Re: [bolger] Wierd Micro Keel Idea: Pour in place?
Hi Glen Gibson,
> Does pouring lead into a normal wood mold burn the wood?
Most assuredly, yes. Especally a closed mold like the keel would
provide.
> No epoxy to hold in the lead, but shouldn't all those nails/screws, which the
> lead has been cast around, be enouph to hold it in place?
This would be your biggest problem! The heat from the lead will
loosen the screws/ nails, by scorching the wood they are in contact
with, and with out the whole ballast block well epoxied into place you
would not only loose the strength in the keel, but I doubt you would get
through a season without dropping the lead out of the boat.
If you must deviate from handling the ballast in one piece, why not
cast in several sections, say thirty or so pounds each, then butter them
well with thickened epoxy and put them into place one at a time.
> TURNING OVER THE BOAT WITH 420 POUNDS OF LEAD ON THE "TOP"!!!
I don't remember who's web page it was, but someone tried this, with
what he described as 6 or 8 of his friends who were dingy sailors, and
when the boat started to turn, he had the worlds biggest mouse trap.
Luckily no one was hurt. It's hard to visualize how much righting force
420 pounds of lead can exert on a hull the size of the micro.
> Comments? Ideas? Or should I simply check myself in to some kind of
> institution ;-)
Those are my comments, for what they are worth. If you find an
institution, for boat builders malady, please let the list know. Maybe
we can get a group rate. ;-) Heaven knows, I would qualify!
All the best, Stan, Stern Wheeler, Micro Tugger, Snow Goose.
