Re: [bolger] Re: Martha Jane oars
thanks for the tip.
please keep up your web site- it is a nice one!
On Jun 17, 2006, at 1:54 PM, alaskamaz wrote:
> I really hate to redirect boat builders from their projects, but if
> you want an easy, efficient way to move a Martha Jane by oar, consider
> a yuloh. The two main advantages are one oar instead of two, and a
> propulsion system that is parallel to the centerline of the boat
> rather than perpendicular--very handy for small creek mouths or narrow
> moorings where it's difficult to swing a pair of oars big enough to
> move your boat along.
> My brother and his wife use a yuloh on their much larger, heavier
> LUNA. In fact, his yuloh's better than mine--he made it out of a
> spruce sapling and a plywood spoon. It's lighter, more flexible, and
> moves a bigger boat faster than mine. I'm seriously considering
> downscaling mine, although I'm extremely happy with my lanyard
> configuration.
> You can see examples of these in the SELKIE and LUNA sections of my
> Web site:http://www.alaska.net/~mzeiger/Boat_Building.html.
> While I'm here, I should mention to those of you who know and use my
> site, we're working on a move to elsewhere in Alaska, and there's a
> good possibility I will take down this site. Haven't made any hard
> decisions yet, but thought I'd give you a bit of warning now that I've
> finally logged back onto this forum.
> Fair winds,
> Mark Zeiger
> Juneau, Alaska
> --- Inbolger@yahoogroups.com, "Mike" <skiffsalor2000@...> wrote:
> > Mike:
> > The patterns are out there for the having. I like the long oars
> > with the narrow blades, mine are 7 feet. I made them from a
> > 2 X 6 and whittled them out with a draw knife. After they got a
> > little closer, I used a belt sander on the blades to taper them.
> > Then, I found this somewhere, you take a belt from a belt sander and
> > turn it inside out. Then you fashion a drive pulley that will spin
> > this belt and you use that to round the shafts. I don't worry about
> > getting the shafts 100% round - mine are oblong. I used nylon line
> > to protect the oars where they contact the boat and vice-versa.
> > I have made 5 oars like this. 5 because I lost one and had to make
> > a new one. It was a sad day when I lost that oar. I found all this
> > online - there are patterns and information if you just
> > google "homemade oars" or something. I did receive a compliment on
> > the oars. They sound crude but, my soon-to-be ex-wife, now showing
> > interest in my boats, said, "these should be on display." You would
> > have to know here to appreciate the comment. Varnish makes most any
> > wood look pretty good.
> > Mike
> > --- Inbolger@yahoogroups.com, "Mike" <mkstocks@> wrote:
> > > I'm thinking about making some oars so that I can row my Martha
> > Jane while standing and
> > > facing forward. Any experienced suggestions on how long to make
> > the oars, etc???
> > > Thanks.
> > > Mike
Mike Stockstill
mkstocks@...
http://mkstocks.tripod.com/
configuration.
Fair winds,
Mark Zeiger
Juneau, Alaska
configuration.
Fair winds,
Mark Zeiger
Juneau, Alaska
> Mike:
> Mike
> the oars, etc???
> > Thanks.
> > Mike
I row my "Bufflehead" (Dovekie inspired 19' row/sailboat) standing up facing
forward with 9' oars on the gunwale. The freeboard is about 32" and the
spread about 60". I think 10' oars might be better, but these do ok. I
face forward mostly in enclosed areas like marinas or for short stints, or
while sailing in light wind. I find facing forward more enjoyable than
backwards, and sometimes go distances that way, though it doesn't seem quite
as efficient. The almost 18' spread of the oars can be a bother in some
tight places as mentioned, but unlike a yuloh, you have reverse and can spin
the boat around and make very sharp turns with one oar in fwd. and one
reverse. My oars are made from 2x3 fir with 1/4" ply blades. My cockpit
floor is about 28" below the oarlock level, which seems to bring the oar
handles about right where I want them, at mid chest level.
Gary
Gary
Sent: Saturday, June 17, 2006 8:31 AM
Subject: [bolger] Martha Jane oars
I'm thinking about making some oars so that I can row my Martha Jane while
standing and
facing forward. Any experienced suggestions on how long to make the oars,
etc???
Thanks.
Mike
Mike:
Mike
Mike
the oars, etc???
> Thanks.
> Mike
I'm thinking about making some oars so that I can row my Martha Jane while standing and
facing forward. Any experienced suggestions on how long to make the oars, etc???
Thanks.
Mike
Thanks.
Mike
