Re: [bolger] Spray equipment for Latex?
I have a power painter and have used it on a lot of home projects. It works
well with both oils and letex based paints and can give a nice finish if you
are carefull. If you get to close, or move the sprayer too slow you can get
runs. Sense a lot of the boats are painted in letex exterior house paints I
can not see why this would not work. I have not used it on a boat but was
thinking about it (boat is still in large sheets of plywood state :)
Michael Surface
>From:glen_gibson@...
>Reply-To:bolger@egroups.com
>Subject: [bolger] Spray equipment for Latex?
>Date: Thu, 1 Jun 2000 14:29:18 -0700
>While I'm not looking to build a showroom finish Micro, I'm also not too
>interested in one with brush marks or roller stipple on it, either. So I
>was
>wondering: Does anyone have any suggestions to low cost spray paint
>systems,
>such as Wagner Power Painters or low cost HVLP systems, either compressor
>driven
>or turbine driven? I'm planning on using good old exterior latex
>housepaint on
>my Micro. I can amortize the cost over some other planned home improvement
>projects ;-)
>Thanks!
>Glen
>"Paul A. Lefebvre, Jr." <paul@...> on 06/01/2000 02:25:30 PM
>Please respond tobolger@egroups.com
>Sent by: "Paul A. Lefebvre, Jr." <paul@...>
>cc: (Glen Gibson/HQ/3Com)
>Subject: RE: [bolger] Re: A few photos posted
>found 'em! Thanks, Dave.
>Paul
>Paul Lefebvre
>paul@...http://www.whrc.org
> > From: David Jost [mailto:djost@...]
> > Sent: Wednesday, May 31, 2000 12:41 PM
> > Subject: [bolger] Re: A few photos posted
> > Yes,
> > Our times are similar if I take your lack of a table saw into
> > consideration. I have a portable table saw (Delta) that does about
> > 80%
> > of the work. I also figured out that 1 1/2 inch finish nails really
> > speed up the work by holding the framing pieces in place whil the
> > bronze nails are driven from the plywood side. I would say that
> > between these two items, I have saved about 2 hours per frame over
> > your
> > times. Frames C and D are relatively easy and I constructed both in
> > about 3 hours!
> > The transom has slowed me down as it took me a while to find out
> > how the motor clamp was supposed to be installed. Look on the
> > profile
> > plan for the inside framing set up on the transom.
> > David Jost
> > Hot off the press- summer's here!
> > School's out and it's sizzling hot. Whether you're planning a
> > graduation party, a summer brunch, or simple birthday party,
> > shop GreatEntertaining.com before your next celebration.
> >http://click.egroups.com/1/4473/10/_/3457/_/959791282/
>Accurate impartial advice on everything from laptops to table saws.
>http://click.egroups.com/1/4634/10/_/3457/_/959894200/
Get Your Private, Free E-mail from MSN Hotmail athttp://www.hotmail.com
I was
systems,
compressor driven
housepaint on
improvement
> > projects ;-)
Many paint stores rent good airless spray rigs if you buy the paint from
them. Here
it is 40 bucks a day. They are a lot better than the Wagner and other
consumer
spray guns. They do expect you to clean it up when you are done. If you are
using
water based paint that's not a big problem.
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
I sprayed lacquer finishes on musical instruments I built for 15 years. So I'm
familiar with professional equipment.
However, I found one of the less expensive Wagners work fairly well for latex. I
first borrowed one from a neighbor then got one at a garage sale for $20 but I think
they sell for about $60 to $100 bucks depending on features. I used the quart
hopper, but it has feed tubes for larger jobs. After using a foam roller on my first
boat, it was a pleasure spraying frames and bulkheads. It ain't devilbis but it
ain't bad.
Tip. One of the pains in the ass is all it takes to dismantle and clean the
gizmo. I've found you can unscrew the spray head, rinse it and then place a piece of
plastic (grocery bag type) over the nozzle and screw it back on. You can then leave
it as long as overnight and still have it spray fine.
> interested in one with brush marks or roller stipple on it, either. So I was
> wondering: Does anyone have any suggestions to low cost spray paint systems,
> such as Wagner Power Painters or low cost HVLP systems, either compressor driven
> or turbine driven? I'm planning on using good old exterior latex housepaint on
> projects ;-)
> Thanks!
> Glen
> Paul
> Paul Lefebvre
> > Yes,
> > 80%
> > your
> > about 3 hours!
> > profile
> > David Jost
>http://click.egroups.com/1/4634/10/_/3457/_/959895018/
SOME CLICKS THAT COUNT!!
Feed someone.
http://www.thehungersite.com/
Save a little rain forest.
Here's my latest boat:
http://unicornstrings.com
rent an airless power sprayer from your local rental center.
To: <bolger@egroups.com>
Sent: Thursday, June 01, 2000 4:29 PM
was
systems,
driven
housepaint on
improvement
> projects ;-)
> Thanks!
> Glen
> Paul
> Paul Lefebvre
> > Yes,
> > 80%
> > your
> > about 3 hours!
> > profile
> > David Jost
