Re: [bolger] Digest Number 2964
Chris, you have given me a lot to think about. The
deck house is on a Cheoy Lee Monterey Clipper, a
salmon-troller type boat. It has a high motor-vessel
type house, and I would like to keep it painted. What
if I strip it to the extent possible, hit all the bare
wood with an epoxy sealer, then overcoat with a good
latex primer and acrylic topcoat? I have always used
latex on the topsides and superstructure of ply-epoxy
boats with good results, but this is my first real
wooden boat, and I had assumed (maybe wrongly) that
oil-based marine paint was better for the topside
planking, cabin and housesides.
--- Chris Crandall <crandall@...> wrote:
> Don't do it. Really. Latex paint (assuming you've
> got acrylic "latex"
> on her) is made to be flexible. It is quite
> dynamic, and this is a
> good, good thing. Putting oil-based paint on top of
> her is a bad match.
> The reason is that oil-based paints are not as
> flexible, and as a
> result, they will check and flake off. You must
> match your primer to
> your topcoat. While you can occasionally get away
> with latex over
> oil-primer, you should not attempt oil over latex
> primer.
> I agree that the perfect is the enemy of the good.
> But the crappy is
> the enemy of the good, too, and that's what you'll
> have on your hands.
> Your deckhouse is teak boards? Alas, too bad it's
> not a teak veneer
> (like a Frisco Flyer).
> You could stick with latex, but you still wouldn't
> be out of the woods.
> I would strip her as much as is possible in a single
> day. That should
> be a lot. Then, I would degrease her as much as
> possible--that means
> lots of acetone and scrubbing. Then, a top quality
> exterior latex
> primer (I happen to favor Kilz II, which is thick
> and flexible). Then a
> topcoat or two of your choice. I believe that latex
> primer can stick to
> teak with proper preparation. It's not the easiest
> and it's not the
> best, but it would probably work.
Do You Yahoo!?
http://mail.yahoo.com
Along this same line has anyone tried pure acrylic over latex acrylic
primer. I primed the interior of my Elver with Latex acrylic thinking to
finsh with the same in a finish coat. Since some are saying use 100%
acrlicr have been thinking about using pure acrylic as a finish coat.
Any body have any experience with this. This might be better than the
oil paint in this thread.
Doug
Chris Crandall wrote:
> Don't do it. Really. Latex paint (assuming you've got acrylic "latex"
> on her) is made to be flexible. It is quite dynamic, and this is a
> good, good thing. Putting oil-based paint on top of her is a bad match.
> The reason is that oil-based paints are not as flexible, and as a
> result, they will check and flake off. You must match your primer to
> your topcoat. While you can occasionally get away with latex over
> oil-primer, you should not attempt oil over latex primer.
> I agree that the perfect is the enemy of the good. But the crappy is
> the enemy of the good, too, and that's what you'll have on your hands.
> Your deckhouse is teak boards? Alas, too bad it's not a teak veneer
> You could stick with latex, but you still wouldn't be out of the woods.
> I would strip her as much as is possible in a single day. That should
> be a lot. Then, I would degrease her as much as possible--that means
> lots of acetone and scrubbing. Then, a top quality exterior latex
> primer (I happen to favor Kilz II, which is thick and flexible). Then a
> topcoat or two of your choice. I believe that latex primer can stick to
> teak with proper preparation. It's not the easiest and it's not the
> However, what you *really* should do is strip her down to the wood, and
> do *no* topcoat finishing. Just wash her with soap and water twice a
> year (gently). As you probably already know, teak alternates between
> soft and hard early/latewood, and stiff bristles can dig out the soft
> stuff. Maybe 3M pads, but not stiff plastic bristles.
> If you really want to seal the teak up, I would use a shellac first.
> That will seal up the oils. Then, an oil-based primer, then oil-based
> paint. You can do the same thing with epoxy, of course, and you can put
> any finish you like on top of epoxy (well, not Cetol, but I assume you
> aren't as crazy and tasteless as that).
> > I have a deckhouse which is made of teak boards. It
> > was painted by a previous owner with what I believe to
> > be latex paint. It didn't stick worth a darn to the
> > oily teak, but where it was over intact paint (the
> > majority of the house) it is in good shape. The best
> > bet would be to strip all the paint off and start
> > fresh, but on the theory that the perfect is the enemy
> > of the good (aka Glasscock's laziness principle) I
> > would like to leave she tight stuff in place. I
> > assume oil-based urethane is what I need over the
> > teak, but I don't know how well it will stick to the
> > latex. Any help/educated guess/speculation will be
> > gratefully accepted. Sam
