Re: [bolger] AS29: new Bolger model that's beefier and stouter?
I now have a scanner at home and if somebody knows the MAIB issue, I
should have it.
Derek Waters wrote:
> If you are interested in a reworking of the AS29 along current PB&F lines
> [steel bottom, all-season insulation /floatation &c.] then I _strongly_
> suggest you contact the Bolgers directly and tell them so. Such a design is
> in the pipeline.
> My MAIB back issues are not to hand, but if no-one else supplies the
> information I'll be able to supply the details in a few days. The
> alterations to the original AS29 covered in MAIB were relatively minor,
> IIRC. A raised house forward, and a rounded lump under the bow to mitigate
> slapping are the two that spring to mind.
> cheers
> Derek
in the pipeline.
cheers
Derek
PBolgers newer version in MAIB that's stouter and heavier: any info on
it? I believe it was a few years ago in MAIB where he detailed a newer
version. Can anyone recall it or its characteristics? We are
contemplating building a AS29 but would like it a bit stronger,
perhaps with steel plate bolted on the bottom.. Thanks and best
holiday wishes.
