Re: Scaled up Tennessee
First, I'd fax/write PB&F direct using the contact info below and
ask their advice for a design.
A diesel inboard is NOT easily adapted to an existing light outboard
design. A box keel such as suggested in a previous post works
nicely but must be well designed to work.
Non-Bolger boats that may work for you are in the Redwing series.
http://www.cmdboats.com/rw26.htm?
cart_id=1ba3a028926ee0c03f55a264b795a5b2
You'll have to piece together the broken link above.
--- Inbolger@yahoogroups.com, "edrapela@..." <edrapela@...> wrote:
> Bolger uses something similar in the Alaskan cargo vessel as well
as the
> Diesel launch. Both can be studied on the Bolger Cartoon site.
> Cheers,
> Ed
01930, Fax:
> (978) 282-1349
I too have seen the Aussie versions of Tennessee; especially the srticle in
Wooden Boat. They seemed to have the inboard issue covered in that they
added the centerline "nacelle" and tapered the aft end to a point from
which the shaft exited. Quite neat in that the shaft was almost certainly
parrallel to the WL. While they used battary and electric motor, I'm sure
that the net weight of the propulsion would equate to some of the new light
weight diesels.
Bolger uses something similar in the Alaskan cargo vessel as well as the
Ed
Original Message:
Date: Sun, 23 Apr 2006 01:37:42 -0000
Subject: [bolger] Scaled up Tennessee
I particularly like some of the Australian Tennessee builds. Trouble
is, the design is just a little too small and I want to use an inboard
diesel that weighs 550lbs.
What is the next size up from the Tennessee and would it adapt well to
an inboard?
Doug
horses
(978) 282-1349
mail2web - Check your email from the web at
http://mail2web.com/.
weight diesels.
Ed
Original Message:
an inboard?
Doug
horses
(978) 282-1349
an inboard?
Doug
an inboard?
Doug
