Re: [bolger] Sailing My Junebug
Chris
I have seen some pretty nice SYP ply. As Phillip states, the 1/4" has
2/3rds of the grain going the same way. This should provide more strength
in the direction needed, and grade AB can be found with essentially no knots
in the outside veneers. I think it is a good idea. Glass on the outside
would not hurt either.
On Wed, 7 Jun 2000, LEA, PHILLIP B wrote:
A nice post.
> My fix will be to use ¼ inch southern yellow pine ply which has thick
> outer veneers - each veneer is equally 1/3 of the thickness. Yellow
> pine is also a strong species of wood. And I will carefully check it
> for bad grain and will avoid any factory patches (Dutchmen). I am
> also considering running a piece of glass tape lengthwise on both
> sides of the board - it has tremendous tensile strength.
I think the glass tape is a very good idea, but I'm not so sure about the
SYP plywood--it's usually not of the finest kind.
Old school buds here:
http://click.egroups.com/1/4057/10/_/3457/_/960393045/
After reading that.. I so want to be out sailing that it hurts!!!
I have resolved that I will not go sailing till I've finished my Micro.. This
will make me finish it quicker!!
Phillip,
On my Junebug, I ended up sheathing the lower 2/3's of my leeboard with
lightweight fiberglass. My problem was checking of the Doug Fir plywood, but it
also stiffened up the board considerably.
"LEA, PHILLIP B" wrote:
