Re: [bolger] Re: slightly OT, epoxy weathering tricks?
It won't be Plexiglass or equivalent. The UV comes thru that as if it
weren't there.
> Yes. I wonder if there's some kind of plastic sheet found around
> household that filters UV, sticks with epoxy, and is durable? I'd
> guess not. I'd rather not varnish, turns yellow and would get in the
> way of the next epoxy job.
> --- Inbolger@yahoogroups.com, "derbyrm" <derbyrm@...> wrote:
>> Maybe put a UV blocker on top??? (but you knew that)
>> Roger
>> derbyrm@...
>> From: "Lincoln Ross" <lincolnr@...>
>> >I am repairing a sign which is very light glass over paper, mounted on
>> > G10. Over the course of several years, the epoxy has just kind of
>> > disappeared, along with some of the glass. Any suggestions on how to
>> > make the new epoxy weather better? Prefer not to get into extended,
>> > multi coat operations. In that case, it's easier just to do it again
>> > when it gets bad again. Thanks
> horses
> (978) 282-1349
> Roger
> derbyrm@...
