Re: Completed Fast Brick
> > As you know there isn't
> > any sealant that will stick well to the UHMW.
> Somehow the people that make skis and snowboards find a way to adhere
> UHMW to wood and plastic. I thing that McMaster Carr sells UHMW sheet
> preprepared with adhesive, peel-off.
Yes I am aware of the stick on UHMW, this place seems to specialize in
it:http://www.crownplastics.com/
I did get my UHMW from Mcmaster Carr, a great resource. I thought about
the stick on kind but I was reluctant to attach it permanantly to the
hull or rather I didn't want to make a permanant attachment without a
good reason to and I don't see any problems with having it "floating".
I guess time will tell, I wouldn't want to have the plastic bend out
from water pressure. I hope to get the boat in the water soon
I have been told by a plastics supplier that you can clean and then
heat the UHMW surface with a propane torch lightly. Then the plastic
will have some ability to work with a sealant. I use the same method to
epoxy glue in PVC pipe in places like the stopper knot holes in the
leeboard.
fritz
Jon, The UHMW is not attached other than the bolt holding the
leeboard. I am considering putting a small screw somewhere through
the plastic into solid wood just to keep it from rotating, though it
doesn't move now when moving the leeboard. As you know there isn't
any sealant that will stick well to the UHMW. I think the important
thing is to just keep it from rotating as I would rather have any
wear take place on the leeboard, not the hull.
fritz
> Great job on your FastBrick! Everything looks really first rate
> well executed, and I especially like the pump idea. May I ask how
you
> attached the UHMW to the hull?
> Jon Kolb
>http://www.kolbsadventures.com/boatbuilding_index.htm
Hi Fritz,
> I have added some photos to my website of my completed Fast Brick.
> www.thegreatsea.com/FastB.html
Great job on your FastBrick! Everything looks really first rate and
well executed, and I especially like the pump idea. May I ask how you
Jon Kolb
I must second that "Awesome". Every detail of the boat including the
bilge pump, rudder, flotation, low maintenance, ruggedness, strength,
positive floatation is well thought out and executed perfectly.
On Sun, 05 Feb 2006 05:32:26 -0000 "Stefan Probst"
<stefan.probst@opticom.v-nam.net> writes:
> Awesome.
> Congratulations to a picture perfect boat and picture perfect
> pictures!
> Can't wait to hear performance reports.
> Cheers,
> Stefan
> not a bit envious. ;)
> dead horses
> posts
> Fax: (978) 282-1349
Awesome.
Congratulations to a picture perfect boat and picture perfect pictures!
Stefan
<http://thegreatsea.homestead.com/FastB.html>
> fritz
fritz
