
I am just now learning, and I do not know the answer to your question.
I think it can now, and also I recall reading that the 'frames'
feature is slated for the next version release of the program.
>I am just now sorting through the books I ordered to learn how to
Just cutting out the strakes, printed with a laser printer on
cardboard allows you to make a 3D model. I have a Shivaree model
right now.
I've spent months selecting a boat for my needs. After much research I decided on the 648. Having just recieved the plans from PB&F this week, your images inspire my question. Can the program make accurate cross sections for mold making and patterns? I am just now sorting through the books I ordered to learn how to translate lines into a 3D model.
Bruce in NJ
> Attached is a study of one Phil Bolger's favorite designs, Shivaree.
> An outboard runabout, 18 ft x 7 ft, rough water capable, and one of
> the few Bolger designs that he has chosen to personally own.
> Image
>http://www.hallman.org/bolger/648/Shivaree.jpg
> fbm file
>http://www.hallman.org/bolger/648/shivaree.fbm
> 282-1349
fbm file
