RE: [bolger] Hot Knife
Weller's 'Porta-Sol' butane soldering iron can be
had in two setups - just the solderer with regular tip and a cap with
pocket clip and sparker for igniting, or in a plastic box with a little sponge,
some solder, and 3 or 4 tips, including a flattened wedge-shaped blade for
cutting things which would easily handle 1/2" line. Variable heat up to ~120W
(plenty hot for cutting nylon, etc), long life on one 'charge' of butane, About
30 bucks for the iron alone at West Marine (I've seen it as low as
$24 in electronics/tool catalogs), more for the full kit - have not
seen kit at my local West store, but I bet they can order one, or look
elsewhere for a better price. Don't know if that's reasonable enough for you but
shop around. As portable as they come, works well, takes alot of abuse!, fuel
available in any drugstore, and the full kit does it all - has a little torch
attachment, a curly thing just for heatshrink, soldering tip, and
cutting tip. A very handy thing to have in your
toolbox.
Paul
Paul Lefebvre
paul@...
Does anyone have a line on 'portable' hot knives that are reasonable in price and are effective on up to 1/2 in line?.
Low tech solution,
I have been using an old fillet knife and a propane torch for many
years now. Simple heat the fillet knife and slice away. It never
breaks!
breaks!
20000606 2305EDT
line?.
Thanks
Grau Segler
