Re: [bolger] Increasing beam only on the larger ASharpies
On 3/27/06, goadarama <goadarama@...> wrote:
> On PBolgers AS39 and the 45' Weston Martyr does anyone see anything
> wrong with merely increasing the beam numbers on the table of offsets
> by say 10% to 20% while keeping everything else the same?
Basically anything that looks like a boat *is* a boat. Starting a design
from a base point of another design, known to be a good design,
is an old old trick.
> ...merely...
Merely, is a reach, considering that one of the biggest advantage
of using a set of plans from Bolger, [and others] is that you get
the dimensions of the expanded panels, frames, etc. already worked
out for you. Changing the beam would invalidate essentially all
of the precalculated dimensions on the plans.
by say 10% to 20% while keeping everything else the same? In other
words the same sweep from bow to stern but just a bit farther out
(wider?). We love his WMartyr design but it is a bit too skinny and
would be nice at 8' instead of 6'9".
