SV: [bolger] WDJ fine tuning
Bill,
That is interesting. I have wondered if the lacking vang of the main boom will have a negative effect. I hadn't thought of the possibility that the weight of the boom will have a vanging effect. It will be interesting to see if the weight of my hollow boom will be sufficient...
I will most certainly try to add outhauls on the boom ends. I have allready cut the boards. Are the booms long enough to give room for a strap, shackle and a block on the end?
What kind of vang did you install? Wire as per plan or a commercial purchase?
Bjorn
