Re: [bolger] Re: Help! Need Birdwatcher advice
visions of mast boots dancing through your head? You have the boat bug
bad. Good for you.
Eric OHiggins wrote:
>Thanks to all who responded to this plea, and I am
>writing to Mr. Bolger hisownself about what I'm
>planning and I'll include something that Doug's
>response has suggested.
>I awake in the night with visions of mast boots
>dancing through my head -- which beats the heck out of
>visions of sugarplums, I've got to tell you -- even if
>it is Christmas Eve. Doug, there's lots of room UNDER
>the coaming on Birdwatcher, so why not a clamp-on
>mastboot extending over to the offcentreboard case to
>drain the rain and spray off into the case instead of
>letting it ran right down to the maststep? I can't
>for the life of me think why that wouldn't work a
>treat.
>Waddoyathink?
>Eric O'Higgins
>ps. I'm going to google Michelak + Cormorant to see
>if I can find something on his modded partners.---
>oarmandt <oarman89@...> wrote:
>>I have a BW 1. I used the Michelak modification at
>>the partners.
>>That is, vertical rods in the partners either side
>>of the mast and
>>lashing to hold the mast in, very simple. The mast
>>in BW 1 is in-line
>>with the centerboard case. This is fine in fair
>>weather. If you want
>>to cover the slot for protection from the rain, you
>>will want the BW 2
>>mast set-up with the mast outside the coaming. It
>>is tough to rig a
>>slot cover around the mast when it is inside the
>>coaming.
>>Doug
>>--- Inbolger@yahoogroups.com, "chaemeocyparis"
>><chaemeocyparis@y...>
>>wrote:
>>> I'm about to commit myself on the question of
>>mast position in my
>>Birdwatcher II and would
>>>like to put the mast step in line with the end of
>>the offcentreboard
>__________________________________________
>Yahoo! DSL – Something to write home about.
>Just $16.99/mo. or less.
>dsl.yahoo.com
>- no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
>Yahoo! Groups Links
treat.
Waddoyathink?
Eric O'Higgins
> the partners.
> of the mast and
> in BW 1 is in-line
> will want the BW 2
> is tough to rig a
> coaming.
> Doug
> mast position in my
> the offcentreboard
dsl.yahoo.com
Two thoughts:
- boats usually don't sail on an even keel, so the off-center yaw torque
effects you are concerned about are probably lost in the noise of sea slop
and main sheet tension
- with proper craftsmanship, amazingly fragile looking joints can be
remarkably strong -- witness some of the frail looking spindled rocking
chairs.
Sent: Thursday, December 22, 2005 11:42 AM
Subject: [bolger] Help! Need Birdwatcher advice
> I'm about to commit myself on the question of mast position in my
> like to put the mast step in line with the end of the offcentreboard to
> lessen the moment arm
> of the offcentre of effort from the rig.
> The designed gate at the partners doesn't look like a good mechanical
> solution (in addition
> to being fussy). If the board and the step are in line, I'll be able to
> put a metal fitting under
> the deck and hold the mast in place using clips like a ski boot, or even
> just bolts extending
> through the coaming with the nuts on the side, of course. I anticipate
> being able to reduce
> the coaming cutout depth from six inches to one inch or perhaps two.
> Any BW folks out there with thots to share?
> Eric O'Higgins
> horses
> (978) 282-1349
I have a BW 1. I used the Michelak modification at the partners.
That is, vertical rods in the partners either side of the mast and
lashing to hold the mast in, very simple. The mast in BW 1 is in-line
with the centerboard case. This is fine in fair weather. If you want
to cover the slot for protection from the rain, you will want the BW 2
mast set-up with the mast outside the coaming. It is tough to rig a
slot cover around the mast when it is inside the coaming.
Doug
--- Inbolger@yahoogroups.com, "chaemeocyparis" <chaemeocyparis@y...>
to lessen the moment arm
mechanical solution (in addition
able to put a metal fitting under
even just bolts extending
anticipate being able to reduce
> Eric O'Higgins
my Birdwatcher II and would
offcentreboard to lessen the moment arm
Iwould strongly concur with what Bruce mentions about contacting the
designer.
In the WB update they wrote, "The mast now stands in, and drains
into, the centerboard trunk." Yet when the plans were finalized this
was not shown. So it may be of benefit to find out why they did not
follow through on that idea.
You might also want to contact the other builders who are listed in
the Links section of this group. They are all very helpful and
proactive folks.
Birdwatcher could probably benefit from it's own discussion group at
some point. I think the Micro series could as well. (I would be
willing to co-moderate a Micro group but have not the smarts to head
one up.)
Nels (Who would love to see all the varities of Micros in one place
sometime:-)
On 12/22/05, chaemeocyparis wrote:
> would like to put the mast step in line with the end of the offcentreboard
> Eric O'Higgins
That sounds like an improvement. It would be a good idea to fax a
sketch of it to Phil Bolger. In my experience, he will promptly look
at it and declare it an improvement, (or not). I suggest you do this
because he might be able to identify some unintended consequence of
the change that might not be obvious.
I sent him a list of a handful of changes I had made, (or was
considering) to his Micro Navigator design and he replied back in
detail saying that he considered about half to be good ideas, and
about half not.
I'm about to commit myself on the question of mast position in my Birdwatcher II and would
like to put the mast step in line with the end of the offcentreboard to lessen the moment arm
The designed gate at the partners doesn't look like a good mechanical solution (in addition
to being fussy). If the board and the step are in line, I'll be able to put a metal fitting under
the deck and hold the mast in place using clips like a ski boot, or even just bolts extending
through the coaming with the nuts on the side, of course. I anticipate being able to reduce
Eric O'Higgins
