Re: Bolger Chinese Gaff Rig
I suggest you insert 'chinese gaff' in the search box above, and you
will find more information,
Don
http://oink.kiwiwebhost.biz/
--- Inbolger@yahoogroups.com, "Rollin dalPiaz" <sailyonder@...> wrote:
> I am interested in reading first person non-fiction experience about
> the handling of the Bolger Chinese Gaff Rig on various points of sail.
> Phil and Suzanne specified the rig for Yonder because nearby cruising
> waters here in Southcentral Alaska are summer light wind bays and
> sounds. Therefore we agreed on a fine, large sail plan. I prefer to
> reef when necessary. Plus all the positive attributes of the rig cited
> by them in the Messing About In Boats articles of 05/01, 05/15 and
> 06/01/2003 issues.
> I do like the look of the sail plan very much. How has it worked for
> you on your craft? Rollin dalPiaz
I confess that I haven't had my Chinese Gaff rig out sailing enough to
say that I am an seasoned expert, but my first hand impression is that
it sails as advertised. Even without the tapering of the battens to
achieve foil shape, [and with my polytarp/duct tape rough cut sail
cloth] it makes way to windward, acceptable to me at least. The cat
yawl rig is much different to the sloop rig, and I very much like the
versitility. The only complaint I have with all the lines, lifts,
sheets and halyards is that initial setup takes some time, a pain for
trailer sailing. Once set up, the benifits are that you have very
fine ability to adjust everything, and that essentially every
individual line shares a low amount to total tension. The ability to
fly a lot of sail area when the wind is light, and to calmly and
quickly reef (or unreef) from inside the cabin whenever you have the
urge, is a drastic improvement from the white knuckle reefing drills I
know from sailing a sloop. Indeed, my building of a Bolger Micro
Navigator was a small scale test of the rig because, as you know, I
have serious dreams, bordering on solid intentions to build a Yonder.
06/01/2003 issues.
