[bolger] Re: Doug Fir ply and connecting them
Brad:
I have had exactly this experience many times. It is amazing how much wood
products vary from batch to batch. I will go from one yard to the next to
see who has the best of whatever I am looking for. The price does not vary
nearly as much as the quality.
> Thanks for those of you who have put out there your experience in
> glassing panels together rather than scarfing. My wife and I, in two
> hours taped the whole bottom of the topaz up this afernoon. This is
> doing both sides at the same time. We planed down the edge so the
> glass was flush, layed the glass in, turned the panels over and butted
> them very neatly on scrap ply and plastic. Then glassed the top seam
> and screwed the joint down tightly to the ply underneath. Very fast
> and neat and done in no time. Just required a little prep and
> pre-planning.
> For those who are lucky, there is a new twist at least from my vantage
> point in ply. At a local lumber yard I was loading out the required
> 1/2 " ply which was very good doug fir. After 4 sheets we got into
> what looked like a completely different wood. This had a perfect
> hardwood final veneer that looked similar to luan. The rest was doug
> fir with only 2 or three voids out of the whole 6 sheets, better than
> most marine ply I have seen. The bottom and sides of the boat if I
> continue to use this wood, will as smooth as a baby's butt. Nice stuff
> you might look for. By the way, I unloaded the first four sheets and
> replaced then with the new stock. Brad
pre-planning.
pre-planning.
