Re: Epoxy paint.
--- Inbolger@yahoogroups.com, "Bob Chamberland" <chamberlands@...> >
For glassing the usual approaches are to lay down a prime coat of
> epoxy and when it is no longer tacky but still green, lay out the
> fiberglass cloth then lay on the epoxy filling the weave of the
cloth.
I wonder if it would be possible to do what Bob recommends above, to
get the cloth attached to the wood with pure epoxy and then finish off
filling the weave with several coats of paint? The surface will likely
end up pebbled likely - sort of a "sharkskin" effect:-)
Paint by itself will not work for reasons already mentioned. The
solids in the paint will prevent full adhesion between the wood and
the glas cloth. But people have done it nonethless. I would not.
One could test first by glassing a small piece of scrap wood and let
it cure for several days and see how easily it peels off using some
pliers. Or better yet, try three test pieces, one using pure epoxy
only, one with epoxy and paint and one with only paint. And share your
findings:-)
We don't know what this stuff is do we? For underwater use you had
best contact the formulators. If they use it for oil platform supports
I would suppose you could paint the bottom of your boat with it.
fiberglass cloth then lay on the epoxy filling the weave of the cloth.
Or you could let the prime fully cure, wash and sand then lay the
cloth out and lay on the epoxy. The other tack is to just lay out the
cloth on the wood and start slathering epoxy until it won't take any
more in. The problem with using paint is that it skins over and this
can happen rapidly before you can fill the voids or perhaps even
before the paint has a chance to soak through the cloth. Epoxy doesn't
skin over like paint. You generally have anywhere from an 30 minutes
to an hour or so before curing limits workability. Maybe longer
depending on the formulation and temperature of the workplace.
Bob Chamberland
--- Inbolger@yahoogroups.com, "howgegoboat" <howgegoboat@...> wrote:
> Hi I was supprised to hear that about epoxy, thanks for the
> correction, this stuff is surplus to the oil industry so you cannot
> get much more industrial than that! I caanot see why you cannot
> suspend glass in it if you can grit. Will email them sometime. But
> that is a while off yet, need to get frames built and then planked.
> YOurs James
James,
This last message was a bit cryptic, but I'll comment on the bits I
think I got. I'm not sure I understand your objection to brittle.
Either a glue works for your application, or it doesn't. It'd have to
be a pretty specialized usage to disqualify a glue for being too
brittle. but I'll comment anyway. First, titebond II is not at all
brittle. In fact, one of the applications to which it is not suited is
bent laminations where there is a tight radius. Because it doesn't dry
hard & brittle it's prone to allow creeping & springback over time. It
dries rubberier than epoxy. I haven't used polyurethane glues much
(and haven't liked them when I have) so can only say my impression is
they dry harder, more brittle than TII. We built a Puddle Duck Racer
using TII & narrow crown staples. It hasn't hit the water yet, so I
can't say how it'll hold up. I'm confident it'll be fine, but I do
regard it as an experiment. I am going to beef it up a bit my using
fiberglass tape set in epoxy at the chines, etc. But no epoxy fillets
planned.
Regarding paints, my boat painting experience is minimal. So far, for
boats, I've used latex porch & deck paint, oil porch & deck paint, and
2-part polyurethane. Like the ease of use & price of the latex porch
paint, but it seems the least durable. Oil porch paint seems more
durable, about the same price, though one must use (and properly
dispose of) solvents to clean up. The 2-part looks like it'll be quite
durable. Solvents to clean up. Quite expensive. Too glossy right out
of the pot for the level of craftsmanship that my sons & I aim for in
our boat projects - it shows every flaw. As with any painting,
preparation is a primary factor in setting the final outcome. Sand &
fair well. Use the appropriate primer. Sand well. Put on multiple thin
coats of topcoat rather than 1 or 2 heavy coats.
Good Luck,
David Graybeal
Portland, OR
"The workboat finish is a case of mind over matter. If you don't mind,
it don't matter" -- Lew Clayman
> --- Inbolger@yahoogroups.com, john h wright <jhargrovewright2@>
> wrote:
> >Hi thanks for the advice,
> seemed to good to be true!
> What do people think of latex exterior paint,
> Bitumen paint,
> Polyuathane floor paint,
> John Welsford recomends paint is as good as epoxy,
> May be resigned to epoxy!
> Epoxy is expensive in Uk.
> Also glues I have been using polyuathane building glue.
> As tested in serveral places - brown cartridge glue!
> Titebond two seems to brittle to me especialy when used with
> softwood which is more flexable than hardwoods
> Yours james.
Hi
Thanks for the advice, I caanot see why I should not use this epoxy
paint on underwater. and indeed lay glas in it. Its ex oil rig paint
so it is going to be good stuff! The narrow boats on the canal just
use bitumen paint and no antifouling! Must be minimal growth, so I
could just use that stuff, as its cheap, but I am not sure how water
proof or abrasion resistant.
Must build today.
Need to cut roof beam laminations but table saw is burnt out.
Neighbour promised me his but I have yet to see it!
Have built all frames, and now need to built transom, before I can
contemplate building up.
Yours James
-- Inbolger@yahoogroups.com, john h wright <jhargrovewright2@...>
> There is two part epoxy paint and two part urethane paint. Both
can be
> very good paint and long lasting but also are relatively expensive.
> On Tue, 11 Jul 2006 19:46:49 -0000 "Bob Chamberland"
> <chamberlands@...> writes:
> John's reply sure brought me up short. What I've been calling epoxy
> paints are polyurathane paints. The two part are linear
polyurathane.
> Petit "Easypoxy" is a polyurathane paint.
> Is there any relationship between "epoxy" chemistry
and "polyurathane"
> chemistry? Read my comments below substituting the
word "polyurathane"
> for "epoxy" until someone can enlighten me. Other than that I don't
> think I would change what I written.
> Bob Chamberland
> wrote:
> > The word Epoxy in a name does not mean very much. A one part
epoxy
> paint
> > is misleading to most of us laymen. Most would be better off
using
> > anything else. The only Epoxy Paint that I have had any luck
with is a
> > Two Part (catalyzed) and must be mixed together but has had pot
life
> of a
> > couple of hours at most temps. My advice is don't waste your
time or
> > money on so called "one part epoxy paint". My 2c worth.
> > On Tue, 11 Jul 2006 13:55:07 -0000 "Bob Chamberland"
> > <chamberlands@> writes:
> > Hi James, Your epoxy paint supplier can probably answer your
first
> > question though he will probably not want to commit himself.
> > You should not use epoxy paint on the bottom of your boat. You
will
> > get blisters if the boat is left in the water. This is the voice
> > experience. I used Interthane Plus on a boat years ago. It spent
> > summer on a mooring in 43 degree water. At the time I took it
out it
> > had plenty of blister. The epoxy paints I've seen are topside
paints
> > only. Epoxy paint is not the same as the usual epoxy for glueing
> > coating. It will skin over while you are trying to set the glass
in
> > place and you will probably have one heck of a mess.
> > Epoxy (not the paint) should not be thinned though when it is
thinned
> > acetone is usually used. One advantage of epoxy is that it cures
> > chemically without leaving the voids that evaporating thinners
leave.
> > This is what gives it its water resistance. There is some
question of
> > whether adding thinner aids penetration but it does leave voids
for
> sure.
> > Epoxy paint is UV resistant mostly by means of the pigment I
think.
> > Dark colors do fade. The paint can will tell you what to use for
> > thinner. Epoxy paint is not usually thinned except when
evaporation is
> > too fast-hot dry days. If your boat is going to be moored it
would be
> > a good idea to glass the bottom with epoxy (not paint) use a
barrier
> > coat then bottom paint and read the directions on the can.
> > Bob Chamberland
> > --- Inbolger@yahoogroups.com, "howgegoboat" <howgegoboat@>
> > > Hi I was just wondering if anyone had an answer for me.
> > > I am building a plywood 23' sailing yacht, long concrete keel
etc,
> and
> > > was wondering if it is possible to use glass cloth in epoxy
paint, I
> > > know you can use anti slip in epoxy paint so why not glass
cloth? I
> > > don't need the glass for strength just for abrasion and water
> > > resistance. I can get epoxy paint very cheap.
> > > Also what can I use to thin it. I am told that to thin the
first coat
> > > means that the penentration is better and will give a better
hold on
> > > the plywood bottom. 3/4" incidentally. Also is epoxy paint
resistant
> > > to UV?
> > > See Backyard boat building 3 for pics - Offcut special!
> > > YOurs James
There is two part epoxy paint and two part urethane paint. Both can be
paints are polyurathane paints. The two part are linear polyurathane.
Is there any relationship between "epoxy" chemistry and "polyurathane"
chemistry? Read my comments below substituting the word "polyurathane"
Bob Chamberland
--- Inbolger@yahoogroups.com, john h wright <jhargrovewright2@...>
> The word Epoxy in a name does not mean very much. A one part epoxy
paint
> is misleading to most of us laymen. Most would be better off using
> anything else. The only Epoxy Paint that I have had any luck with is a
> Two Part (catalyzed) and must be mixed together but has had pot life
of a
> couple of hours at most temps. My advice is don't waste your time or
> Hi James, Your epoxy paint supplier can probably answer your first
> You should not use epoxy paint on the bottom of your boat. You will
> get blisters if the boat is left in the water. This is the voice of
> experience. I used Interthane Plus on a boat years ago. It spent the
> summer on a mooring in 43 degree water. At the time I took it out it
> had plenty of blister. The epoxy paints I've seen are topside paints
> only. Epoxy paint is not the same as the usual epoxy for glueing and
> coating. It will skin over while you are trying to set the glass in
> Epoxy (not the paint) should not be thinned though when it is thinned
> chemically without leaving the voids that evaporating thinners leave.
> This is what gives it its water resistance. There is some question of
> whether adding thinner aids penetration but it does leave voids for
sure.
> Epoxy paint is UV resistant mostly by means of the pigment I think.
> thinner. Epoxy paint is not usually thinned except when evaporation is
> too fast-hot dry days. If your boat is going to be moored it would be
> a good idea to glass the bottom with epoxy (not paint) use a barrier
> Bob Chamberland
> > I am building a plywood 23' sailing yacht, long concrete keel etc,
> > was wondering if it is possible to use glass cloth in epoxy paint, I
> > know you can use anti slip in epoxy paint so why not glass cloth? I
> > Also what can I use to thin it. I am told that to thin the first coat
> > means that the penentration is better and will give a better hold on
> > the plywood bottom. 3/4" incidentally. Also is epoxy paint resistant
> > to UV?
> > YOurs James
Bob:
I've been quite happy with the 1-part polyurethane (Interlux
Brightsides) that I used on my Windsprint and the bottom of my kayak. I
don't leave them in the water for very long (up to 2 weeks in salt water
with a months-long drying out period afterward for the Windsprint), so
maybe the whole boat is like topsides for me.
Pat
> Bob Chamberland
> paint
> of a
> sure.
>> Bob Chamberland
> and
>>> to UV?
>>> YOurs James
YOurs James
polyurathane.
and "polyurathane"
word "polyurathane"
> Bob Chamberland
epoxy
> paint
using
with is a
life
> of a
time or
first
will
out it
paints
in
thinned
leave.
question of
for
> sure.
think.
evaporation is
would be
barrier
> > Bob Chamberland
etc,
> and
paint, I
cloth? I
first coat
hold on
resistant
> > > to UV?
> > > YOurs James
Bob Chamberland
paint
of a
sure.
> Bob Chamberland
> > to UV?
> > YOurs James
Bitumen paint,
Yours james.
epoxy paint
is a
life of a
or
it
paints
thinned
leave.
for sure.
evaporation is
be
barrier
> Bob Chamberland
etc, and
paint, I
cloth? I
coat
hold on
resistant
> > to UV?
> > YOurs James
The word Epoxy in a name does not mean very much. A one part epoxy paint
Two Part (catalyzed) and must be mixed together but has had pot life of a
whether adding thinner aids penetration but it does leave voids for sure.
Bob Chamberland
> I am building a plywood 23' sailing yacht, long concrete keel etc, and
> to UV?
> YOurs James
Bob Chamberland
> to UV?
> YOurs James
to UV?
YOurs James
