Re: [bolger] Re: Oldshoe with cabin - Gnushoe
Hi Graeme
Yeah, this boyancy and stability thing can certainly get more complex the
longer one things about it no doubt. Certainly needs alot of work for sure.
Fortunately, when push comes to shove, the WAY I would use such a beast, I
would be pretty safe as long as the darn thing stayed together and
floated.....upright but low in the water or on its side or even up side down....any of
those would be tolerable for me....so my requirements are not as demanding as
some...
Now, if your cruising is more "serious" then yeah, get the stability and
orientation issues worked out much better....
Something did occur to me today thinking about such things.....if your cabin
is fairly assymetric and depending on how much air it holds or how intact it
is or how much foam you have in the walls/ceiling of the cabin and where it
is and how much flotation
you have on the "non-cabin" side, the assymetric cabin may offer another
advantage. It may ONLY be stable upright....or in other words you turn it upside
down and the cabin flotation flips it upright again...and even if it doesn't,
it may provide enough "help" to make using your own body weight to "un
turtle" the beast easier ....
So, such a cabin may make a rollover just that....always a rollover and
never a turtle situation....of course the cabin would probably make a rollover
more probable.....but if it meant it could never turtle......thats a trade off
I'd happily live with.
take care
Blll
In a message dated 6/2/2006 11:03:54 PM Central Daylight Time,
graeme19121984@...writes:
There is probably a lot of positive bouyancy here if you do this,
but carefully calculate your new centres of gravity and bouyancy,
righting arms and so on for various circumstances. The foam weighs
something, obviously, and so the hull COG has been lowered, which
may add to performance when upright, but the capsised COB has been
brought closer to the floor too. In fact they may be almost
superimposed. Worse, with the weight of the other stuff in the boat
contributing, on her beam ends the COG may actually be above the
flooded COB ( relative to the floor of course). If masts are
shipped, their bouyancy may prevent inversion, but the boat may not
self right. If it turns turtle it may be in the most stable
position :( or, depending on sea state, it may only be rescued with
some effort.
Calculation may show it's alright, but off the top of my head I
can't think of anywhere Bolger shows flotation right down low. If it
doesn't go from bilge to deck like in the quarters or bows perhaps,
then it is shown chocked up against the deck underside right off the
floor so when flooded the boat ought to sit stable in the correct
orientation without manhandling to get it that way. It wont easily
be tipped over by wave action before it is bailed out. I thought he
put the foam off the floor to discourage rot and to allow space for
things like oars or legs to be poked under there. Suttle.
--- Inbolger@yahoogroups.com, BllFs6@... wrote:
>, but I think it may meet all Common Sense Criteria including
>#5: "...They don't exist because they are fashionable or
>character boats."
> So what you are trying to say diplomatically is that if form
>follows function then my design would be amazingly functional given
>its amazingly bad looks :)
No not really. I don't know that it would look bad. Just that it
does't have to slavishly follow conventional dictates about how a
boat is supposed to look to be a good boat.
> My sketch is LESS? beamy than the real Oldshoe.
My mistake. I eyeballed it again - and counted grid squares ;-) and
your sketch seems ok .
>I realize pretty much everything interior to the hull shell would
>be different and have to be engineered by me, myself and I.
Some of those things might be serving more than one function. PCB
can be quite suttle in this. PCB assigns a number to a design after
the offsets are calculated. Old Shoe is #449. PCB&F would probably
supply the offsets so you could completely change the internals and
keep exactly the same hull form, however the replacement internals
would need to satisfy the structural and other demands. I'm sure you
know more about that engineering stuff than I - just thought I'd
better mention it though :)
> SOLAS...
>Imagine looking at Oldshoe from a side profile. The bottom of the
>hull is a curved surface that "dips" down about 6 inches IIRC in
>the center in relation to the bow and stern. Now the cabin floor
>needs to be flat, and I would prefer that the footwell be flat and
>above the external water as well because I want it to seriously
>self draining. If you use foam topped by thin flat plywood panels,
>you've put a fair thickness of foam over a large number of square
>feet. I did a back of the envelope calc awhile back and though I
>dont recall the amount of bouyancy you get out of it, it was at
>least decent IIRC. Now this DOES eat into cabin height and
>footwell depth, but how badly and at what costs to other
>considerations I do not know.
some effort.
>calculations as to what/when/where/ how stable she is seriously
>flooded under different scenarios. I do think its doable, but then
>again it certainly isnt something you'd wanna just eyeball, wing it
>and hope for the best either.
>...time for more boxes, rulers, and sketches me thinks....
It's doable. Just gotta get out all the wrinkles.
> I am suprised that an assymetric cabin seems to be a fairly novel
>idea. I can see myself being admonished by Bolger now. "Listen
>young man....form may follow function but one must learn to
>control oneself" :) I am kinda itchy to try the layout on a
>Micro.....might be able to get a...
I'm sure Mr Bolger would have no trouble with assymetry per se.
You'd know you were going too far here though, if he mentioned
zealotry. ;-)
Cheers
--- Inbolger@yahoogroups.com, Kenneth Grome <bagacayboatworks@...>
>If I were to build one for myself, the most I would want in a cabin
>is the cuddy shown in this photo, which is really no more than a
>locker for secure/dry storage:
>http://ph.groups.yahoo.com/group/bolger6/photos/view/efcb?b=6
Kenneth,
This cuddy may be large enough for children to shelter in from a
downpour, and on calmer days when there would be little danger of
flooding through the hatchway they might like to stay in there :-)
Alternativeley, if the hatch acccess were not through the bulkhead
as pictured, but was a hatch in the raised deck shown, then there
might be just sufficient privacy for porta-potti use within. I guess
the hatch coaming might be chest high when sitting within. PCB has
drawn a few heads in the bow with the occupiers head and shoulders
protruding above deck. It would require a bit of agility in stepping
from the cockpit seat, up, over, and down into the hatch, but the
concession to some privacy might remove a bigger obstacle to some
peoples' crewing.
Cheers
--- Inbolger@yahoogroups.com, "John and Kathy Trussell"
<jtrussell2@...> wrote:
> An approach which has fairly obvious parallels is PCB's Super Mouse
found in BWAOM.
Bolger had this to say in a recent MAIB article regarding Oldshoe.
"The design is an obvious candidate for a Birdwatcher top, perhaps a
removeable one to use in appropriate weather. That would make one
heavy-weather capable indeed, they're stiff as designed, with the
200lb of outside ballast giving a reassuring range of stability."
An approach which has fairly obvious parallels is PCB's Super Mouse found in BWAOM.
John T
Sent: Friday, June 02, 2006 11:28 AM
Subject: Re: [bolger] Re: Oldshoe with cabin - Gnushoe
In a message dated 6/1/2006 11:51:31 PM Central Daylight Time,
bagacayboatworks@...writes:
Hi Bill,
The attraction of OldShoe (for me anyways) is the fact that it's an open
boat with high sides, so people can move around in it with relative ease, yet
without much risk of "falling overboard". If I were to build one for myself,
the most I would want in a cabin is the cuddy shown in this photo, which is
really no more than a locker for secure/dry storage:
By the way, using a custom canvas tent on a boat like OldShoe may be better
than anyone's idea of putting a cabin on it. A tent lets you have an open
boat when you want one, and a protected shelter at other times.
Kenneth Grome
Bagacay Boatworks
Hi Kenneth....
Those are valid points I will readily concede under certain conditions.
However, if you read my replies to Graeme and Peter about these same points,
you'll see that I feel there are conditions under which the fixed cabin offers
advantages (though not without its costs either). Of course I could be all wet
so to speak and any percieved advantages are overwhelmed by real
disadvantages.
thanks for the input!
take care
Blll
SPONSORED LINKS Phil bolger Bolger Bolger center
YAHOO! GROUPS LINKS
a.. Visit your group "bolger" on the web.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.8.1/354 - Release Date: 6/1/2006
Hi Bill,
Kenneth Grome
Bagacay Boatworks
Hi Kenneth....
disadvantages.
take care
Blll
In a message dated 6/2/2006 12:09:39 AM Central Daylight Time,
Hi Bill,
your sketch is pretty much what I had from your decription. Perhaps
only use would determine how much sense, but I think it may meet all
Common Sense Criteria including #5: "...They don't exist because
they are fashionable or character boats."
So what you are trying to say diplomatically is that if form follows
function then my design would be amazingly functional given its amazingly bad looks
:) Hey, in a millionaire marina when you have a tiny boat....any publicity
is good publicity! My other dream project is still to build John Welsfords?
Nano Shanty, making it look as much like a floating run down poor white trash
trialer with a few chickens on top and anchoring next a fancy marina for a
weekend. I'd also have to get up speed on how to properly chew and spit chewing
tobaccee for this to have maximum effect. And I think I could manage to
strap a mini keg and a tire rim on there somewhere as well.
You have really approached this design problem of having a small
sleeper cabin for one, day sailing accomodation and shelter for
more in a very original manner. Very intriguing. Great going.
Overall, I think it a good innovative solution for the type of
sailing you intend, but I do have some reservations you may wish to
consider.
Thank you very much for the compliment, though I had my inspirations. First,
obviously Bolgers trend of thinking outa the box and letting form follow
function, as well as the Oldshoe design itself. Also, all these designs on the
internet of micro cruisers gets one to thinking of what you need cabin wise if
all it is to be used for is sleeping. And other designers out there with
design features not found on your common commerical boats.
Your sketch is a little different in proportion to the Old Shoe
l ines, being relatively less beamy with a wider bow transom. This
may not matter much, but there isn't much space anyway and every bit
may count when it comes to actual measuring to accomodate real
bodies.
My sketch is LESS? beamy than the real Oldshoe. I drew it with a 5 foot
beam, a 1.5 foot bow, and a 3 foot wide transom. Does anybody have the real
measurements for the bow and transom? And perhaps a few more measurements across
the hull so I could get the plan view shape of the hull correct? Dont worry,
not trying to backwards engineer Old Shoe, when and if this project ever goes
forward I will be buying a set of Oldshoe plans.
Re-positioning a bulkhead or frame that is left in in your
plan will make for extra building work - a newly measured and extra
component will have to be made.
Yes, I realize pretty much everything interior to the hull shell would be
different and have to be engineered by me, myself and I. We dont mind that at
all, but then again it could get ugly and we might never speak to ourselves
again.
SOLAS. The Old Shoe as designed has great reserves of safety. The
hold makes for a large bouyancy chamber, however, if it is
compromised, then the under seat foam filled chambers will still
float her very high. Most water will quickly run out the aft
scupper, and bucketing of the footwell only will be required. The
top of the footwell will be higher than the external water.
Imagine looking at Oldshoe from a side profile. The bottom of the hull is a
curved surface that "dips" down about 6 inches IIRC in the center in relation
to the bow and stern. Now the cabin floor needs to be flat, and I would
prefer that the footwell be flat and above the external water as well because I
want it to seriously self draining. If you use foam topped by thin flat
plywood panels, you've put a fair thickness of foam over a large number of square
feet. I did a back of the envelope calc awhile back and though I dont recall
the amount of bouyancy you get out of it, it was at least decent IIRC. Now
this DOES eat into cabin height and footwell depth, but how badly and at what
costs to other considerations I do not know.
That is 200 lbs of lead she has under her, and circumstances could
arise
without adequate flotation in which she would rapidly sink from
under you.
No doubt about that.....at the very least the design will have to float the
lead, any attached heavy stuff like the anchor, motor, battery, and a certain
amount of the structure itself above water. I think that is doable. Now HOW
high, dry, and stable this can be after after things have obviously gone bad
is the question. In my neck of the woods, with the geography, warm water,
sandy beachs, and the type of sailing I am likely to do, if you can keep a good
fraction of your body outa the water things probably wont turn out too bad.
In your variation I feel, like Bolger with the storage
hold, that you cannot rely on the bouyancy of the cabin volume to
save you - Murphy's law and all that, the cover may not be on when
you need it, or this is where the hull may be holed.
I agree with you there too. Any stuff stored in the cabin like the sleeping
bag, padding extra clothing etc etc would be stored in "waterproof"
containers/bags and secured if at all possible. This keeps stuff dry (duh), may
provide helpful floation, and at least doesnt ADD unwanted "sinking forces" if
large amounts of water end up in the cabin due to hulling or add weight should
alot of water enter, then leave the cabin, thereby leaving lots of soggy heavy
wet stuff behind.
The storage
compartments you show detract from flotation volume as may the under
seat utility areas (PCB writes a bit on all this when discussing the
Japanese Beachcruiser in BWAOM ).
True. I wound do my best to make under the seat storage relatively water
tight. I would also try to insure that they are least unlikely to accidently
open up. Then also store everything in containers (say tupperware of different
sizes and shapes). And also even if not much is stored in there, the storage
area is still filled with empty watertight containers.That way if storage
area itself is not watertight for prolonged emmersion, you are still getting a
decent fraction of the bouyancy you would get if the whole thing was just
filled with foam.
If they are dedicated to
flotation, then, in addition to the question of the quantity and
spatial relationship needed to ensure floating high enough upright
in level trim (in all circumstances) there arises a new problem of
where now to store things if not here? If the small cabin is used
for storage you may be back to square one, but if a bit of
inconvenience can be tolerated then this may suffice. I'm still not
sure if she may float with dangerously too much heel, even if only
the offset footwell is flooded?
The above safety considerations may be able to be met. It may be
difficult, I don't know enough to say. If you keep on with such a
creative approach I bet you could arrive at a satisfactory
arrangement. However, if she is not to be taken far offshore, into
rough water, or away from ready help then the SOLAS concerns are
mostly irrelevent, and then for the type of use you mentioned such
as....
Yes, at some point I'd have to stop hand waving and do some serious
calculations as to what/when/where/ how stable she is seriously flooded under
different scenarios. I do think its doable, but then again it certainly isnt
something you'd wanna just eyeball, wing it and hope for the best either.
" the versatility and utility of this layout may well amaze. Some
may complain they couldn't sleep in such a tight cabin owing to
claustrophobia, but I don't think all that many people get
claustrophobia. Many like a feeling of "snug". Especially if warm
and dry.
Well, if you are claustrophobic you are outa luck for sure. Not a problem
for me. The main measure for me is can I turn over, lay on my side, lay in a
fetal position without knee's hitting the wall and hopefully at least mostly
sit up somewhere? From my "floor plan" and some laying in closets recently, its
looks like the answer is a conditional yes.
I'd say the that my design still might not be bad for someone who doesnt
like cramped spaces. As drawn you still have as much if not more "floorspace"
outside the cabin as inside. That person just has to set up a tent to sleep in.
So the boat can still sleep 2, just that its gotta be a snug as a bug in a
rug type and a wide open spaces type. It just cant accomodate 2 wide open
spaces types. And if sailed by a wide open spaces type the cabin still provides a
few advantages. Quick place to duck in short term for say the pop up
thunderstorm or a quick bit of shade, or a place to warm up/change clothes if its
cold/windy/wet....The cabin is also a better storage space for bulky though
preferably not too heavy stuff. And finally, should things get really bad, its a
much better place to batten down the hatches and hold on for dear life than
in an open cockpit or tent!
Will there be comfortable seating on the aft seats? The bottom rises
markedly owing to its large curvature and the hull is not very deep
back aft. If the sides are still to provide a seatback then an adult
may have to sit with their legs tucked up? This might be
uncomfortable after a lengthy period at the helm. This is my main
concern about the aft-cockpit, decked, "Danidoo" type.
Yes, that would certainly need some looking into. You might be able to put
in some railing (since you would need very little) instead of raising the hull
sides if it turned out you had to raise the seat hieght to maintain decent
footwell depth and still wanted that not gonna fall backwards outa the boat
feeling. But I "think" you could give up a bit on footwell depth and a bit on
backrest height and still have a workable solution...time for more boxes,
To summarise at this point: your idea seems to have the advantages
sought from a fixed structure (however a tent is also versatile);
SOLAS is a concern ( but may be met, or irrelevant); the effects of
an apprehended athwartships assymetry may amount to advantage
(concerns may not be real, or may be addressed {aircraft carriers
once looked lob-sided and, many commercial craft do, form following
function very "Bolger"}).
Fair synopsis there. Don't get me wrong here. I dont think this is better
than Oldshoe in every respect. You do give up alot. Simplity of
design/construction. Costs. Proven track record. Probably some load carrying ability.
Probably some flooded stability. The ability to easily carry 4 or more folks. And
probably some other stuff that isnt obvious either at the moment or until you
try both versions out.
But I do think it you mostly gonna camp/cruise by your self or just daysail
with 3 total adults (and maybe one little kid) or 2 adults and and 2 possibly
3 little kids that the cabin does offer advantages that could be worth the
loss of some of the attributes of the orginal Oldshoe.
Again, thanks for the comments and input!
I am suprised that an assymetric cabin seems to be a fairly novel idea.
I can see myself being admonished by Bolger now. "Listen young man....form
may follow function but one must learn to control oneself" :)
I am kinda itchy to try the layout on a Micro.....might be able to get a
dedicated head and a nice sized one person cabin that way and still have a fair
bit of uptop space.....
A dedicated head.....THATS hows ya gets the women folk when it comes to
sailing! Well, that and sailing with a cute little dog with a doggy life jacket
on.
take care all
Blll
Hi Peter
Thanks much for the thoughtful response.
But now its fightn time! :0 Just kidding!
Hi B111
Yes I did recieve the (BIG!)sketch :-) and a big thank you to
Graeme for re-posting it to the OLD SHOE file!
Well, I guess its good that I didnt send the 14MB file that was scanned at
720dpi!
I applaud your enthusiasm to put a cabin on an OLD SHOE,but then
I saw those wonderful pictures of Joe's gorgeous rendition and it
got me to thinking that maybe,just maybe,you might be trying to get
too much into too small a package.
I tend to think that I am trying to use the given space in a different way
more so than trying add stuff given I am knowingly give up some of Oldshoe's
better virtue's.
Thus my considered response would be to perhaps build her as per
the plans and rig up a cockpit tent or, perhaps more correctly, a
boat tent to provide necessary shelter from the elements and/or
privacy for the head. After a fair seasons worth of actual
use,perhaps your needs will become more concrete and result in two
options:
a) Proceed with adding the required cabin/storage compartments etc
as per your sketches,or
If these were minor or relatively minor tweaks or something that could be
added onto the existing structure I would very much agree, but given that about
the only thing that would be original Oldshoe would be the sails, hull shell,
and keel, I am not sure how much that would help given how different the new
layout would be from the old.
I could use Oldshoe with some kinda tent or removable hardtop sorta thing
and I might find it to be perfectly acceptable.....BUT I would never know how
much better/worse different something like my proposal would be until I tried
it. So I guess I really need to build both versions!
b) Build a bigger and better boat that more closely meets your
experienced based real needs.
Perhaps, but I think I'd get a fair idea of whether Oldshoe was big enough
or not for what I wanted using either model version.
Also, I really like Oldshoe because it seems for me at least to be "Just big
enough". Go up to the Micro say and the mass is ALOT more, mast
significantly harder to manhandle, and the sails cost about 50 percent more IIRC.
Mind you, this is just my opinion and I am aware that with such a
small boat, the modifications you're contemplating will not be all
that costly to execute nor too disasterous to the boats humble over-
all performance.Just make sure you go as light-weight as possible
with any big cabin structures :-)
Yes, that is the good part. If I were to come across some gotcha in
construction or use of my version, it would be more of an "aww crud" rather than
"OHHH NOOO!"
Yes on cabin weight. Fortunately I have enough engineering type experience
to know how to make something strong in ways other than just using
thick/thicker plywood.
In the end, should your proposed modifications fail to attain
your expectations,removing the mods and returning her to her
original state shall not be too much hardship :-)
Well, if my version was a flop for me at least it would be a true
original...a true oddity among oddities...you think an Oldshoe is hard to find.....try
finding a Gnushoe! Heck, I could probably sell it to some mentally unbalanced
Bolgerista for a decent amount because they just gotta try it out :)
Sorry for not being totally able to encourage you any further nor
for even offering up several different modifications to move the
effort forward some.
No problem Peter.
Getting others people opinion always helps in one of two ways...either you
realize the error of your ways and are saved from yourself orrrrrr you get even
more entrenched in thought that your idea is the RIGHT idea, removing any
pesky linger doubts you should have obviously never had in the first place!
This isnt a project so much a alot of thinking and dreaming at this
stage....but maybe this thread will help out others with thier projects, ideas, and
thought processes.
Again thanks.
take care
Blll
> Hi all
> This was started in another thread, so I have pasted the stuff
I've sent
> about it in the other thread together here.
> Peter and Graeme did you get the sketch file I sent you?
Hi B111
Having built and owned a MICRO, I am certainly no stranger to how
seductive these "shapes" can be nor to how they may equally inspire
dozens of custom modifications.Afterall, can you imagine an easier
shape to work with considering their slab-sidedness and all of that
appealing interior volume? :-)
options:
Nevertheless,I do look forward to following your project and hope
that you will get to experience the grand pleasures of
building,launching and using your very own magic carpet ride to
happy adventures!
Peter Lenihan, just another chicken-shit builder who sticks to the
plans and only strays with great trepidation,all the while
fascinated by those who happily blaze their own trails( what guts
that must take!), from along the shores of the mighty
St.Lawrence..........
> Does my layout look ok? make any sense? Would you make some things
>larger and others smaller? and why? I'm sure the layout (besides
>the general concept) could use a lot of tweaking/refining...
Hi Bill,
I'll try as best I can to address some of the implications of your
Old Shoe modification ideas. These are just my initial thoughts and
impressions. I'm not any kind of naval architect, rather, just as
you seem to be, along with many here, I often wonder how a design
might be altered a bit to accomodate some need better. And whether
it would work out!
consider.
lines, being relatively less beamy with a wider bow transom. This
bodies. Re-positioning a bulkhead or frame that is left in in your
top of the footwell will be higher than the external water. That is
200 lbs of lead she has under her, and circumstances could arise
under you.In your variation I feel, like Bolger with the storage
you need it, or this is where the hull may be holed. The storage
Japanese Beachcruiser in BWAOM ). If they are dedicated to
as: "
>IT DOES GIVE up a fair bit of cockpit space over the the original
>oldshoe for daysailing. But 2 easily and probably 3 adults can
>still be "topside". It does have the advantage of having a
>cabin/area that you can securely put one or two little kids in, or
>an area to duck outa the weather for one or 2 adults. You could
>probably get 2 adults, one mid sized kid, and 2 little ones in the
>boat if you kept what you brought aboard to a bare
>minimum... "
>"AGAIN, IN SOME respects its not as good as original oldshoe, but
>it looks to me that it would be a great daysailer that at a
>minimum can sail 2 adults easily, with a cabin for at least one
>adult to duck into in bad weather (around here on the northern
>gulf coast, the weather is typically good and fairly predictable
>except for pop up thunderstorms that typically dont last long), and
>for camping/cruising easily accomodates one "sailor".
and dry.
> but I did run around sitting on alot of things with a ruler and
laying in closets and under funiture etc etc...
LOL. In addition to you and me, I'm sure many a Bolgerado has done
this. Does Mr Bolger, do you think? He's had clients draw outlines
in their driveways etc. when elucidating their wants and needs.
function is very "Bolger"}).
Thanks for sharing this outa-the-box idea with us. Please keep up
development, and keep us informed how it goes.
Cheers
Hi Bill,
The attraction of OldShoe (for me anyways) is the fact that it's an open boat with high sides, so people can move around in it with relative ease, yet without much risk of "falling overboard". If I were to build one for myself, the most I would want in a cabin is the cuddy shown in this photo, which is really no more than a locker for secure/dry storage:
By the way, using a custom canvas tent on a boat like OldShoe may be better than anyone's idea of putting a cabin on it. A tent lets you have an open boat when you want one, and a protected shelter at other times.
Kenneth Grome
Bagacay Boatworks
>> In a message dated 6/1/2006 3:27:43 PM Central Daylight Time,
>> coletta_j@... writes:
>> Bill,
>>> You are definitely thinking out of the box with your design.
>> Some initial thoughts after taking a quick look at your drawing...
> Bill's Old Shoe design is at: Bolger6/Photos/Oldshoe
>http://ph.groups.yahoo.com/group/bolger6/photos/browse/efcb?c=
> /Bill's Sketch
>http://ph.groups.yahoo.com/group/bolger6/photos/view/efcb?b=8(Bill
> I think there is enough resolution here with the file automatically
> re-sized down by Yahoo, but if you would like it re-sized somewhat
> larger I could try it in a file somewheres. 729kb is big!)
> "It was just like the plans except that they'd (an Italian couple)
> made it longer and wider, but not higher, than the plans called for
> and made the bow pointed instead of the designed bow transom, and
> eliminated the keel (replacing it with a single leeboard), and
> rearranged the cockpit, and substituted a cat-schooner lug rig for
> the designed cat-yawl. Susanne commented mildly that it did not look
> much like an Old Shoe, but in fact it did not look bad. I have no
> problem with people who want to exercise creativity, especially
> when, as in this case, their design (not mine, wherever it started!)
> looks and sails well and made them happy... ...The design is an
> obvious candidate for a Birdwatcher top, perhaps a removable one to
> use in appropriate weather. That would make one heavy-weather
> capable indeed..." (PCB&F)
> Which other Bolger boat attracts/invites so much interest in
> modification? Quite a few do, no doubt, but Old Shoe must be well in
> the lead. And as for variants actually built... again I'd bet this
> design is probably #1! (excepting Windsprint?). In the above Italian
> job: did they use moveable sandbag ballast - like Matt Leyden's EC
> winner, Enigma?
> Cheers
> Graeme
> dead horses
> Fax: (978) 282-1349
In a message dated 6/1/2006 9:09:48 PM Central Daylight Time,
/Bill's Sketch
Thanks Graeme!
Would you make some things larger and others smaller? and why?
I'm sure the layout (besides the general concept) could use alot of
Here is something I wrote to Frank about it:
remember....in no way is this sketch detailed or optimized....its just shows
the spatial relationship between the sitting areas, storage areas, foot
wells, cabin etc etc...
In reality you'd probably want to shift things around a bit from what the
sketch shows....though "basically" the layout would likely stay the same.
The biggest unknown....or the thing I have though about the least is the
actual cabin....I know it would be of low height where your legs stick under the
port seat and be higher than that elsewhere but other than that I havent any
firm ideas....is it 4? foot high everywhere in the high part....or is
different heights in different areas....or is sloped? or curved? or stepped?.....
hatches? - number, size and location? access/hatchway design/layout ?....etc
etc
Also remember I have not real experience in
sailing/cruising.....particularly in smaller boats.....
My "big" contribution? here is the idea for the layout itself...fine details
and refinement are probably best done by those with much more experience....
The sketch just basically shows the "floorplan"
take care
Blll
> Bill,
/Bill's Sketch
winner, Enigma?
Cheers
In a message dated 6/1/2006 4:50:24 PM Central Daylight Time,BllFs6@...
writes:
6. I kept playing with some kinda sloted cabin idea in my mind and I didnt
like it for several reasons. A boat this short and narrow it just doesnt
seem
to work...if you have sleeping areas on both sides of the "isle", either
isle or the sleeping areas are pretty narrow...and probably both...If
someone
is laying down and part of the isle space is used as a sleeping area, if
you
gotta get to bow fast they are in the way,,,,if stuff is stored in isle its
in the way as well. If the porta pottie is to be used in the isle and
someone's laying down you get to use it right next to them and women folk
aint gonna
like that at all.
one thought just occured to me
You have a cabin the front with no isle....just sleeping space...the cabin
wall is basically flush with the hull on one side. However on the other side
you have a narrow walking space, which could either be at the same level as the
top of the hull, or it might be a narrow foot well lower than the top of the
hull but still has space underneath it that is usable/accessable in the
cabin below
take care
Blll
coletta_j@...writes:
Bill,
1. I am concerned about side-to-side trim with the cabin on the side.
2. Where would the mast be situated in the layout.
3. From what I have read 3.5 feet of headroom is sufficient to sit upright
in the cabin.
4. The seat foot well arrangement makes for a checkerboard affair that my
be hard to build.
5. Can the two foot wells be doable with a full width thwart seat with a
foot well on one side aft and the other side forward?
6. I wonder how a Birdwatcher slotted cabin arrangement might work on an
Old Shoe.
Thank you for sharing your ideas with us.
Frank
Hi Frank...
1. Yes, the cabin does present an asymetric port/starboard load thats built
into the boat. But I dont think its as bad as it sounds. Anyway, you will note
that I have two storage areas on the opposite side of the boat, plus the
porta potty is on the opposite side as well. I figure you store heavy/dense
stuff like tools, flares, metal parts, extra chain/anchor, batteries, water
bottles etc etc in those storage areas. Or perhaps a cooler in one of them...or
make on those areas a built in cooler even....I think that would go a long way
towards balancing out the extra weight due to the cabin on one side.... the
cabin aint that big IMHO..
2. The masts would be were they were on orginal Oldshoe...pretty much at the
very bow for the main and pretty much at the very stern for the mizzen?
3. Like I said, I need to go in the garage with a bunch of carboard boxes
and play in/on them. As far as a man with a female sailing companion goes...we
need to tackle the Holy Grail of small craft cruising here....the ability to
use the porta potty INSIDE the cabin....
4. Yes, it would be a bit harder to build, but I dont think it requires any
special skills and there are in my mind good reasons to build it that
way...see 5 below..
5. Do you mean you want the port seat to extend all the way across the boat
and do away with the aft starboard seat? If so, I dont like it. With the
checkerboard layout either way either person sits they already have a built in
back rest of sorts. They are also always sorta facing each other "knee to
knee"....and socially/conversation wise I like that alot more....and facing
somewhat opposite directions has another benifit.....more likely to see either good
or bad things outside the boat....
Hey Dave, check out those cool dolphins over there!
Uhhh, Bob....is that a torpedo headed our way?!
A "bench" running across the boat doesnt allow these things....but hey, some
folks may like it....
If you reall wanna get weird, think about side by side seating.....where
lets say you always sit on the port side looking starboard....and you only have
a footwell on the starboard side of the boat...might allow for some
advantages in a design....
like it for several reasons. A boat this short and narrow it just doesnt seem
to work...if you have sleeping areas on both sides of the "isle", either the
isle or the sleeping areas are pretty narrow...and probably both...If someone
is laying down and part of the isle space is used as a sleeping area, if you
someone's laying down you get to use it right next to them and women folk aint gonna
like that at all.
If you think about it abstractly....My design has put all the isle space
outside the cabin where it can do double duty as footwell/cockpit space...and is
still convertable to sleeping square footage....also, you can just throw
stuff in my cabin anywere and its not gonna be in the way if you going to the
bow.
Just some thoughts....take care
Blll
Bill,
in the cabin.
be hard to build.
Old Shoe.
Frank
>From:BllFs6@...
>Subject: [bolger] Oldshoe with cabin - Gnushoe
>Date: Thu, 1 Jun 2006 08:50:13 EDT
>Hi all
>This was started in another thread, so I have pasted the stuff I've sent�
>Basically, it is an oldshoe with a decent sized one person permanent cabin�
>which can still easily daysail 2 to 3 adults and still sleep 2 if one�
>sleeps
>outside the cabin. It should also be good for a husband and wife with 2/3�
>little kids as the cabin could be a good place to put the rug rats.
>Anyway, if someone wants the sketch of the layout let me know....the�
>current
>scanned file is about 800KB...I can scan it at a different resolution if�
>someone needs that...and if someone could post it in the photo/files
>section�
>that would be great since my computer and yahoo dont get along at all for
>some�
>reason.
>take care
>Blll
>here is the sketch......scanned at 200 dpi, grayscale
>if you print it at high quality mode (vs draft or regular quality) you can�
>see the graph paper lines/grids better...and you may have to print it out
>as�
>color rather than grayscale for it to look better (for some strange�
>reason...)
>in no way is this layout optimized, but it looks fairly functional as�
>is....at least I think so....but there are still ALOT of details to be�
>decided/worked out
>playing with a bunch of boxes, stacks of books, scrap lumber, and a� friend
>or two in the garage would probably go a long way towards optimizing the�
>final
>layout...
>If you need a higher quality scan, let me know....I just did not want to�
>overload your internet connection
>take care
>Blll
>A super quick description...
>The cabin only takes up one side of the boat..this the important/unique?�
>part
>It starts about 2 foot aft of the middle of the boat
>These first 2 feet are low....its where the end of your legs would be�
>laying
>down in the cabin...the roof here forms one the the two seats in the rear�
>part of the boat
>The cabin goes roughly another 5 feet foward of the middle of the boat� at
>a
>more reasonable height...for a total length of 7 feet give or take a� bit
>Note that while the cabin only takes up one side of the boat, the wall of�
>the cabin near the centerline of the boat (as opposed to the wall that is
>along�
>the outer hull of the boat) need not follow the centerline. Its probably
>better� if it is angled and actually crosses the centerline, getting most
>of the
>way to� the other side as it nears the bow.
>The back/aft half of the boat has two seats. The one near center, over the�
>cabin, as described above.� The other is on the other side of the boat and�
>at
>the stern. Think of two squares that are oriented the same way and touch�
>at
>the corners. Two people could easily sit with one facing fore and one aft,
>or�
>one port and one starboard or even one forward and one starboard (if they
>dont
> mind their legs in the same "well")
>Assuming the cabin is on the port side,� you still have some space� forward
>of the center of the boat outside of the cabin for a third person to sit�
>on
>the starboard side facing aft.
>And if you make the hatchway into the cabin right, with a special seat,
>you�
>could probably have a fourth person sorta sitting in the cabin, with their
>head� out and above the roof seated near the center of the boat facing�
>starboard.
>Now of course the only thing you would retain of oldshoe would be the hull�
>shape/size, keel, and sail design...everything internal to the hull would
>have�
>to be redesigned.
>Note that while the cabin could only sleep one (or maybe two small�
>children), two adults could probably sit up in it for short term shelter�
>decently.
>Also there is still room outside the cabin for one to sleep, which is� good
>since
>two men could camp out, safely separated by a cabin wall, preventing� any
>inadvertant nocturnal cuddling!
>Another feature is even if you make the cabin high, its still easy to�
>provide for access to the bow on the starboard side of the boat, without
>having� to
>go thru the cabin. The cabin wall actually gives you something good to�
>hang
>on to as you go to the bow.
>You could also apply this layout to the micro...
>In a message dated 5/30/2006 11:34:00 PM Central Daylight Time,�
>A sketch� would be good ;) just to check I've got your layout right in
>my mind's� eye. It seems a very flexible multi-use of the space
>available. I don't� quite see how the outside sleeper lies down
>straight enough on the� starboard side. I'm a bit concerned for the
>flooded stability, but perhaps� it can all get away overboard quickly
>without� impediment.
>Graeme
>There would be a foot well/bottom of the hull area about 4 feet long�� and
>2.5 feet wide on the starboard side which would be between the rear seat
>on� the
>starboard side and the front/bow seat on the starboad side.
>If the space under the rear seat is not used, again your legs can stick�
>under it and a body might fit laying down in foot well. But what would
>probably�
>make more sense are some boards/planels that you lay across the footwell,�
>thereby providing a flush raised deck that spans across the front starboard
>seat�
>to the rear starboard seat.
>So the area under the aft starboard seat would probably be for� storage.
>Again, the sleeping length is 7 feet give or take. The bow area of� the
>this
>sleeping deck would be the narrow end, so you would most� likely want to
>sleep
>with you head at the aft end.
>Another advantage of this layout, is if the outside sleeper needs� shelter,
>"all" you have to do is run a tent/tarp from the cabin wall to the� hull
>wall,
>so you are basically running a roof between 2 decently tall rigid�
>structures,
>making the "tent" much more secure, and fairly� simple. And I would think
>having "real" walls on a tent would go a long way� towards reducing the
>typical
>tent problem of water seeping in from the� sides.
>You might even be able to engineer thin solid panels that either store�
>on/under the cabin roof or on cabin floor or in/on the cabin wall that span
>from�
>the cabin wall to the hull to make your outside sleeping area. You might
>even
>be� able to make it so they are attached to the cabin with hinges say and
>you
>just� flip them over/up and bang, you gottcha yourself another little
>cabin.
>I think you could work it out so that a porta potty� would store under� the
>foward starboard seat. Not sure weather you would want it to stay under
>the�
>seat and you just lift a lid to use it....or maybe it slides into the
>cockpit�
>area to use....or maybe it slides out towards the port side to be used�
>inside
>the cabin.
>This would certainly be an odd looking boat....and oldshoe is a bit odd�
>looking to start with..but I fell in love with that design instantly and I
>still�
>think its my favorite.
>It does give up a fair bit of cockpit space over the the original oldshoe�
>for daysailing. But 2 easily and probably 3 adults can still be "topside".
>It�
>does have the advantage of having a cabin/area that you can securely put
>one or
> two little kids in, or an area to duck outa the weather for one or 2
>adults.
>You� could probably get 2 adults, one mid sized kid, and 2 little ones in
>the
>boat if� you kept what you brought aboard to a bare minimum.
>I sketched this out only knowing oldshoe's length and beam and eyeballing�
>the width of the blunt bow, the width of the stern, and guessing at what
>the�
>curve that defines the hull sides is like. I also guesstimated how much
>space�
>the transom/motor well needs and the bow anchor well also. Its hard for me
>to�
>guage how usefull/big/small the seats/footwells/cabin are, but I did run
>around� sitting on alot of things with a ruler and laying in closets and
>under
>funiture� etc etc...
>Again, in some respects its not as good as original oldshoe, but it� looks
>to
>me that it would be a great daysailer that at a minimum can sail 2� adults
>easily, with a cabin for at least one adult to duck into in bad� weather
>(around
>here on the northern gulf coast, the weather is typically good� and fairly
>predictable except for pop up thunderstorms that typically dont� last
>long), and
>Since if I were using it thats how it would be used I think it would� be a
>better match for me that oldshoe� original.
>- NO "GO AWAY SPAMMER!" posts!!!� Please!
>horses
>(978) 282-1349
>- Unsubscribe:�bolger-unsubscribe@yahoogroups.com
> SPONSORED LINKS
> Phil bolger
> Bolger
> Bolger center
> YAHOO! GROUPS LINKS
> �Visit your group "bolger" on the web.
> �To unsubscribe from this group, send an email to:
> �Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Hi all
which can still easily daysail 2 to 3 adults and still sleep 2 if one sleeps
Anyway, if someone wants the sketch of the layout let me know....the current
someone needs that...and if someone could post it in the photo/files section
that would be great since my computer and yahoo dont get along at all for some
reason.
take care
Blll
see the graph paper lines/grids better...and you may have to print it out as
color rather than grayscale for it to look better (for some strange reason...)
decided/worked out
playing with a bunch of boxes, stacks of books, scrap lumber, and a friend
or two in the garage would probably go a long way towards optimizing the final
layout...
take care
Blll
The cabin only takes up one side of the boat..this the important/unique? part
These first 2 feet are low....its where the end of your legs would be laying
part of the boat
The cabin goes roughly another 5 feet foward of the middle of the boat at a
more reasonable height...for a total length of 7 feet give or take a bit
the cabin near the centerline of the boat (as opposed to the wall that is along
better if it is angled and actually crosses the centerline, getting most of the
way to the other side as it nears the bow.
cabin, as described above. The other is on the other side of the boat and at
the stern. Think of two squares that are oriented the same way and touch at
the corners. Two people could easily sit with one facing fore and one aft, or
one port and one starboard or even one forward and one starboard (if they dont
Assuming the cabin is on the port side, you still have some space forward
of the center of the boat outside of the cabin for a third person to sit on
And if you make the hatchway into the cabin right, with a special seat, you
head out and above the roof seated near the center of the boat facing starboard.
shape/size, keel, and sail design...everything internal to the hull would have
to be redesigned.
children), two adults could probably sit up in it for short term shelter decently.
Also there is still room outside the cabin for one to sleep, which is good since
two men could camp out, safely separated by a cabin wall, preventing any
provide for access to the bow on the starboard side of the boat, without having to
go thru the cabin. The cabin wall actually gives you something good to hang
A sketch would be good ;) just to check I've got your layout right in
my mind's eye. It seems a very flexible multi-use of the space
available. I don't quite see how the outside sleeper lies down
straight enough on the starboard side. I'm a bit concerned for the
flooded stability, but perhaps it can all get away overboard quickly
without impediment.
There would be a foot well/bottom of the hull area about 4 feet long and
2.5 feet wide on the starboard side which would be between the rear seat on the
under it and a body might fit laying down in foot well. But what would probably
thereby providing a flush raised deck that spans across the front starboard seat
So the area under the aft starboard seat would probably be for storage.
Again, the sleeping length is 7 feet give or take. The bow area of the this
sleeping deck would be the narrow end, so you would most likely want to sleep
Another advantage of this layout, is if the outside sleeper needs shelter,
"all" you have to do is run a tent/tarp from the cabin wall to the hull wall,
so you are basically running a roof between 2 decently tall rigid structures,
making the "tent" much more secure, and fairly simple. And I would think
having "real" walls on a tent would go a long way towards reducing the typical
tent problem of water seeping in from the sides.
on/under the cabin roof or on cabin floor or in/on the cabin wall that span from
the cabin wall to the hull to make your outside sleeping area. You might even
be able to make it so they are attached to the cabin with hinges say and you
just flip them over/up and bang, you gottcha yourself another little cabin.
I think you could work it out so that a porta potty would store under the
foward starboard seat. Not sure weather you would want it to stay under the
seat and you just lift a lid to use it....or maybe it slides into the cockpit
area to use....or maybe it slides out towards the port side to be used inside
the cabin.
looking to start with..but I fell in love with that design instantly and I still
for daysailing. But 2 easily and probably 3 adults can still be "topside". It
does have the advantage of having a cabin/area that you can securely put one or
two little kids in, or an area to duck outa the weather for one or 2 adults.
You could probably get 2 adults, one mid sized kid, and 2 little ones in the
boat if you kept what you brought aboard to a bare minimum.
the width of the blunt bow, the width of the stern, and guessing at what the
curve that defines the hull sides is like. I also guesstimated how much space
the transom/motor well needs and the bow anchor well also. Its hard for me to
around sitting on alot of things with a ruler and laying in closets and under
funiture etc etc...
Again, in some respects its not as good as original oldshoe, but it looks to
me that it would be a great daysailer that at a minimum can sail 2 adults
easily, with a cabin for at least one adult to duck into in bad weather (around
here on the northern gulf coast, the weather is typically good and fairly
predictable except for pop up thunderstorms that typically dont last long), and
Since if I were using it thats how it would be used I think it would be a
better match for me that oldshoe original.
