Re: [bolger] Re: A few photos posted
There are many things in the files (vault) beside photos, and many of the
items are store in folders. Click on the folder to open it and then click
on each item in the folder to view it. Use the back command of your browser
to go back to look at more items in the folder. I hope this helps
Michael Surface
Get Your Private, Free E-mail from MSN Hotmail athttp://www.hotmail.com
Michael Surface
>From: "Paul Lefebvre" <paul@...>________________________________________________________________________
>Reply-To:bolger@egroups.com
>Subject: [bolger] Re: A few photos posted
>Date: Thu, 01 Jun 2000 17:45:31 -0000
>I'm new to the group - can someone please tell me where I can see
>the 'vault' photos? I've looked in the main group page under 'Files'
>but do not see the photos you guys seem to be talking about. What am
>I missing?
found 'em! Thanks, Dave.
Paul
Paul Lefebvre
paul@...http://www.whrc.org
Paul
Paul Lefebvre
> -----Original Message-----
> From: David Jost [mailto:djost@...]
> Sent: Wednesday, May 31, 2000 12:41 PM
> Yes,
> Our times are similar if I take your lack of a table saw into
> consideration. I have a portable table saw (Delta) that does about
> 80%
> of the work. I also figured out that 1 1/2 inch finish nails really
> speed up the work by holding the framing pieces in place whil the
> bronze nails are driven from the plywood side. I would say that
> between these two items, I have saved about 2 hours per frame over
> your
> times. Frames C and D are relatively easy and I constructed both in
> about 3 hours!
> The transom has slowed me down as it took me a while to find out
> how the motor clamp was supposed to be installed. Look on the
> profile
> plan for the inside framing set up on the transom.
> David Jost
> Hot off the press- summer's here!
> School's out and it's sizzling hot. Whether you're planning a
> graduation party, a summer brunch, or simple birthday party,
> shop GreatEntertaining.com before your next celebration.
>http://click.egroups.com/1/4473/10/_/3457/_/959791282/
I missing?
I missing?
Yes,
80%
your
about 3 hours!
profile
80%
your
about 3 hours!
profile
Ciao David
actually I spent about two hours in shaping that *°@%& cabin roof
beam, so I think you took the right decision. My boat's CG will be
lower though... ;-)
What about the building times: do mine match with yours or am I too
slow? I suspect that if I had more elbow room and a few more power
tools (a table saw for instance) I could cut my working time in
half...
Best
Pippo
lower though... ;-)
half...
Best
Pippo
--- Inbolger@egroups.com, "David Jost" <djost@m...> wrote:
> Pippo,
> I just finished looking at your bulkheads and am impressed by
> scribing of the deck beams. I just picked out wider stock
> and drew the camber on the top edge and left the bottom straight.
I
> don't see how it will interfere with anything. I just built
> frame c and d, and cut out a rough draft of the transom this
weekend.
> I hope to have pictures of all the frames by next
> weekend.
> Ciao,
> David Jost , builder of the Micro "Firefly"
Pippo,
I just finished looking at your bulkheads and am impressed by the
and drew the camber on the top edge and left the bottom straight. I
frame c and d, and cut out a rough draft of the transom this weekend.
weekend.
Ciao,
weekend.
Ciao,
Dear all - I've posted a few photos showing the butt block tests
and the finished bow transom and bulkhead A in their respective pages.
I expect to be wacking back starting next sunday (last wife's exam
due by next Saturday).
Best, Pippo
Best, Pippo
