Re: Low Power for Diablo?
--- Inbolger@yahoogroups.com, Máximo <grupos@...> wrote:
> Jon, I have tested Diablo (a heavy one, with bottoms and frames of
18mm
> instead of 10mm) with an old Honda B100L 10 hp 4t, you can see some
photos:
>http://www.promax.com.ar/diablo/diablo08.htm
> With one person (100 kg) maximum speed was 12 knots. Regards, Máximo.
Hey Maximo:-)
Whenever I look at your website it creates a lot of smiles and
feelings of warmth inside.
Not sure if the people or the dogs are having the most fun building
Bolger boats!
My father started with a ten hp 4 stroke Honda on his first Diablo. I
thought it went fine. He replaced it with a 15 hp I think, which he said was
much better. But he was using it as his primary form of transport to the
nearest road to his house, which is about 20 kilometers away.
Stuart Crawford.
> From: adventures_in_astrophotography <jon@...>
> Reply-To:bolger@yahoogroups.com
> Date: Fri, 10 Mar 2006 14:52:06 +0000
> Subject: [bolger] Low Power for Diablo?
> The motor I'm planning to use on my FastBrick is a 9.9 hp high-thrust 4-
> stroke. These are pretty expensive. PCB calls for up to 25 hp on
> Diablo, but I'd like to try using the 9.9 on that hull first, and avoid
> buying another expensive motor just to go fishing. I could also go
> fishing in FastBrick, but I wasn't planning to build or buy a trailer
> for it, since it's supposed to be the tender for our eventual cruiser.
> Has anyone tried lower power motors on Diablo? If so, how did it work
> for you?
> Jon Kolb
>http://www.kolbsadventures.com/boatbuilding_index.htm
> PS: FastBrick (Stargazer) and Diablo (Hypoxia) are both in paint stage
> as of this weekend!
> (978) 282-1349
Aha! I actually have tried this trick.
With a 9.9 2cycle Johnson, it will plane with two 180 lb men on board.
With a 9.9 4cycle Honda, it won't plane with two 180 lb men on board.
The boat still planes with the two cycle engine with 1 dad, two kids,
and a black lab.
Happy boating.
"still pouring over the BW II plans, I can't believe how cool this
boat is. Form and function for every square inch"
Hi Maximo
18mm
photos:
Thanks! That's what I needed to know.
Jon Kolb
Jon, I have tested Diablo (a heavy one, with bottoms and frames of 18mm
instead of 10mm) with an old Honda B100L 10 hp 4t, you can see some photos:
for you?
Jon Kolb
as of this weekend!
