Re: [bolger] Weighed Canoe / Pirogue
Tim:
One of the Austin boat builders I talked to added a skeg to a kayak. He
ended up with one about two feet long, and about two inched deep tapering to
nothing. He first built several different skegs, and tried each one by duct
taping it on, and paddling around, until he found the one he liked.
I have just started doing the stitch and tape on the Caprice, and I have a
lot more respect for Dave Gulley's work now. If you see him, tell him I
said hi.
> List,
> Weighed the Pirogue today and it came out 34 lbs. Dave Gulleys similar
> design was 28 lbs. His is stitch and glue and mine has chine logs and
> gunwhales. It still has to have a skeg and epoxy coat the inside. Will
test
> it this weekend (hopefully - storms forecast - usually means "clear and
> dry").
> Not sure how to attach a skeg. Anyone have a suggestions? The canoe is
> 14'3" x 30" - any idea about the size of the skeg? Other than this, I am
in
> complete control of the skeg situation. Also, it is double ended,
> symetrical and the same on both ends - how do I know which end to put the
> skeg on.
> Tim - manager of ill repute - Spring, TX
> Old school buds here:
>http://click.egroups.com/1/4057/10/_/3457/_/960504295/
