Re: [bolger] Re: Blowing up a sea-hawk or inflating, as the case may be.
Mike,
Look at Diablo and Diablo Grande on instantboats.com. If you have
access to Boats With An Open Mind., look at Samuel Clyde. These are
similar to Seahawk.
V/R
Chris
Mike wrote:
> Because Clyde, I like the lines of the Sea Hawk. snip...
Because Clyde, I like the lines of the Sea Hawk. The Topaz to my
eye, is an awkward and clumsy design, more suited to please the
farmer's eye than one who has spent much time around water. I don't
mean to ruffle feathers, but designers are like anyone who puts their
pants on one leg at a time. They have good days, and bad days.
I've worked on boats since 1970 and I can say with experience;
graceful, seaworthy boats, are no more expensive and take no more
time to build than ugly boats.
The sweeping sheer, flair of the sides, and the rake of the stem all
combine to make the Sea Hawk dory the power equivalent of Bolger's
Gloucester Dory, the boat he plans to make it into heaven with.
I look at the boat as almost a scale model of a larger boat because
of it's proportions.
Mike.
--- Inbolger@yahoogroups.com, Clyde Wisner <clydewis@...> wrote:
> I'm not familiar with Seahawk but what about building Topaz without a
> house, at 31+'. Clyde
> Mike wrote:
> > I've built a 15'6" version of Phil's sea-hawk and I really liked
> > it's qualities. Except for the size. As stated in "Small Boats" it
> > truly is more like a 12 footer th
This is a little off topic but I would appreciate the
group's opinion. I am restoring an old Monterey
Clipper, strip built of mahogany. She has been 2 1/2
years out of the water and the bilge is very dry. I
would like to put in some kind of anti-rot treatment
now while the strips will really take it up, before I
use a soaker hose outside preparatory to filling the
seams and painting. Any thoughts about what would be
best? Cuprinol? Antifreeze? Borate solution? The
fasteners are all Bronze/brass/copper. The tender for
this boat will be a Bolger design, so it really is a
Bolger question! Thanks. Sam
Do You Yahoo!?
http://mail.yahoo.com
I'm thinking two layers of 1/2 inch for the bottom and one of 1/2
for the sides. On my model I've put the equivalent of two batterys and
36 gallons of fuel right in front of the transom and the low cabin is
just a place to get out of the rain in. (no galley, bunks, or head.
Also, a steering console just forward of station #5 floats the model
on its lines.I belive the narrowness foward will keep the slamming to
a minimum. This is a fishing boat and not a cruiser
Speed wise, I'm thinking of 20 knots as a maximum. The model seems
to slip through the water at 10-12 very nicely leaving a little extra
horsepower to counter wind and water conditions. If you should happen
to have the book "Small Boats" the top picture of the Sea Hawk is
running with two passengers foward at about the same attitude as my
model does at a scale 12 knots.
You may cause me to rethink the cabin configuration, perhaps a short
deck with an angled vee shaped coaming would be more appropriate.
mike
--- Inbolger@yahoogroups.com, "Howard Stephenson" <stephensonhw@...>
> A few thoughts:
> 1. Obviously you'd have to increase the thickness of the ply; but
> what would you need to use?
> 2. The centre of buoyancy and centre of the planing surface are not
> very far forward in this design i.e. it's fairly narrow forward. This
> might make a scaled-up version unsuitable for a fair bit of weight
> forward (like a cabin and forward controls). You'd need to make
> estimates of weights then calculations of moments vs. buoyancy.
> 3. Twenty knots in a flat-bottomed boat? OK if you're going to be
> using it in flat water. OTOH there are quite a few apparently
> successful planing semi-dories around in sizes up to 20' or so.
> Howard
> > truly is more like a 12 footer than a sixteen.
> > I played around with a model and have done some drawing, and I
> think
> > I can multiply the original dimensions by as much as 1.8 to 2.0 and
> > come up with a long, narrow, trailerable, fishing boat that will
> have
> > the same qualities I like in the short version.
> > I know people like me drive designers crazy, but try to imagine
> the
> > sea-hawk as a 31 footer with 8'2" beam, 10 inch washboards, 3 inch
> > coamings, and a low cabin forward. 50 horsepower should push it
> about
> > twenty knots with great mileage. 6 extra frames will give it
> support,
> > and two or three stringers will strengthen the side planking.
> > Think about it and then try shooting holes in my idea, I will
> > welcome any response that remains civil. (;I'll welcome any uncivil
> > ones too but I retain the right to be as uncivil as appropriate ;)
> > Mike.
> > Meddle not with dragons for thee are crunchy, and good with ketchup.
A few thoughts:
Howard
think
have
about
support,
> Mike.
I played around with a model and have done some drawing, and I think
come up with a long, narrow, trailerable, fishing boat that will have
I know people like me drive designers crazy, but try to imagine the
coamings, and a low cabin forward. 50 horsepower should push it about
twenty knots with great mileage. 6 extra frames will give it support,
Mike.
