Re: [bolger] Re: Keel on the Micro
> The homemade strip of lead blocks that you made to bring all the lines
> aft.
http://sports.webshots.com/photo/1200179693051159125GuetGh
I am pretty happy, but am thinking of re-doing the reefing sheeves,
(the outside pairs), because the angle is wrong a tad and causes
friction and chaff. The important sheeves, for the halyards and
topping lifts, work great.
> Going through your photos I can see that you would probably be
> warranted to do a Duckworks article on homemade blocks.
Except, that I learned how to make blocks by reading a Duckworks article.
aft. Going through your photos I can see that you would probably be
Bruce Hallman wrote:
>> Are their a pictures on line of your homemade deck organizer on the
>> Micro Navigator? I have misplaced my copies that you had up earlier.
> Here are my building photos. I don't know what you mean by 'deck organizer'.
>http://sports.webshots.com/album/121069753OCENAu
> ------------------------ Yahoo! Groups Sponsor --------------------~-->
> Great things are happening at Yahoo! Groups. See the new email design.
>http://us.click.yahoo.com/lOt0.A/hOaOAA/yQLSAA/_0TolB/TM
Bruce (Hallman)
Sleeping arrangements on the Esther Mae are currently in flux. My wife uses
the v-berth; I cannot easily roll over due to the space from bunk to cabin
top being smaller than the width of my chest. Plus with two in the v-berth
it is like stuffing sardines into a can (I am 6' and my wife is 5'10"). I
have slept on the sole of the cockpit, not very satisfactory, and I have
slept on one of the benches in the cockpit, (current top choice). I am
planning to rework the interior at the #4 bulkhead to create a bunk on the
port side where I would lie head to head with the v-berth occupant (my
wife's idea, I like it because it reflects an asymmetrical layout based on
the ergonomics of real usage) . Current sleeping arrangement does not bring
the bow down enough to stop the chatter. I have a 25 hp four stroke and a
built in 17 gal tank along with two 12 volt batteries behind the cockpit to
counter act any weight forward. I want to move the batteries forward under
the bench seats to the back side of the cabin to ease access to them and
move weight forward for running trim. One of the advantages of anchoring
from the stern is access. I can step out of the cockpit into the aft
cockpit well without all the gymnastics involved with going forward to the
anchor on the bow. I have obtained a 2'x2' hatch that I plan to install in
the forward end of the cabin, but it needs to be stripped and recoated
before doing so. That hatch would allow me to reach the anchor without
having to crawl out onto the cabin top, perhaps then I will give further
consideration to a slap pad of built up foam under the bow. There are many
other items on the list of things to rebuild before that happens, such as
cabin top hatch, aft hatch, cockpit top, not to mention the rework of the
interior that I would like to complete this season before the annual Easter
camping trip. Did I mention the sandblasting and re-glassing of the hull at
the chines all the way around? O yea, and some touch up on the patch where
we poked a piling through the bottom, that tends to leak a little when
running in rough water. I have got to stop driving her around and work on
her at some point. I can tell ya that come next spring....
Caloosarat
_____
>From: "graeme19121984" <graeme19121984@
<mailto:graeme19121984%40yahoo.com.au> yahoo.com.au>
>When anchored from the bow do you sleep forward in the Esther Mae,
>Chester? I would have thought that weight forward would stop the
>wave slap. PCB described this advantage of the sleeping forward
>arrangement in the Singlehanded Schooner. The weight up front
>pitches the bow down into the water. The waves are then cut by the
>bow rather than slapping/drumming on the bottom. Perhaps motor, and
>fuel weight back in the stern don't allow sufficient pitching of the
>rising bottom forward in a hull like the Esther Mae.
>Graeme
As a designer of small waterfront facilities I avoid epoxy coated steel in
construction specifications for use in concrete. The epoxy reduces the
ability of concrete to adhere to the rebar, it is inevitable that during
handling of the steel the epoxy will get chipped, no field bends can be made
and cut-offs are a problem also. Once intrusion happens and it makes it
way to a spot on the steel it will run down the inside of an epoxy coated
bar like it is a conduit for corrosion. Salt water infiltration in concrete
is best defeated by using a denser mix, say 5,000 psi concrete. Another
item we specify for high salinity conditions is MMFX steel, it is corrosion
resistant to the point that if left lying around outside it will look better
after a full year then standard grade 60 mild steel does directly off the
delivery truck. Current practice is to specify a minimum of 3" of concrete
cover on all steel when cast on the ground and 2" when cast in a form other
than soil. I would avoid concrete in a keel that is less than 6" from side
to side unless the 'form' remains in place permanently.
Caloosarat
_____
Allan Pickman
Sent: Wednesday, October 11, 2006 7:14 AM
Cc:BllFs6@...
Subject: Re: [bolger] Re: Keel on the Micro
All very true.
In northern climates they use epoxy coated rebar for highway bridge decks,
as the salt used for ice control tends to soak into the concrete, causeing
accelerated corrosion on teh steel.
Allan
in the hills
----BllFs6@...<mailto:BllFs6%40aol.com> wrote:
> In a message dated 10/10/2006 3:21:22 PM Central Daylight Time,
> donschultz@iname. <mailto:donschultz%40iname.com> com writes:
> "though you'd want to be cafeful to not include SOOO much rebar that
> the resulting structer was WEAKER than concrete alone...."
> Not much chance of that. Concrete is NOT very strong compared to
> steel. It is not very dense compared to steel.
> Yes....that is techincally true but not practically true....
> You can only get concrete so "thin" before it doesnt behave like concrete
> anymore...
> As an example....surround a piece of rebar with a thickness of 3 inches of
> concrete on all sides and that sucker will last forever...
> Surround same rebar with a thickness of 0.3 millimeters and within year
you
> will have a naked rusted piece of rebar....
> IFFFFF the concrete is the only thing holding the various pieces of rebar
> TOGETHER.....the thickeness of the concrete BETTER be enough to last
awhile
> before cracking and spalling....
> Which brings up another point....if I was putting said rebar in concrete
in
> a keel, particularly for a boat to be used in saltwater....I would coat
> rebar with something before putting it in the concrete.....a thin layer or
2 of
> epoxy and perhaps another one or two at the ends would probably be a good
> idea.....once enough water/oxygen/salt reaches the rebar and starts
creating
> rust your rebar/concrete maxtrix's days are numbered...
> Bllll
horses
(978) 282-1349
> - Unsubscribe: bolger-unsubscribe@
<mailto:bolger-unsubscribe%40yahoogroups.com> yahoogroups.com
> - Open discussion: bolger_coffee_
<mailto:bolger_coffee_lounge-subscribe%40yahoogroups.com>
lounge-subscribe@yahoogroups.com
Yes Bruce I know how heavy lead is. Try 94.5 lbs per
gallon. I also know how well it will flow when it's
hot. I have helped pour lead before and it's easy to
put to much lead in the pot when you are making
trolling leads. Most of the time you just want to get
the job done with.
Dad liked to load the pot so he could pour two 60 lb
leads at a time. The pot had handles on both sides of
it so two people could carry it when pouring.
Also at 94.5 lbs per gallon it doesn't take much of a
pot to do that. I think our pot was made out of an old
freon tank.
Blessings All
Krissie
> Be aware that the Micro keel is cast on its side, an
> inch and a half thick. It is much simpler to pour
> lead
> 'flat' than 'vertical', as lead is very heavy and
> when
> molten it has the viscosity of water but still
> weighs A LOT!
> (For instance, a piece of steel floats on lead like
> a cork.)
Do You Yahoo!?
http://mail.yahoo.com
--- Inbolger@yahoogroups.com, "9buck crowley" <buckcrowley@...> wrote:
> Funny that you suggest that. I have considered that option as
apparently
> there very effective in dealing with the size of wavelet that
creates the
> most noise.
> Buck
A larger fender or tire tube held in place by a stowage net and bridle
might work as well.
I regularly use an eye mask and ear plugs (along with a u-shaped
pillow) as I often sleep in airplanes, Walmart "campgrounds" and truck
stops in my travels. A hot toddy or... errr you know... also helps.
Nels (realizing this is a family forum:-)
Funny that you suggest that. I have considered that option as apparently
there very effective in dealing with the size of wavelet that creates the
most noise.
Buck
>From: "Joe Tribulato" <scsbmsjoe@...>
>Subject: [bolger] Re: micro pointing ability (bow chatter)
>Date: Tue, 17 Oct 2006 04:15:21 -0000
>I wonder if anyone has tried floating a pool noodle or two across the
>bow to reduce noise at anchor.
>Joe T
> > Graeme,
> > On a cruise last year on the Maine coast I tried sinking the bow by
>hanging
> > as much weight as possible off the bow and floating whatever was at
>hand in
> > front to dampen the waves but to little effect. Stern to side to was
>not any
> > better. I have some other ideas I'd like to try out but as of now I
> > haven't. One is the equivalent of (don't laugh) a car bra which
>could be
> > fitted at anchor across or more precisely under the bow. The "Broat"
>would
> > bridge the gap between the keel and chine and absorb the energy of the
> > wavelets. As you can see there have been a few sleepless nights
>devoted to
> > this. I've read here that some are not bothered by the sound my wife
>is one
> > of them. I myself want to be able to hear approaching traffic, fog
>horns
> > etc. which the the drip drap chatter under my head drowns out.
> > Buck Crowley
On 10/16/06, Kristine Bennett wrote:
> I know this is not as simple as what Phil has done for
> a keel but for someone like myself I could have it
> cutout and welded up and ready to pour the lead in 5
> to 6 hours.
inch and a half thick. It is much simpler to pour lead
'flat' than 'vertical', as lead is very heavy and when
molten it has the viscosity of water but still weighs A LOT!
(For instance, a piece of steel floats on lead like a cork.)
I've read how some have put fenders there like you suggest. IIRC it
wasn't entirely succcessful.
Gaeme
> Joe T
Buck,
as for myself it kind of comes and goes. Drifts in and out of
attention. It can be extremely annoying or virtually un-noticed. What
is unfortunate about that is that I can't pick and choose when, and so
have lost a bit of sleep myself. I reckon on a long enough cruise it
would become fully tuned out - like for people that live near busy
roads or airport approaches. Well, ...I hope that's the case.
As you can see there have been a few sleepless nights devoted to
is one
horns
Joe T
> Graeme,
hanging
hand in
not any
could be
would
devoted to
is one
horns
> Buck Crowley
Graeme,
On a cruise last year on the Maine coast I tried sinking the bow by hanging
as much weight as possible off the bow and floating whatever was at hand in
front to dampen the waves but to little effect. Stern to side to was not any
haven't. One is the equivalent of (don't laugh) a car bra which could be
fitted at anchor across or more precisely under the bow. The "Broat" would
wavelets. As you can see there have been a few sleepless nights devoted to
this. I've read here that some are not bothered by the sound my wife is one
of them. I myself want to be able to hear approaching traffic, fog horns
Buck Crowley
>From: "graeme19121984" <graeme19121984@...>
>Date: Tue, 17 Oct 2006 01:40:45 -0000
>A lot of gear would need be transferred to the forward well in Micro
>to have that deeply rockered bottom pitch enough to cut the racket.
>A flat iron bottom, as under the Cynthia J cabin, should be fairly
>quiet. Sleeping crew weight, well forward of the normal centre of
>bouyancy, there on the flat floor will cause positive pitch enough
>to sink the bow.
>Graeme
>--- Inbolger@yahoogroups.com, "Chester Young" <chester@...> wrote:
> > The curves are one dimensional, not compound. This generates a
>uniform
> > surface that is struck flatly all at one time by waves rolling
>under the
> > bottom, thus creating the sound heard inside. I noted earlier
>that
> > anchoring the Esther Mae stern to eliminates the majority of this
>sound. I
> > think it is due to allowing the wave to strike an oblique surface
>that is
> > more verticle but not facing the wave flatly. I should have said
>stern to
> > from one corner or the other, starboard or port. Thickness of
>plywood does
> > not seem to affect it, at least up to two sheets of 3/8".
> > Caloosarat
> > _____
>Behalf Of
> > Bruce Hallman
> > Sent: Monday, October 16, 2006 1:18 PM
> > Subject: Re: [bolger] Re: micro pointing ability
> > On 10/16/06, 9buck crowley wrote:
> > > At anchor the micro and I suspect all these flat bottom boats
>are pretty
> > > noisy down below.
> > I don't deny the reports of noise, though personally, I don't find
>the
> > noises annoying.
> > I do disagree that the bottom of the Micro is 'flat'. The Micro
> > bottom (and sides)
> > have a very deep and pronounced curvature. Perhaps the reason for
>the noise
> > reports is that the Micro is made of thin plywood which transmits
>noise
> > easily?
I know we have talked about keels for a Micro for some
time but I was doing some number crunching and came up
with this a 4 inch pipe 36 inches will hold 176 lbs of
lead and a 5 inch pipe 36 inches long will hold 231
lbs of lead.
I'm not sure how long the flat part of the Micro's is
but what would be wrong with putting a bulbed keel
under a micro, out of steel plate and pipe for the
bulb, and keep it the same profile? You would be about
the same weight over all but have more weight lower on
the keel.
to 6 hours.
Blessings
Krissie
Do You Yahoo!?
to sink the bow.
uniform
under the
that
sound. I
that is
stern to
plywood does
> Caloosarat
> _____
Behalf Of
> Bruce Hallman
are pretty
> > noisy down below.
> noises annoying.
> bottom (and sides)
the noise
noise
> easily?
On 10/16/06, Nels <arvent@...> wrote:
> for a forward companionway
This is a great addition to the design, allowing space for Port-a-potty.
Imagine that on a 16 foot long boat!
On 10/16/06, lancasterdennis <dlancast@...> wrote:
> Ok, I'll bite, what's the problem with Common Sense Designs?
There are questions as to whether or not CSD properly holds the right
to sell certain Bolger plans.
Bolger explained their position on this question in message 1250 on
this Yahoo group.
http://groups.yahoo.com/group/bolger/message/1250
Ok, I'll bite, what's the problem with Common Sense Designs? I
purchased my plans for the Shoe from them and so far so good.
Athough, the quality of the plan copies were not the best. It is my
intent to purchase my sails through them as well. Is there something
I need to be aware of here?
Dennis
- Inbolger@yahoogroups.com, "Nels" <arvent@...> wrote:
> Bolger and Friends have addressed this on most of their flat-
bottomed
> plan upgrades where one might sleep aboard.
> Referred to as a "no-slap pad added at the forefoot... built up
bread
> and butter fashion from scrap plywood." This I expect would add to
> hull thickness and deaden the drumming effect, as well as provide
more
> strength, additional buoyancy in the bow, and less pounding when
> motoring into a head sea.
> Not sure if it is in the regular Micro plans but anyone ordering
them
> should also request the latest Navigator upgrade. (DO NOT order
plans
> from Common Sense or Duckflat Boatworks!) It also includes drawings
> for a forward companionway and the mast on a tablernacle and
pointed
> bow as well as the end-plated rudder and some other goodies
worthwhile
> even if you build the standard version without a pilothouse.
> All this additional complication however, makes one wonder if it is
> all worth it on such a short waterline. The Long Micro already has
> some of these additions and is less complicated to build. The all
up
> weight and size is not that much different to trailer and you get a
> lot more boat for the buck invested in my opinion.
> Then there is Wandervogel, of which I would love to see plans
> finalized.
> Nels
Bolger and Friends have addressed this on most of their flat-bottomed
Referred to as a "no-slap pad added at the forefoot... built up bread
and butter fashion from scrap plywood." This I expect would add to the
hull thickness and deaden the drumming effect, as well as provide more
Not sure if it is in the regular Micro plans but anyone ordering them
should also request the latest Navigator upgrade. (DO NOT order plans
for a forward companionway and the mast on a tablernacle and pointed
bow as well as the end-plated rudder and some other goodies worthwhile
some of these additions and is less complicated to build. The all up
finalized.
The curves are one dimensional, not compound. This generates a uniform
surface that is struck flatly all at one time by waves rolling under the
bottom, thus creating the sound heard inside. I noted earlier that
anchoring the Esther Mae stern to eliminates the majority of this sound. I
think it is due to allowing the wave to strike an oblique surface that is
more verticle but not facing the wave flatly. I should have said stern to
from one corner or the other, starboard or port. Thickness of plywood does
Caloosarat
_____
Bruce Hallman
> At anchor the micro and I suspect all these flat bottom boats are pretty
> noisy down below.
I don't deny the reports of noise, though personally, I don't find the
noises annoying.
bottom (and sides)
have a very deep and pronounced curvature. Perhaps the reason for the noise
reports is that the Micro is made of thin plywood which transmits noise
easily?
> noisy down below.
noises annoying.
bottom (and sides)
reports is that the Micro is made of thin plywood which transmits noise easily?
Hi,
noisy down below. Even the smallest wavelets produce an amazing variety an
volume of sound. I'm sure there is a solution but my boat is three thousand
miles away which makes it hard to experiment with..
Buck
>From: "pdorc62" <pdorcey@...>
>Date: Sun, 15 Oct 2006 18:20:59 -0000
>Buck,
>Always interested in both building and sailing experiences in Micro. Would
>you elaborate
>on what you found to be Micro's one little fault? Thanks
> > Bill,
> > I can only speak about my boat which I mentioned tacks through 130
>degrees
> > and then only in good conditions. My feeling is that I must have some
>pretty
> > bad sails. I got them from Common Sense Designs about eight years ago
>when I
> > finished the boat so they've got some miles on them. I knew from the
>start
> > that the boat would not be a worldbeater upwind but recently I was able
>to
> > see that we were tacking through 130 degrees based on my gps track. I've
> > been asking around to see how other micros perform but nobody has given
>me a
> > definitive answe..One reason I suspect the sails is that streamers
>attached
> > to the leach don't stream but wrap around the leach on the windward
> > side..The other reason is that I also built a bolger surf which uses the
> > same type of sail and it goes very well to windward so its not sprit rig
> > that's the problem.
> > To answer your question my calculations tell me a boat that will tack
> > through 90 degrees (which I believe is average performance) will travel
>1.4
> > miles to move upwind 1 mile. My Micro needs to cover 2.36 miles to get
>to
> > the same spot upwind. Add in a little adverse current and I could and do
> > find myself going backwards. Now if new sails would get me tacking
>through
> > 120 degrees my 2.36 miles would become 2 miles which is much better.
> > I don't know how you plan on using your boat but if I were to do it
>again I
> > would build the Birdwatcher 1 for the following reasons
> > One. It requires no motor. Even the best motor stinks is noisy and
>requires
> > gas onboard. Oars on the other hand provide exercise which you generaly
> > don't get on a boat.
> > Two. You don't need a tender. My fifteen foot boat needs an eight foot
> > tender.
> > Three. Birdwatcher can dryout upright. This allows you to go were few
>boats
> > can up long estuarys and inlets the real pretty places on our coasts.
> > Four. It tows better. It's lower and lighter. It also launches easier
>and
> > faster.
> > All that being said I do love my micro Our family of four cruised in the
>Sea
> > of Cortez in it the San Juan Islnds and the coast of Maine as well as
>our in
> > home San Francisco. It is a nice little boat and has only one little
>fault
> > which I'll leave to another time.
> > Buck Crowley
> > >From: BllFs6@...
> > >Subject: Re: [bolger] micro pointing ability
> > >Date: Tue, 10 Oct 2006 13:08:06 EDT
> > >In a message dated 10/10/2006 10:09:49 AM Central Daylight Time,
> > >bruce@... writes:
> > >On 10/9/06, 9buck crowley <buckcrowley@...> wrote:
> > > > Hello,
> > > > Has anyone out there any first hand knowledge of the "Micros"
>pointing
> > > > ability. Mine which I feel was very well made, fair smooth etc.'
>tacks
> > > > through 130 degrees. That's not very good. I'm considering having
>new
> > >sails
> > > > made to see if that's the problem but I don't want to go to the
> > >expense if
> > > > the problem is with the design....
> > > > Buck
> > >I think mine points better than 130. The quality of the cut of the
> > >sail, plus your technique, matters. If I need to get to windward in a
> > >hurry, I use my motor.
> > >A Micro will never point as high as the expensive, high tech / high
> > >stress sloops. But the sloops lose when your goal is simplicity,
> > >comfort and ease.
> > >Hi guys..
> > >This brings up a point I've wondered about given that old shoe and
>micro
> > >are
> > >two of my favorite/most likely if anything to be built designs....
> > >Take a Bolger Micro,
> > >Now take a similar "normal" sailboat....nice commercial one say, but by
>the
> > >same token not a gold plated, state of the art, mega buck absolute best
> > >carbon
> > > graphite racing machine...
> > >Or in other words a nice commercial saiboat with similar length and
> > >breadth,
> > >a nice smooth "normal" shaped hull, a real proper fixed keel, modern
> > >"normal" sail set up, and about the same all up weight and load
>carrying
> > >capacity....
> > >Now, both boats are trying to run a course that is directly upwind,
> > >Obviously, they can't so they tack back and forth, going from "side to
> > >side" but
> > >overall they do make upwind progress...
> > >How does a Bolger Micro compare with the "normal" commercial boat? In a
> > >light wind or medium wind or strong wind?
> > >50 percent of the normal one? 75 percent as fast? 90?
> > >And allow for a tacking angle that allows for the fasted NET upwind
> > >progress
> > >for each rather than fastest "apparent" speed etc etc
> > >Forgive my lack of proper sailing terms...
> > >Blll
Buck,
Always interested in both building and sailing experiences in Micro. Would you elaborate
> Bill,
> I can only speak about my boat which I mentioned tacks through 130 degrees
> and then only in good conditions. My feeling is that I must have some pretty
> bad sails. I got them from Common Sense Designs about eight years ago when I
> finished the boat so they've got some miles on them. I knew from the start
> that the boat would not be a worldbeater upwind but recently I was able to
> been asking around to see how other micros perform but nobody has given me a
> definitive answe..One reason I suspect the sails is that streamers attached
> that's the problem.
> through 90 degrees (which I believe is average performance) will travel 1.4
> miles to move upwind 1 mile. My Micro needs to cover 2.36 miles to get to
> find myself going backwards. Now if new sails would get me tacking through
> I don't know how you plan on using your boat but if I were to do it again I
> One. It requires no motor. Even the best motor stinks is noisy and requires
> tender.
> Three. Birdwatcher can dryout upright. This allows you to go were few boats
> Four. It tows better. It's lower and lighter. It also launches easier and
> faster.
> All that being said I do love my micro Our family of four cruised in the Sea
> of Cortez in it the San Juan Islnds and the coast of Maine as well as our in
> home San Francisco. It is a nice little boat and has only one little fault
> Buck Crowley
> >From: BllFs6@...
> >bruce@... writes:
> > > Hello,
> > > Has anyone out there any first hand knowledge of the "Micros" pointing
> > > ability. Mine which I feel was very well made, fair smooth etc.' tacks
> > > through 130 degrees. That's not very good. I'm considering having new
> >sails
> >expense if
> > > Buck
> >comfort and ease.
> >Hi guys..
> >This brings up a point I've wondered about given that old shoe and micro
> >are
> >Now take a similar "normal" sailboat....nice commercial one say, but by the
> >carbon
> >breadth,
> >"normal" sail set up, and about the same all up weight and load carrying
> >capacity....
> >side" but
> >progress
> >Blll
That will be about a half inch from each end in a linear sense for
my Oldshoe keel. I'll know sometime next week. Thanks for that
input of info Bruce. I can shave down my wood plug to match the
lead and mock up my frame that way. Planning on using lots of googe
and shims if necessary, paying close attention to the slot that will
fit over my keelson... needs to be kept clear.
Dennis
Bellingham, WA
-- Inbolger@yahoogroups.com, stuart crawford <scrawford@...> wrote:
> Shrinkage is 1/8" to the foot with lead.
> > From: Bruce Hallman <bruce@...>
> > Date: Sun, 15 Oct 2006 09:00:22 -0700
> > Subject: Re: [bolger] Re: Keel on the Micro/Oldshoe
> > On 10/14/06, lancasterdennis <dlancast@...> wrote:
> >> Yes, the foundry explained that... shrinkage will be in length
> >> height, but not much in thickness.
> > Be aware that lead is soft, soft enough to be cut with a wood
saw. My
> > casting was a inch off in shape to match the curvature of the
bottom
> > of the hull, and I just cut it to shape with the Skilsaw.
flogging dead horses
Fred' posts
away
01930, Fax:
> > (978) 282-1349
> > Yahoo! Groups Links
Power planers work well on lead. You can build the mold a little bigger than
needed, then plane the lead down to the right size rather easily, except
where bolts extend through the surface and in those places you can use a
chisel.
Note that the planer blades should be carbide ... and sharp.
Kenneth Grome
Bagacay Boatworks
www.bagacayboatworks.com
On Saturday 14 October 2006 23:21, John Kohnen wrote:
> The lead will shrink in the mold as it cools, so �
> your ballast will be a bit smaller than the wooden pattern. I can't seem �
> to find the right search terms for a 'net search for the percentage to �
> expect, but it's out there somewhere I'm sure. The shrinkage is probably �
> small enough to handle with thickened goo, or maybe shims.
Joe,
Tks, got the picture now. We are on the same page. I will look for
that 3/4". The taper on the edges is something I was thinking about
doing or filling with googe. I have bronze ring nails and was
intending to use them on the keelson... soft though and I think may
need a pilot hole. I'm using stainless, squarehead screws for most
of my assembly.
Dennis
Bellingham, WA
> Dennis
> I like butt blocks. Yes, bevel all edges. They look to me like they
> will not fail.
> On my bottom the two butt blocks were very close to the ends of the
> foot well, about .75 in. shy which I filled in with a bit of ply.
> That's where I used galvinized carriage bolts through the keel
strip.
> The rest of the keel strip was drawn tight with screws. Again, in
> addition to bronze ring nails, I don't see any problem using
> galvinized screws and bolts thruout unless you are building a gold
> plater, cost be damned.
> --- Inbolger@yahoogroups.com, "lancasterdennis" <dlancast@> wrote:
> > Hi Joe,
> > ... I am a bit confused as what you mean by bolts through
> > the two butt blocks.. could you explain that for me please. I
know
> > that the bottom panels will be butted and a butt block used, as
will
> > the side panels. Some builders have gone without the blocks and
> > reported success.. however, I believe one used addtional
stringers
> > for hull side strength. Are we talking about the same thing?
> > I made my tiller today. Had a nice hunk of mahogany and got the
> > stick out just fine, very happy with it.
> > Regards,
> > Dennis
> > Bellingham, WA
> > -- Inbolger@yahoogroups.com, "Joe Tribulato" <scsbmsjoe@> wrote:
> > > Dennis
> > > Be aware that the lead casting will shrink some. Your foundry
can
> > > probably supply particulars.
> > > Glass the bottom first. Epoxy, bolts through two butt blocks
> > > screws for keel strip. I just used epoxy and ring nails
closely
> > spaced
> > > to attach the keel cheeks to the keel strip. Ring nails for
all
> > other
> > > attachments to keel and blocking. No need to drill for ring
nails.
> > > Joe T
>> Yes, the foundry explained that... shrinkage will be in length and
> Be aware that lead is soft, soft enough to be cut with a wood saw. My
> casting was a inch off in shape to match the curvature of the bottom
> (978) 282-1349
Dennis
will not fail.
That's where I used galvinized carriage bolts through the keel strip.
--- Inbolger@yahoogroups.com, "lancasterdennis" <dlancast@...> wrote:
> Hi Joe,
> the two butt blocks.. could you explain that for me please. I know
> that the bottom panels will be butted and a butt block used, as will
> reported success.. however, I believe one used addtional stringers
> Regards,
> Dennis
> Bellingham, WA
> > Dennis
> > Be aware that the lead casting will shrink some. Your foundry can
> > Glass the bottom first. Epoxy, bolts through two butt blocks and
> > screws for keel strip. I just used epoxy and ring nails closely
> spaced
> > to attach the keel cheeks to the keel strip. Ring nails for all
> other
> > attachments to keel and blocking. No need to drill for ring nails.
> > Joe T
Sounds like a good plan. The lead will shrink in the mold as it cools, so
small enough to handle with thickened goo, or maybe shims, but it's worth
checking.
On Sat, 14 Oct 2006 08:54:21 -0700, Dennis wrote:
> My plan is to build the boat upside down on a strong back. After
> the bottom is on and the keelson in place, I will build the keel and
> using the wood plug that I made for the ballast casting, dry
> assemble the keel and test fit it to the hull. I will predrill my
> screw placements to the keelson, then insert the lead ballast and
> finish up the keel. At that point, the keel will be lifted into
> place and screwed down with lots of thickened epoxy. After, proper
> fillets will be added to the keel to hull seam. At least this is my
> plan....
John <jkohnen@...>
I cannot help thinking that the people with motor boats miss a great deal.
If they would only keep to rowboats or canoes, and use oar or paddle...
they would get infinitely more benefit than by having their work done for
them by gasoline. <Theodore Roosevelt>
Hi Joe,
height, but not much in thickness. I will take that into account
when I do my mock-up. Most certainly, the bottom will be glassed
with epoxy. I am a bit confused as what you mean by bolts through
Dennis
Bellingham, WA
> Dennis
spaced
other
> Joe T
> > I have been following this thread with great interest. My Shoe
is
> > just a smaller version of the Micro, the lead being about half
> > weight at 200lbs. I was at first concerned that there were no
keel
> > bolts to hold that lead to the boat, but am now convinced that
> > Bolger's method of attachment is sound and does work. In fact, I
> > believe that when that keel is finally on, it will be rock
solid.
After
my
proper
is my
> > plan....
> > Fairwinds,
> > Dennis
> > Bellingham, WA
Cutting the edges of your butt straps at 45 degrees, or just
chamfering them a bit then adding an epoxy fillet will prevent them
from trapping dirt. They will wipe clean as easily as the rest of
the hull.
Jamie
> Hi
> If it's not to late I'd suggest eliminating those butt splices in
favor of
> another splicing method mine trap dirt and water and add to the
wor kof
> keeping the boats interior clean.
> Buck
> >Subject: [bolger] Re: Keel on the Micro/Oldshoe
> >Date: Sun, 15 Oct 2006 02:11:53 -0000
> >Dennis
spaced
other
> >Joe T
Shoe is
keel
I
solid.
After
keel and
predrill my
into
proper
is my
> > > plan....
> > > Fairwinds,
> > > Dennis
> > > Bellingham, WA
Hi
If it's not to late I'd suggest eliminating those butt splices in favor of
another splicing method mine trap dirt and water and add to the wor kof
Buck
>Dennis
>screws for keel strip. I just used epoxy and ring nails closely spaced
>to attach the keel cheeks to the keel strip. Ring nails for all other
>Joe T
> > I have been following this thread with great interest. My Shoe is
> > just a smaller version of the Micro, the lead being about half the
> > weight at 200lbs. I was at first concerned that there were no keel
> > believe that when that keel is finally on, it will be rock solid.
> > plan....
> > Fairwinds,
> > Dennis
> > Bellingham, WA
Dennis
Joe T
> plan....
> Fairwinds,
> Dennis
> Bellingham, WA
In a message dated 10/13/2006 5:39:51 PM Central Daylight Time,
femmpaws@...writes:
Blessings Krissie (feeling like a bimbo today)
I almost always feel like a bimbo.....but they never seem to be around when
I want one...
sorry..just couldnt help myself with that one :)
Blll
Now am I understanding right there are areas in the
Micro's keel that are free flooding?
This is not a good thing! There are a number of water
borne critters that could be moved from one place to
another in that space! Zibra Mussles are the first to
come to mind and I know there are others as well.
There are also a number of plants that can be carried
that way as well.
If you look around you can get some very fine sand
blasting sand that you could mix in epoxy to fill the
voids. The idea of having the craft on her side when
you are putting the lead in the keel sounds like a
good time to fill the voids as well. The other thing
it would also add a few more Lbs of weight in the keel
as well. The other nice thing is the stuff is cheep
like 20 bucks a 100 lb bag. The stuff is about like
corse flower.
Just an idea how to control the water and rot before
it gets in the keel.
I also think a good name for a sail boat would be
Bimbo, or Air Head, as well. LOL
Blessings Krissie
Do You Yahoo!?
plan....
Fairwinds,
Dennis
Bellingham, WA
> Bruce
> I put on most of my keel when with the boat upside down by this I
mean the
> keel stringer all solid wood and one half of the sheathing. After
that I
> rolled the boat over onto it's side supported the boat and keel
structure
> and jacked the lead casting up onto high horses even with the
keel. Getting
> the lead up to that height is just a matter of incrementaly
raising one end
> then the other and if your suppports are in about a third of the
way from
> the ends your never really lifting much at any one time. Now with
the lead
> level and just a little higher than the ply I put on a heavy load
of epoxy
> and slid the lead over into place. After that it was more epoxy on
the top
> of the casting and framing and the remaining ply was nailed into
place. The
> remaining nails into the lead (underside) were driven when the
boat was
> upright. I'm sure there was plenty of hand wringing but I don't
recall any
> drama.
> Buck
> >From: "Nels" <arvent@...>
> >Date: Sat, 14 Oct 2006 14:25:54 -0000
> >--- Inbolger@yahoogroups.com, "dnjost" <davidjost@> wrote:
> > > Bruce -
> > > I had forgot that he did not do the sheathing but instead did a
> > > traditional deadwood arrangement. In either method there is
concern
> > > over time of rot getting in. I put several coats of epoxy on
the wood
> > > in this area to attempt to put off decaying of internal wood
members.
> > > Only time will tell if this was sufficient. Nothing a Sawsall,
> > > electric plane, and some ingenuity could not solve.
> >With the traditional method I doubt if one would need a saw to
make
> >changes. It all comes apart - if and only IF the sikaflex lets
go. Any
> >idea how long that stuff keeps it's sealing properties?
> >Even back in those days Peter was using his "dish jointed" method
> >sealing joints together. That is, dishing one of the joint
connection
> >areas with a grinder to prevent glue or sealing compound squeeze
out.
> >Photo #11 at this link shows him dishing the top of the keel.
>http://www.duckworksmagazine.com/00/DM1999/articles/micro/index.htm
> >I think the biggest challenge is drilling the holes for the
deadwood
> >accurately. Peter did it by hand and had no problems.
> >Hopefully as long as the keel bolts are kept tight, and the
sikaflex
> >and barrier coat keep out the moisture, it should last a long time
> >without rot setting in. If not, it all comes apart.
> >Nels
Bruce
I put on most of my keel when with the boat upside down by this I mean the
keel stringer all solid wood and one half of the sheathing. After that I
rolled the boat over onto it's side supported the boat and keel structure
and jacked the lead casting up onto high horses even with the keel. Getting
the lead up to that height is just a matter of incrementaly raising one end
then the other and if your suppports are in about a third of the way from
the ends your never really lifting much at any one time. Now with the lead
level and just a little higher than the ply I put on a heavy load of epoxy
and slid the lead over into place. After that it was more epoxy on the top
of the casting and framing and the remaining ply was nailed into place. The
remaining nails into the lead (underside) were driven when the boat was
upright. I'm sure there was plenty of hand wringing but I don't recall any
drama.
Buck
>--- Inbolger@yahoogroups.com, "dnjost" <davidjost@...> wrote:
> > Bruce -
> > traditional deadwood arrangement. In either method there is concern
> > over time of rot getting in. I put several coats of epoxy on the wood
> > in this area to attempt to put off decaying of internal wood members.
>With the traditional method I doubt if one would need a saw to make
>changes. It all comes apart - if and only IF the sikaflex lets go. Any
>Even back in those days Peter was using his "dish jointed" method of
>sealing joints together. That is, dishing one of the joint connection
>areas with a grinder to prevent glue or sealing compound squeeze out.
>I think the biggest challenge is drilling the holes for the deadwood
>Hopefully as long as the keel bolts are kept tight, and the sikaflex
>Nels
> Bruce -
Bruce -
I did my keel exactly the same way as you described. It was when the
assembly tipped over and hit me on the shoulder (putting me out of
commission for a while) that I realized that Peter's method had some
real advantages! Once the bolts are in the holes the keel is then
stablized.
For those thinking of the welded steel box approach, I will have to
say that building the wooden mold, and taking it to the foundry was a
very, very easy step and not cost prohibitive. I came back with a
real nice lead ballast slug. They mixed the proper amount of antimony
into the mix to give the keel good stiffness yet allow the driving of
the fastenings.
> This method has the advantage of sparing you the need
> to waterproof extra bolt holes through the hull bottom.
> I hindsight, a piece of cake!
> (In truth, a little awkward, but not too bad)
Greg,
If you can swing it, IMHO, the multichined Piccup will be better for
this. Traffic and wind against tide on the Col can generate some
quite hairy conditions for which it's better suited.
On Oct 13, 2006, at 8:44 PM, greg marston wrote:
> Its funny this boat is mentioned, I am thinking of building this
> boat some time before next summer,piccup squared, for fishing and
> sailing in the Columbia River and coastal bays.
> Greg
Its funny this boat is mentioned, I am thinking of building this boat some time before next summer,piccup squared, for fishing and sailing in the Columbia River and coastal bays.
Greg
--- Inbolger@yahoogroups.com, "John Kohnen" <jhkohnen@...> wrote:
> If you can stand stitch 'n' goo construction I think Jim Michalak's
Piccup
> Pram is a dynamite boat for a newcomer to sailing:
>http://www.duckworksbbs.com/plans/jim/piccup_pram/index.htm
There is also a Piccup Squared version that goes together using nails
and glue:
http://www.duckworksbbs.com/plans/jim/piccup_squared/index.htm
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
> > the free-flooding sections of the keel.
> <Tongue in cheek>
> The free-flooding keel amounts to a small amount of water ballast
down low.
> Putting buoyant wood below the waterline degrades the stability curve
> somewhat. <smile>
> (can you tell I believe in building 'per the plans'?)
There is added lead at each end of the keel that allows for that:-)
What a great name for a Cruise-a-Home.
Bryant (feeling naughty)
LOL! Nels your last comment just made me laugh and
being willing to crew for me.....Hmmm I know I have a
whip here some place...
I may have found an inboard Diesel for my big boat. So
I may have to put building small boats on hold till I
get her ready for the water. For those in the
Northwest or if you want to know the hull is a
Cruise-a-Home hull. They are noted to be a good rough
water hull.
When I say big she is 40 x 12 foot beam, fiberglass
hull. If things work out the cabin layout will be
close to that of the Watervan. But I plan to rase the
helm and dinnet area so it will be at deck line. And
I'll have aft deck space! Deck space is a MUST have on
any boat I own. And it's the only draw back to the
Fiddle II and the Watervan. When it's just humans they
are fine but hen you add the four legged family
members well you need some place to shoo them when you
are fixing meals at least it's that way with my two
Malamutes.
> Or one could carry a Piccup pram for occasional
> sailing forays.
> You build one and I will volunteer to crew;-)
> Nels (aka Bimbo Boy)
Do You Yahoo!?
<Tongue in cheek>
The free-flooding keel amounts to a small amount of water ballast down low.
somewhat. <smile>
On 10/13/06, dnjost wrote:
> it was a major chore to move a 300 lb lead slab into place.
Daunting, but...
I installed mine (sorry no pics) by building a simple rack to
hold the lead upright on a plywood 'sled' .
I then rolled this plywood 'sled' into position using pipe rollers
(2 foot pieces of electrical conduit.)
Then, with shop jacks, I lowered the hull down just right, and
[the hard part] while lying on my side, I nailed the plywood
keel facing into place, driving nails directly into the lead per
the design.
> Peter Lenihan did a great job chronicling his building of the Micro
> keel for Lestat. If I were to do it again, I would use his method as
> Keel bolts would have definately helped. Raise the boat up. Slide the
> keel under. raise the keel with jacks til the bolts rise up through
> the hull, and screw it down with tons of bedding compound. Then the
> sheathing could be done at a leisurely pace.
> David Jost
Hi David,
There is no sheathing on Lestat's keel, which was traditionally built.
Also there are no free-fooding areas in the keel, but solid mahogany
laminated deadwood fore and aft of it, and additonal keelbolts (and
bedding compound)through the deadwood as well. This allows the
keelbolts to be snugged up if necessary.
I think either method works equally well except for the concern of
growth or rot in the free-flooding sections of the keel.
A little lat, but thats OK.
Hello Kristine. I would agree with eheins wholeheartedly. I started
my sailboat quest with the Paradox. I bought the plans, and spent
hours in preparation to build. In the end, I got desperate and
bought myself a Venture 17. I did this because I started to worry
about the fact that I might end up spending thousands of dollars only
to find out I did not like to sail, or I did not like the boat. I
ended up buying my boat for $1500 and learned to sail using it. Now
I know I love to sail, and I have a much better idea of what type of
boat I want. I'm no longer planning to build a paradox (it's a great
boat!) because I have a much better idea of what I really want.
I would suggest asking around and and getting on someone elses boat
as "crew" even if it's just a few hours at a time. You'll gain a
huge amount of knowledge in the process. The internet is also a
great place to learn about this as a hobby. The folks at various
groups Microcruising, paradox, Bolger have been very helpful.
Good luck in your quest. It's not the finish, it's the journey that
counts.
Chris Curtis
On Oct 12, 2006, at 7:25 AM,eheins@...wrote:
> Kristine,
> Welcome to insanity, where we spend significantly more to build
> something with significantly less resale value than we could buy on
> the
> used or new market. Having said that, there is some safety in
> numbers and
> there's a number of us around that fit the description.
> A couple things to think about. I started down the road by building
> one of Jim Michalak's dinghy designs. Jim Made the point that the
> dinghy's are an easy way to get familar with reading the plans, and
> the skills needed to build, as well as the fact that with most boats,
> evben those like the Micro that can get into relatively shallow
> water, a dinghy is real convenient.
> My 8 ft sailing dinghy took about 80 man hours to complete just for
> reference. It doesn't sail poorly at all, and I use it a lot. From
> the dink, I decided to move up to the 20' Chebacco and took over a
> still upside down hull project from Burton Blaise up in Canada. That
> was 1998. I launched the Chebacco in 2004. So well, the math seems
> to be rather logrithmic in nature. 8ft = 80 man hours 20 ft = 7
> years. Of course I moved house several times and had the normal life
> things happen during that time, but the point remains, that I
> certainly recommend starting small and finding out if you like doing
> this and maybe even getting to use the finished product in a
> reasonable amount of time.
> Last suggestion, is to not confuse sailing, learning to sail, and
> boatbuilding necessarily. Find a friend with a sailboat, rent a
> daysailor, or buy a used production boat to learn to sail. That's all
> about fresh air, salt spray and the wind in your hair and it's great!
> Build your boat when you discover what kind of sailing you like,
> and what
> kind of boat would best suit that. Theres almost as much difference
> between sailing my dink and the Chebacco as there is between
> sailingthe
> Chebacco and a 40ft production yacht. I like them all but differently.
> Then when you start building, it's all about sawdust, epoxy fumes
> and gunk
> in your hair. That's not bad either, but it's two different things.
> Cheers mate & welcome aboard.
Chris Curtis
Sandpoint Computers
Office 208-265-1608
Cell 208-610-3062
Yes...now that I recall, my Micro did have a bit of an eddy coming off
the keel. It seemed to sail better loaded too. (obvious comment on the
skipper and crew being loaded, deleted).
Good luck, all this boat talk has me thinking of getting a load of fir
to start on Birdwatcher's mast.
> I keep coming back to when I have time to get away
> it's may be for 2 to maybe 3 days and even living in
> the San Juan Islands you can't get far in that amount
> of time. So that brings we back to going power.
Hi Krissie,
Have you looked at Fast Motorsailer which was designed specifically
for the Pacific northwest? Here is a link to the motor version:
http://www.ace.net.au/schooner/fms.htm
There is a write-up in BWAOM and also an upgraded sail plan article
that appeared later in MAIB. A cartoon of the two sailplans are in the
Bolger Cartoons group files.
http://tinyurl.com/y4jerv
Or one could carry a Piccup pram for occasional sailing forays.
There you have it in a nutshell how easy it is to get
in and out of the water! A friend of mine and I were
talking and he use to be out on the water all summer
after work. His shop was a mile to the ramp. Well he
moved the shop almost 3 years ago and the boat has not
seen the water in that time. At his old shop all he
had to do was back up and hook up and go. Well not now
it's a major hassle to get the boat out. So there it
sits.
I would guess in the summer the Piccup could be sailed
all over most of the islands in the summer time. and I
do have a little 2 hp for when the wind is dead. Some
people say rowing is good for you too but not if you
have messed up shoulders!
Blessings all Krissie
PS, Some of you may wonder why I use Krissie well some
years ago a friend stared call me that and it stuck.
So no I'm not a bimbo! LOL But there are times when I
do act like one. Hey guys remember it's not just the
female gender that are prown to being bimbos! :)
> Piccup is just for sailing around in sheltered
> waters, but it's quick,
> cheap and easy to build; quick and easy to launch
> and rig for sailing;
> quick and easy to retreive; easy to trailer (or even
> cartop) wherever you
> want to sail. If you build a Piccup, or one of
> Bolger's small instant
> sailboats, you'll be out sailing soon. :o) If you
> like sailing (it's hard
> to imagine, but some people don't take to it
> <shrug>) you can start a more
> ambitious sailboat project. I'll bet you'll still
> use the Piccup a lot
> after your bigger, more seaworthy, but harder to
> launch and rig, cruising
> boat is done. <g>
> On Wed, 11 Oct 2006 20:55:14 -0700, Kristine wrote:
> > With all this talk about sailing it has got me to
> > thinking about MAYBE learning to sail and building
> a
> > sail boat. (did I just say that???!!)
> > So if I do deside to build a sail boat any ideas
> for a
> > first time sailor? To be honest one of the Micros
> fits
> > my idea of what I would look for in a boat. But
> how
> > does one deside what to build? I like tack and
> tape or
> > stich and glue. I don't care to work with all the
> > little battens needed to put a hull together.
> John <jkohnen@...>
> Never put off until tomorrow what you can do the day
> after tomorrow. <Mark
> Twain>
> thanks, Fred' posts
> and snip away
> - Open discussion:
Do You Yahoo!?
Here is a table I came across showing test results for several boats,
notably from the Compac family of sailboats.
The results are not all that impressive regarding designs that are
touted to be quite capable judging from the advertising.
Especially the Compac 16:-)
http://www.ipass.net/sailboat/bttests.htm
Piccup
and glue:
If you can stand stitch 'n' goo construction I think Jim Michalak's Piccup
Piccup is just for sailing around in sheltered waters, but it's quick,
cheap and easy to build; quick and easy to launch and rig for sailing;
quick and easy to retreive; easy to trailer (or even cartop) wherever you
want to sail. If you build a Piccup, or one of Bolger's small instant
sailboats, you'll be out sailing soon. :o) If you like sailing (it's hard
to imagine, but some people don't take to it <shrug>) you can start a more
ambitious sailboat project. I'll bet you'll still use the Piccup a lot
after your bigger, more seaworthy, but harder to launch and rig, cruising
boat is done. <g>
> thinking about MAYBE learning to sail and building a
> So if I do deside to build a sail boat any ideas for a
> first time sailor? To be honest one of the Micros fits
> my idea of what I would look for in a boat. But how
> does one deside what to build? I like tack and tape or
John <jkohnen@...>
Never put off until tomorrow what you can do the day after tomorrow. <Mark
Twain>
All of you bring up good points and ideas. Thank you!
It just so happens I know a few that sail up here as
well.
Sailing has it's strong points and it's down sides as
well. As does power boating.
Something like the Fiddler II at about 22 feet with an
aftdeck and a box keel. I have no dought that 55 HP
will get it up to 20 or so and I have the outboard.
When I was reading 30 odd boats PB was worried about
the bottom being to limber. Well flash forward 30
years and look at all the good foams that you can use
now! plywood with a foam core bottom sounds like a
very good idea to me.
I'm not worried about the building I've done that.
Reading the drawings or prints not a big deal there I
use to draw them and have 2 years in school drafting.
Also having worked in a "jobshop" you were handed shop
drawing and told to make it. Let me tell you fixing an
oops in wood is a lot easer to hide then in Stainless
Steel let me tell you!
If you would like to see some of the stuff I make look
at Nordic Tug's website. The shop I work in does all
of their stainless rails. The welds have to be nice
before the tubing/rails are buffed. There are a number
of rails and ladders on the boats that were my design
to fit their needs. I have to say working at the shop
can be a lot of fun when you are given just some crude
drawings that may or may not have all the info needed
to make the part. Then make a pattern and work out all
the bends and where to put them and them make them in
tube. Then when you go to a boat show and tell them
they are walking on YOUR boat because it has your
rails on it is a good feeling. If you can't tell I do
take great pride in doing things well.
Gee this is a long rambling post I'm sorry!
Well when most of you read this post it will be the
start of your weekend! I do hope you have an enjoyable
and safe weekend!
Blessings Krissie
Do You Yahoo!?
> David,
> I was under the impression that with the hard chine and box design,
> the Micro or Shoe or others, actually present a keel profile when
> heeled.
From what I undestand, when a Bolger designed sharpie is heeled the
waterline length increases a bit and makes for a somewhat faster hull
- in theory anyway. And the immersed chine offers added resistance to
preventing leeway.
But there are other factors involved too, like the wave conditions and
the wind strength, the overall weight and the rudder balance. I
believe Bolger now recommends an end plate on the rudder of the Micro
like the Long Micro has.
If the hull is not down to it's DWL and there are two heavy people in
the stern it will affect the upwind ability noticeably too.
Probably if 5 Micros were all sailing together there would be some
variation between them all dependant on the intuitve experience of
each skipper, the cut of the sails and how clean the hulls are.
Even the depth of the water can affect the sailing characteristics.
I would bet that properly cut new sails will improve the performance
any way you look at it.
David,
heeled. Of course, its not a deep keel, so yes, leeway would be an
issue.. I guess what I'm trying to say is does she track better on
the flat as compared to heeling because of the depth and shape of
the actual keel as compared to the chine as "keel". One tends to
sheet in when going to weather and flatten the main a bit more.. are
things different with the sprit sail design..? something new to me
for sure. I guess this hull design is just what it is an one cannot
expect pointing high and no leeway. I'm not afraid to kick the motor
on if I need to get somewhere. I'm thinking about he lake I plan to
sail on when I do finish my Shoe. She is long an narrow and the
prevailing winds will have running downwind wind to start and then
beating and tacking to return...hahaha.. I may have to motor home.
Dennis
Bellingham, WA
> Buck -
> The best way to get this was to sail the boat absolutely flat!!!
Do
> not heel. And try your best to prevent oversheeting. This really
is
> a catboat with a mizzen. Leeway is hard to measure. But, there
is
> considerably more leeway with 20 degrees of heel vs. none.
> > At the risk of beating this to death did that 110 degrees
include
> leeway.
> > Your figure of 110 is about what I would have expected and would
be
> a huge
> > improvement on what I've been doing..
Buck -
The best way to get this was to sail the boat absolutely flat!!! Do
not heel. And try your best to prevent oversheeting. This really is
a catboat with a mizzen. Leeway is hard to measure. But, there is
> At the risk of beating this to death did that 110 degrees include
leeway.
> Your figure of 110 is about what I would have expected and would be
a huge
Greg
Thanks for jumping in. Didn't you have a micro at one point ? If so did you
ever quantify its tacking angle? I'd love to try your suggestion for
troubleshooting the sail but unfortunately the boat lives on the east coast
(Maine) and I live on the west. I've had the sails looked at. The mizzen is
shot because it's always up and the main is stretched at the luff opposite
the snotter attachment point but the sailcloth still feels relatively crisp.
The question for me is how much better would she sail with new sails.
One other question I have for micro owners is does your boat trail a
substantial vortexs off either the lower corner of the rudder or the heel of
the keel ?
Thanks
Buck
>From: "ghartc" <gregg.carlson@...>
>Date: Thu, 12 Oct 2006 21:42:08 -0000
>Excellent advice. The Micro is especially sensitive to well-cut
>sails, being a short waterline displacement boat, with a low aspect
>rig, and an inefficient keel. All the things that make it otherwise
>handy (and charming). It's also sensitive to pinching/leeway as the
>keel just doesn't provide the lift a deep, high aspect keel can.
>I would definitely look for a local loft that understands wooden boats
>and unusual boats, if you can. If they are good, they will at a
>minimum ask you a lot of questions mail-order types won't - and
>hopefully even have a look at the boat. As a compromise, Sailrite
>(caveat - they use my cutting machines) will probably have good canned
>designs for Micros as they've cut them more than once. But there's
>nothing like the local old salt sailmaker.
>Old sails get blown out, and the draft increases, which in itself
>isn't bad - the micro needs power - but it will also move back,
>turning the sail into more of a bucket than a wing. The leech carries
>a lot of load and gives up eventually (tarps almost immediately). A
>new suit of sails not only make you go faster, but you'll point higher
>- often a lot higher.
>Here's something cool you can do if you want to be scientific. Tape
>some horizontal bars across your sail in one or more places
>(sailmakers have sticky dacron for this, but electical tape might do,
>file). Go to my wesbite at www.carlsondesign.com, scroll down to the
>shareware and download the Sail Analyzer (it's free). You can use it
>to determine you sail's max draft, draft position, and entry and exit
>angles. That way you can tell exactly what your sail's doing "in
>flight" and seem really smart when you talk to your sailmaker.
>Gregg Carlson
> > > Choose a local sailmaker, because you need a
> > > face to face relationship with your sailmaker.
> > Great discussion on Micro pointing. My Micro would tack within 110
> > degrees, but no higher. a chop widened it a little more to the point
> > that if I really needed to get there, I put the motor on. Nantucket
> > sound usually features a decent SW chop on most summer afternoons.
> > The boat went great in Salem sound, and on Boston Harbor!!!
> > that said, the leeway increases as you point higher,but any deeper
> > with the keel and you would have a bear of time getting it on and off
> > the trailer.
> > I had a ball with my Micro, but sold it due to time constraints and
> > family interest. Since then, I have learned how to make sails.
> > Contact Sailrite kits and have them put something together for you.
> > Learning how curvature is put in a sail is really very worthwhile for
> > anyone who loves to sail.
> > Birdwatcher plans still sitting in the tube with a half finished
> > model done. Hopefully will start in earnest over the winter with
> > some pre-fabbed parts in the basement.
> > David Jost
> > " got another year out of Pointy Skiff!!! The boat looks and runs
> > great after much,much,much, epoxy filler and glass.
Gregg Carlson
> the trailer.
> David Jost
David,
At the risk of beating this to death did that 110 degrees include leeway.
Your figure of 110 is about what I would have expected and would be a huge
Thanks
Buck
>From: "dnjost" <davidjost@...>
>Date: Thu, 12 Oct 2006 16:52:13 -0000
>the trailer.
>David Jost
On 10/12/06, Nels <arvent@...> wrote:
> My other observation is to stick with the plans - no matter what - for
> the first build.
I have built about a dozen Bolger boats, (lost count), and I can say
from experience that almost always when I have tried to 'improve' by
deviating from the plans, my change results in unintended
consequences, for the worse, and taking added time and cost.
> Ok I have been reading about the Micros and the Long
> Micros. I would like to know what differs beween the
> two?
Looks like you already have some great advice from some great people.
I would like to add two additional observations.
According to Phil and Susanne, Long Micro is more capable due to it's
longer W/L (by about 33%) for off-shore passages. It essentially has a
4 ft. by 6 ft. by 4 ft. extra section amidships that adds
considerabley to it's capacity and ability without too much difference
in trailerability - which is about the limit of what I feel is a
one-person job. (Preferably two.) It also can handle a larger motor
which makes it somewhat of a motorsailor.
the first build. If you prefer stich and glue then choose a stitch and
glue design.
Dynamite's website is invaluable as a resource for bang-for-the-buck
regarding Bolger designs. Consider Elegant Punt if you decide on
instant boat method and Nymph if you want to try tack and tape. (Both
are equally elegant:-) Then when you build the big one and you have a
tender for it.
For all around day sailers consider Surf in the instant method or
cartopper in the tack and tape. Then it all gets overwhelming after
that and a person gets kinda crazy:-)
http://instantboats.com/
Hello Kristine. I would agree with eheins wholeheartedly. I started my
sailboat quest with the Paradox. I bought the plans, and spent hours in
preparation to build. In the end, I got desperate and bought myself a Venture
17. I did this because I started to worry about the fact that I might end up
spending thousands and hundreds of dollars only to find out I did not like to
sail, or I did not like the boat. I ended up buying my boat for $1500 and
learned to sail using it. Now I know I love to sail, and I have a much better
idea of what type of boat I want. I'm no longer planning to build a paradox
(it's a great boat!) because I have a much better idea of what I really want.
I would suggest asking around and and getting on someone elses boat as "crew"
even if it's just a few hours at a time. You'll gain a huge amount of
knowledge in the process. The internet is also a great place to learn about
this as a hobby. The folks at various groups Microcruising, paradox, Bolger
Good luck in your quest. It's not the finish, it's the journey that counts.
Chris Curtis
Kristine,
something with significantly less resale value than we could buy on the
used or new market. Having said that, there is some safety in numbers and
the trailer.
Krissie,
I won't repeat the good advice you have already received about how to get
into sailing, but would suggest that Hot Chili would not be a good starting
project. For one thing it is a new design and none have been launched yet
to prove it will be a good boat. If you want a small cat with a cabin, you
should look at the Jarcatshttp://www.members.optusnet.com.au/rhturner1/
which have had hundreds built and sailed for many years. But that would be
a bit too much of a starter project too. Of the boats you mention, I'd
choose the Micro, but personally, for ease of trailering and storage, I'd
look at other Bolger and Michalak designs with shallower draft.
The important thing is to get on the water and sail. Perhaps you could post
a note on bulletin boards in Roche Harbor and Friday Harbor offering to
crew. Often sailors will take a novice along for company, or need crew for
a race. The hardest part of deciding on a boat is deciding exactly what
type of sailing you are going to really do: daysail in the harbor? cruise
the islands? Inside Passage? just in the summer, or winter too? Cartop,
trailer, or marina? That's why a lot of us have more than one boat, to
fill different niches.
Gary
Port Angeles, WA
Sent: Wednesday, October 11, 2006 8:55 PM
Subject: [bolger] Differences in the Micros
> two?
snip
> I look at the Hot Chilli on Duckworks and I keep going
> back and relook at it over and over. But I know my
> skills to sail it are not there! I would be lucky to
> get the sail up!
> Blessings Krissie
Jim Michalak's book "Boatbuilding For Beginners" has several sections
on sailing (Sailing for Nonsailors: Theory and Sailing for Nonsailors:
Doing It). The book also has lots of good boatbuilding advice and some
foldout plans. A bargain at $17.00 USD from Duckworks. Jim's work is
heavily influenced by Bolger so you won't be disloyal.
Bryant
> two?
> I kind of gather the long is the longer of the two.
> With that said I look at KISS when I build or do
> anyting.
> K-keep I-it S-simple S-stupid
> The simpler you can make it the less likely it is
> going to brake to soon. Just look at all the new cars
> today! They are not simple and are prown to not
> working the way the should!
> But I'm open to ideas and suggestions.
> get the sail up!
> Blessings Krissie
> Do You Yahoo!?
> I don't know who PCB is recomending as a sailmaker
I have asked PCB this question and he answered to the effect:
Kristine,
Build your boat when you discover what kind of sailing you like, and what
between sailing my dink and the Chebacco as there is between sailingthe
Then when you start building, it's all about sawdust, epoxy fumes and gunk
Well Krissie,
You can sail. Its not that hard to learn, really! I would suggest
Dynamite Payson's book on Instant Boats, he has a section on sailing
that is very good. I am sure that there are sailing programs in your
area that you can take a class. Its not rocket science, contrary to
what some might want you to believe. I'd say, "go for it". I cannot
speak with experience about the Micro's, all I have read and all the
input from those that own and sail them, give very good reports. I
have tons of experience in heavy, full keel sailboats and now that
chapter has pretty much ended for me. I searched for a small boat
design that would be stable, easy to sail and single handle and the
Old Shoe jumped out at me. I feel confident that it will live up to
its expectations. As for building one? This is my first full size
wood boat to build, I have moderate wood working experience, but the
project is moving along and I'm learning at the same time. You can't
be afraid to ask for help from the experts. I have been blessed in
that department, since I am being mentored by two of the best
shipwrights I know of. Bolger has done well with his designs and I
believe in sticking with the design unless it can be proven to me
that a modification will enhance or even correct a weakness. When I
saw the keel/ballast design, I wondered about its integrity at
staying in the boat (I'm a keel bolt man myself)..but, frankly, has
anyone heard of the lead ballast falling out of a Micro or Old
Shoe...? Bolger knew what he was doing and I ain't worried. So, my
vote is one of the Micro's.. True, there are tons of designs out
there, all worth merit to build, so many boats and so little time!
Fairwinds,
Dennis
> two?
> anyting.
> get the sail up!
> Blessings Krissie
> Do You Yahoo!?
Well maintained ferro-cement boats are probably painted, slowing down the damage considerably. The tops of bridge decks are subject to far too much physical abuse to hold paint, and are also subject to temperature fluctuations and physical shocks that tend form tiny cracks in the concrete. Water seeps in and repeated freeze thaw cycles accelerate the damage. In comparison, boats have an easy life compaired to bridges in northern New England and other wet cold climates.
Allan
in the hills
----BllFs6@...wrote:
> In a message dated 10/11/2006 8:12:26 AM Central Daylight Time,
>pcrockett@...writes:
> So -- if salt kills rebar inside concrete, are all the ferro-cement
> boats from the 1970s disintegrating now?
> Patrick
> IFFF the concrete is thin enough, cracked enough, and sitting in the salt
> water enough YES, in my very humble and no first hand experience opinion.
> Like I said....THICK concrete....no problem....THINNNNNN concrete disaster
> in the making...
> The question is.....when do you cross the line?
> By definition...if you are REALLY trying to pack in the rebar, you are
> getting it close to the surfaces/edges and each other...how close is too close?
> Perhaps a better way is mix in as much lead into the cement as you can
> stand...and just a few pieces of rebar to make sure the concrete holds together.
> Blll
two?
anyting.
get the sail up!
Blessings Krissie
Do You Yahoo!?
http://mail.yahoo.com
Hi Krissie,
Stresses? The three fixing points are not at all highly stressed as
the offset between the ends and middle points creates a large lever
arm to resist side stresses. As we're talking galvinised steel keel
there is strength enough there, and the hull attachment area loading
is no greater than some adult standing there. A smallish doubler
will dissipate point loading adequately.
PCB draws things all the time that serve more functions than they at
first appear to. For instance, he particularly mentions the boat
strenthening given by a keel attaching to a curved bottom in regard
to Storm Petrel and Supermouse (Supermouse has much less rocker than
Micro too), and goes right off at critics of his sponson attachment
in Gloucester Yawl (those sponsons bear greater weight/side-stress
perpendicular to the attachments, approximately 1000lbs, than
Micro's 400lbs plus some keel).
Sealing? The end attachment points are in free flooding wells. For
Micro, as I said, the midships attachment has issues, but there are
a number of possible solutions - some with no through hull. In Storm
Petrel, only the bow attachment is in a free flooding well. The
other two are outside the watertight envelope. Lining up three
bottom holes and hoisting the keel is a problem, as designed, even
in the stillest, knee-deep water. If lugs are suspended below the
bow and stern, welded to steel straps fixed outside to the bow and
stern, and the already thin at the ends keel is stretched a smidgeon
to accomodate matching lugs, then alignment of the bolt holes is
easier. The keel lugs can also incorporate a lifting eye then. An
untightened lug at one end would allow the keel to pivot, and with a
slightly elongated midships hole a short threaded rod atop the keel
could swing home. Thus one end could be fixed at a time, solo, in
anycase it would be fairly easy work.
PCB happily leads in mining the history of boat design. One gem
extracted is the slipping keel of the Norfolk wherry, a boat so
impressive in all its unexpected options and abilities that it
graces the introduction of BWAOM.
So...Why do it? To extend utility. Of the two Storm Petrels I know,
one has the keel and the other does not. One is limited to deep
water and kept on a mooring, the other is confined to protected
water - but it has a simple trailer. One can ride out storms at sea,
the other can traverse very thin water. Making keel attachment a
casual option grants a much increased range of access to boating
opportunity, to say nothing of improved trailering. Storm Petrel's
apparent keel weight in water is only 157lbs.
I wouldn't, of course, do it so casually with Micro's 400lbs keel.
It might be useful to pass on the keel, along with the rig, to a new
replacement boat. Or... why not remove the keel and rudder, hang a
leeboard and stern rudder, throw in some sand ballast, and Micro's
rocker would make her a reasonable river drift boat and thin water
sailer, like Paloma Blanca did at first. Rarely, the large central
Australian dry salt lakes fill after a large, passing, bulging,
bubble tide of floodwaters has made it's way from tropical
northeast, and monsoonal north west Queensland. A gentle ride down
the Georgina, or through the Channel Country down the Barcoo and on
across Lake Eyre in a keel-less Micro would be great. The explorers
rowed, some do it in tinnies, a Micro would be a luxury cruise by
comparison. Everything in the land has adapted to this fleeting
event, and it is changed utterly. There is suddenly an incredible
abundance of wildlife, and red dust is changed to verdant greenery
ablaze with blooming colour, splendid sights, with no sharks or
crocs about. Everything is in a rush for life; except the relaxed
boater. Unlike cherry blossoms it is truly ephemeral, unpredictable,
no warning before the flood plains may have water for days, rivers
for weeks, and the lakes merely months. Perhaps three times in a
lifetime, if lucky, with coinciding outback rainfall granting
sweeping, rising, vistas of delight. To do it you need to drop
everything you have on ... Now.
Cheers
> --- graeme19121984 <graeme19121984@...>
> wrote:
> > Bottom rocker makes a continuous flange redundant if
> > there's three
> > spaced fastening points. One hanging from a strap
> > before the rudder
> > post, one from the bow transom, ...now, how and
> > where to place the
> > middle one in Micro? In water the steel keel would
> > have an apparent
> > weight near 350 lbs (cf the lead at near 365lbs), so
> > a light three
> > part tackle at each end could be used to easily
> > lower it off, if
> > ever wanted (been thinking about this for Storm
> > Petrel - allow one
> > end fastening to hinge, so only one end at a time
> > need be offered
> > up - allow for a dolly attachment for ramp
> > transport.)
> > Graeme
> Good Sir if you think you can attach your keel to the
> bottom of the boat at the boat ramp and get it to
> seal. Be my guest and I wish you all the luck. I know
> how a pain in the butt it is in a shop with all the
> tools.
> Myself I'll bolt it to the bottom of my boat with 10
> to 12 bolts so the load is not in a few high stressed
> areas.
> Anyway what would be the point to do that it still
> will take the same amount of water to float your boat
> anyway.
> Blessings all
> Krissie
> Do You Yahoo!?
> equivalent displacement speed motor cruiser out there....or is there
one?
Michalak's Electron
http://www.duckworksbbs.com/plans/jim/electron/index.htm
Tracy O'Brian's Kayleigh
http://www.tracyobrien.com/moreinfo.asp?id=32
Jacques Mertons' HMD18
http://www.bateau.com/proddetail.php?prod=HMD18
Bolger Cabin Clam Skiff (not true displacement, but could be used so,
and comparable cabin area)
http://www.duckworksmagazine.com/02/projects/sakari/index.htm
Stambaugh's Redwing
http://www.cmdboats.com/rw18.htm
And any number of displacement sailboats that could easily convert to
displacement outboard cruisers (read as not having lots of ballast and
draft robbing keels) MusicBox II, Normsboat, etc.
Bill
No never did get a read when the sails were new but i don't think it was
alot better. Off the wind with a litle breeze she moves right along within
the limits of a boat that size. I might be repeating myself but I like the
boat it's just that if I could get her to point higher I want to. As for the
sails i got them through Bernie Wolford of common sense designs. I've
brought them into various sailmakers telling them whats been going on. I
don't know who PCB is recomending as a sailmaker but there are two in Camden
Me. that makealot of Harold Paysons sprit rig sails. That's who I'll have
make mine if and when i decide to.
Buck
>From:BllFs6@...
>Date: Wed, 11 Oct 2006 09:19:53 EDT
>In a message dated 10/10/2006 11:52:18 PM Central Daylight Time,
>buckcrowley@...writes:
>Bill,
>pretty
>I
>a
>attached
>that's the problem.
>1.4
>Thanks for the detailed info..I guess you never did really measure the
>performance when the sails were new then?
>As a sorta aside....were the sails from the same place that bolger tells
>you
>to get them from now? How was the quality/cost ratio as far as you were
>concerned?
>Another question....would a daggerboard/deep narrow keel/ or at least a
>deeper "full" length keel help the upwind situation significantly? YES I
>understand the downsides to such things (or at least dont want to sidetrack
> this part
>of the discussion with it right now).
>Your guesstimate of 2 for your boat in top form compared to 1.4 for a
>"real"
>boat would probably be good enough for me to live with.
>How is the performance more along the lines of perpendicular to the wind
>compare to other boats?
>I
>requires
>tender.
>boats
>faster.
>Sea
>in
>Buck Crowley
>Thanks for the comment on the birdwatcher...but if im going out....its
>gonna
>be an all day affair...and with my girly arms I aint rowing anything
>bigger
>than a tiny kayak for hours on end...rowing is okay for emergencies or on
>a
>big pond...or traveling DOWN a river....but in my area that probably would
>not
>work too well unless like I said its a kayak. Also tides and trailering
>probably aren't an issue for me, and I wouldnt need a tender here either as
>my
>aqua stilts work just fine.....
>Again guys, thanks for the comments....and hopefully there are of help to
>some lurkers out there as well....
>Blll
Ferro Cement boats are coated to keep the water out and keels should
be too becouse steel expands as it carrodes,
Jon
> pcrockett@... writes:
cement
> Patrick
the salt
opinion.
disaster
> in the making...
are
is too close?
can
holds together.
> Blll
>From:BllFs6@...
>Bill,
>pretty
>I
>a
>attached
>that's the problem.
>1.4
>you
>concerned?
> this part
>"real"
>I
>requires
>tender.
>boats
>faster.
>Sea
>in
>Buck Crowley
>gonna
>bigger
>a
>not
>my
>Blll
Hi,
Well like I said I've sailed the boat for at least eight years and have
experimented with the sheeting and the snotter tension on the sail quite a
bit. On my sail I can never get the telltales in the first third of sail to
behave while simultaneously getting the leech telltales to stream. I suspect
thats becasue the leech is curling somewhat creating a stall. As to weather
the leech telltales wrap to windward or leeward now I can't say with
certainty. My recolection is windward but the point is they won't stream.
I would still like to hear from any micro owner who knows with some
precision what there boats tacking angle is to help me decide on weather I
should spring for some new sails
Buck
>From: Mark Balogh <mark@...>
>Date: Wed, 11 Oct 2006 10:22:53 -0400
>If you have leech telltales and they are wrapping around the windward
>side of the sail it would mean your sail is under-sheeted or in other
>words let out too far. Is your sail luffing while you are sailing to
>windward? If the telltales are wrapping around the lee side of the
>sail it would mean the sail is sheeted too tightly or over-sheeted.
>This can stall the sail an make the boat less able to point as
>effectively. If yours are wrapped to windward try pulling the sail
>in tighter until they stream parallel to the leech area of the sail.
>It would be odd with a soft sail that telltales would wrap to windward
>without the sail luffing. It sometimes happens on full batten sails
>but not on soft sails. If you can not sheet in enough to stream the
>telltales, maybe you need to increase your sheet purchase. Have your
>tried different adjustments of the snotter line for the sprit boom?
>If they are wrapping to leeward then let the sail out a little to make
>them stream.
>Mark
> > Bill,
> > degrees
> > pretty
> > when I
> > start
> > able to
> > see that we were tacking through 130 degrees based on my gps track.
> > I've
> > given me a
> > attached
> > to the leach don't stream but wrap around the leach on the windward
> > side..The other reason is that I also built a bolger surf which uses
> > the
> > same type of sail and it goes very well to windward so its not sprit
> > rig
> > that's the problem.
> > To answer your question my calculations tell me a boat that will tack
> > travel 1.4
> > get to
> > the same spot upwind. Add in a little adverse current and I could and
> > do
> > through
> > 120 degrees my 2.36 miles would become 2 miles which is much better.
> > tells you
> > were
> > concerned?
> > a
> > YES I
> > sidetrack this part
> > "real"
> > wind
> > again I
> > would build the Birdwatcher 1 for the following reasons
> > requires
> > gas onboard. Oars on the other hand provide exercise which you
> > generaly
> > don't get on a boat.
> > Two. You don't need a tender. My fifteen foot boat needs an eight foot
> > tender.
> > boats
> > and
> > faster.
> > the Sea
> > our in
> > fault
> > Buck Crowley
> > out....its gonna
> > bigger
> > or on a
> > would not
> > trailering
> > either as my
> > help to
> > Blll
> I'll bet most of them are not including the loss for
> leeway, which can be substantial.
The Micro design deliberately compromises on the 'leeway' issue, with
its shallow draft fin keel.
A deeper foil keel could give less leeway, but couldn't take advantage
of shallow waters like the Micro with it's 16 inch draft.
I don't have a Micro, but I have noticed when sailing my balanced
lug dinghy and tracking with a GPS that my tacks are anywhere from
120 degrees to 140 degrees as shown by the GPS track. I do better in
open water than on a small lake. When I am sailing, I appear to be
sailing about 45 to 50 degrees off the wind. I attribute the
difference a to combination of leeway and wind shifts caused by the
shore line at the lake. When people claim to tack through 90
degrees, I'll bet most of them are not including the loss for
> buckcrowley@... writes:
> Bill,
130 degrees
some pretty
ago when I
the start
was able to
track. I've
given me a
streamers attached
windward
uses the
sprit rig
> that's the problem.
tack
travel 1.4
get to
and do
tacking through
better.
tells you
were
> concerned?
least a
YES I
sidetrack this part
for a "real"
the wind
it again I
and requires
generaly
foot
> tender.
few boats
> can up long estuarys and inlets the real pretty places on our
coasts.
easier and
> faster.
in the Sea
well as our in
little fault
> which I'll leave to another time.
> Buck Crowley
out....its gonna
anything bigger
emergencies or on a
probably would not
trailering
either as my
help to
> Blll
them stream.
> Bill,
> degrees
> pretty
> when I
> start
> able to
> I've
> given me a
> attached
> the
> rig
> that's the problem.
> travel 1.4
> get to
> do
> through
> tells you
> were
> concerned?
> a
> YES I
> sidetrack this part
> "real"
> wind
> again I
> requires
> generaly
> tender.
> boats
> can up long estuarys and inlets the real pretty places on our coasts.
> and
> faster.
> the Sea
> our in
> fault
> Buck Crowley
> out....its gonna
> bigger
> or on a
> would not
> trailering
> either as my
> help to
> Blll
Patrick
in the making...
Blll
Bill,
see that we were tacking through 130 degrees based on my gps track. I've
side..The other reason is that I also built a bolger surf which uses the
same type of sail and it goes very well to windward so its not sprit rig
that's the problem.
the same spot upwind. Add in a little adverse current and I could and do
As a sorta aside....were the sails from the same place that bolger tells you
concerned?
understand the downsides to such things (or at least dont want to sidetrack this part
Your guesstimate of 2 for your boat in top form compared to 1.4 for a "real"
gas onboard. Oars on the other hand provide exercise which you generaly
tender.
faster.
Buck Crowley
Thanks for the comment on the birdwatcher...but if im going out....its gonna
be an all day affair...and with my girly arms I aint rowing anything bigger
than a tiny kayak for hours on end...rowing is okay for emergencies or on a
big pond...or traveling DOWN a river....but in my area that probably would not
probably aren't an issue for me, and I wouldnt need a tender here either as my
Blll
Patrick
BllFs6@...wrote:
> In a message dated 10/11/2006 6:15:53 AM Central Daylight Time,
>alpickman@...writes:
> All very true.
> In northern climates they use epoxy coated rebar for highway bridge decks,
> as the salt used for ice control tends to soak into the concrete, causeing
> accelerated corrosion on teh steel.
> Allan
> in the hills
> Yep, thats what reminded me to talk about coated rebar in the first place
> Which reminds me that it might be worth looking for already coated rebar in
> you local area if the rebar keel route is your chosen plan of attack...or
> maybe even a nearby larger city...now once you cut the ends you'll need to give
> that area a new coat or two.
> If you REALLY wanted to pack rebar in you might wanna go this route:
> Hold it together with epoxy, maybe even with say about 50 percent of epoxy
> volume being relatively fine lead shot, and either mix in short glass fibers as
> well as weave in or encapsulate the whole thing with some glass cloth.
> But again probably the easiest/most effective non molten lead route is the
> solid steel keel, or baring that a hollow but narrow welded up steel keel with
> as much lead/epoxy as you can effectively pack in there..or if you are really
> lucky maybe you could get your hands on some depleted uranium :)
> Blll
In a message dated 10/10/2006 1:45:50 PM Central Daylight Time,
arvent@...writes:
All Bolger designs that have an unstayed mast and no jib on a
tensioned stay, foot faster when a bit off the wind but over a
triangular course will stay with most production pocket yachts of
similar size and beat many of them.
Well, that tells me the micro is certainly in the ball park of "real"
sailboats when it comes to performance...
Like I said in my other post, the performance doesnt have to be right up
there with other boats...just a decent fraction of it...
Blll
In a message dated 10/10/2006 1:03:52 PM Central Daylight Time,
bruce@...writes:
The max hull speed is determined by length, and all the longer sloops
will pass a Micro because of their higher max hull speed. I have
found that I can outrun the longer sloops (barely, and when their
skipper is drunk) while sailing downwind.
In short, if you are fixated on speed, or on passing people, a Micro
isn't your best choice.
Want to go fast upwind? Use your motor.
Want a comfortable, simple, safe, small cruiser for two? A Micro is good.
Yep that old devil that keeps men awake at night and that women refuse to
admit...length does matter!
Hmmm....maybe thats why you always see those sexy women lounging on the mega
yatchts rather than the trailerable puddle jumpers.....its all about the
"hull speed" :)
Anyhow, certainly NOT fixated on speed.....its just that IFFF the micro is
REALLY bad at upwind travel and in my area I end up having to do ALOT of it
(dont know enough about sailing or our "weather" patterns here to know if
thats the case or not) then I will wind up using a motor ALOT.
Now, unlike some purist, I have no problem with a motor (besides initial
cost). As a matter of fact I keep vacillating between a "micro cruising"
sailboat and a micro cruising displacement "motor boat" and even sometimes a cross
between the 2.
As a child I grew up with the typical family coastal fishing boat...the kind
that flew like a bat out a hell, louder than a jet engine, rougher than
cheese grater on salt coated knuckles, and sucked fuel faster than the IRS does
money outa rich folks.
So a little couple horse power job that goes all day on a couple gallons and
that you can carry on a conversation right next to is bliss in comparison.
And a couple summers ago I spent all day every day for a week cruising in a 9
foot inflatable with a 4hp motor at displacement speeds and had a blast,
which is what caused me to realize small and slow could be pretty damn fun.
I guess my point being, if the micro can go upwind 50 percent as well as
whats a realistic maximum for a "real" sailboat....I could probably live with
it....75 percent very happy...90 or so wouldnt even notice.
I'd just hate to build a sailboat that I spend toooooo much time motoring
with, if thats the case, I put the money/work into a design more suited for
slow motoring. But I suspect it would not be the case....need to do some more
research.
And I do realize that the bolger design does give up some performance for
some very real advantages elsewhere...thats why I love the looks of the micro
while most folks probably don't..because I realize there is a good reason that
it looks that way.
Also, the micro seems to be the textbook miro cruiser/dailsailer/homebuilt
that most others are compared too. However, there doesnt seem to be an
equivalent displacement speed motor cruiser out there....or is there one?
thanks again for the comments guys...
Blll
All very true.
Allan
in the hills
Blll
All very true.
In northern climates they use epoxy coated rebar for highway bridge decks, as the salt used for ice control tends to soak into the concrete, causeing accelerated corrosion on teh steel.
Allan
in the hills
> In a message dated 10/10/2006 3:21:22 PM Central Daylight Time,
>donschultz@...writes:
> "though you'd want to be cafeful to not include SOOO much rebar that
> the resulting structer was WEAKER than concrete alone...."
> Not much chance of that. Concrete is NOT very strong compared to
> steel. It is not very dense compared to steel.
> Yes....that is techincally true but not practically true....
> You can only get concrete so "thin" before it doesnt behave like concrete
> anymore...
> As an example....surround a piece of rebar with a thickness of 3 inches of
> concrete on all sides and that sucker will last forever...
> Surround same rebar with a thickness of 0.3 millimeters and within year you
> will have a naked rusted piece of rebar....
> IFFFFF the concrete is the only thing holding the various pieces of rebar
> TOGETHER.....the thickeness of the concrete BETTER be enough to last awhile
> before cracking and spalling....
> Which brings up another point....if I was putting said rebar in concrete in
> a keel, particularly for a boat to be used in saltwater....I would coat the
> rebar with something before putting it in the concrete.....a thin layer or 2 of
> epoxy and perhaps another one or two at the ends would probably be a good
> idea.....once enough water/oxygen/salt reaches the rebar and starts creating
> rust your rebar/concrete maxtrix's days are numbered...
> Bllll
Yes 65 degrees when you add in leeway based on looking at my gps track and
while I'm not a racer by any means I've owned the boat for eight years and
have been sailing for about thirty so I can generaly tell about where to
point her to make her make the best track if you follow me..
Buck
>From: "Derek Waters" <dgw@...>
>Subject: Re: [bolger] micro pointing ability
>Date: Mon, 9 Oct 2006 22:34:11 -0700
>"Mine ....tacks through 130 degrees."
>Just to be clear, you are saying that your boat will point no higher than
>65
>degrees?
>Hmmm. That's not been my experience with ours. She'll make some forward
>progress tacking through 90 degrees, i.e. tacking so the point dead abeam
>is
>the new heading. That's easy to tell without taking the cover off the
>compass or firing up the GPS, so I notice it. We don't always sail that
>pinched though, as our wind is often light, and there's more progress to be
>made footing faster on broader tacks, or so it seems. At 90 degrees we're
>probably making ugly leeway. I don't have the GPS at hand to look at
>tracks,
>but I can swear we do better than 130.
>I built our boat, so I can say with certainty that she's not particularly
>well polished, although everything down there is as straight as it's meant
>to be. At the risk of 'teaching my Grandmother to suck eggs', you _are_
>trimming the mizzen to keep the helm balanced, eh?
>Good luck
>Derek
Bill,
I can only speak about my boat which I mentioned tacks through 130 degrees
and then only in good conditions. My feeling is that I must have some pretty
bad sails. I got them from Common Sense Designs about eight years ago when I
finished the boat so they've got some miles on them. I knew from the start
that the boat would not be a worldbeater upwind but recently I was able to
been asking around to see how other micros perform but nobody has given me a
definitive answe..One reason I suspect the sails is that streamers attached
that's the problem.
through 90 degrees (which I believe is average performance) will travel 1.4
miles to move upwind 1 mile. My Micro needs to cover 2.36 miles to get to
find myself going backwards. Now if new sails would get me tacking through
I don't know how you plan on using your boat but if I were to do it again I
One. It requires no motor. Even the best motor stinks is noisy and requires
tender.
Three. Birdwatcher can dryout upright. This allows you to go were few boats
Four. It tows better. It's lower and lighter. It also launches easier and
faster.
All that being said I do love my micro Our family of four cruised in the Sea
of Cortez in it the San Juan Islnds and the coast of Maine as well as our in
home San Francisco. It is a nice little boat and has only one little fault
Buck Crowley
>From:BllFs6@...
>Date: Tue, 10 Oct 2006 13:08:06 EDT
>In a message dated 10/10/2006 10:09:49 AM Central Daylight Time,
>bruce@...writes:
>On 10/9/06, 9buck crowley <buckcrowley@...> wrote:
> > Hello,
> > Has anyone out there any first hand knowledge of the "Micros" pointing
> > ability. Mine which I feel was very well made, fair smooth etc.' tacks
> > through 130 degrees. That's not very good. I'm considering having new
>sails
> > made to see if that's the problem but I don't want to go to the
>expense if
> > the problem is with the design....
> > Buck
>I think mine points better than 130. The quality of the cut of the
>sail, plus your technique, matters. If I need to get to windward in a
>hurry, I use my motor.
>A Micro will never point as high as the expensive, high tech / high
>stress sloops. But the sloops lose when your goal is simplicity,
>comfort and ease.
>Hi guys..
>This brings up a point I've wondered about given that old shoe and micro
>are
>two of my favorite/most likely if anything to be built designs....
>Take a Bolger Micro,
>Now take a similar "normal" sailboat....nice commercial one say, but by the
>same token not a gold plated, state of the art, mega buck absolute best
>carbon
> graphite racing machine...
>Or in other words a nice commercial saiboat with similar length and
>breadth,
>a nice smooth "normal" shaped hull, a real proper fixed keel, modern
>"normal" sail set up, and about the same all up weight and load carrying
>capacity....
>Now, both boats are trying to run a course that is directly upwind,
>Obviously, they can't so they tack back and forth, going from "side to
>side" but
>overall they do make upwind progress...
>How does a Bolger Micro compare with the "normal" commercial boat? In a
>light wind or medium wind or strong wind?
>50 percent of the normal one? 75 percent as fast? 90?
>And allow for a tacking angle that allows for the fasted NET upwind
>progress
>for each rather than fastest "apparent" speed etc etc
>Forgive my lack of proper sailing terms...
>Blll
> there's three
> before the rudder
> where to place the
> have an apparent
> a light three
> lower it off, if
> Petrel - allow one
> need be offered
> transport.)
> Graeme
tools.
areas.
anyway.
Blessings all
Krissie
Do You Yahoo!?
two?
anyting.
does one deside on the boat to build? Stich and glue
would be a nice way to building too.
Blessings Krissie
Do You Yahoo!?
anymore...
Bllll
HMMMMM a steel mold and melting pot all in one no pouring. HMMMM
Jon
--- Inbolger@yahoogroups.com, gmcatee@... wrote:
> Another option might be what Buehler discusses in his book: weld up
or get someone to weld up a steel "box" in the shape of the ballast
portion of your keel, including a framework to hold the bolts that will
stick up through your deadwood/keel/etc... and the fill the box with
concrete and scrap metal, or if you need a higher density lead (I think
somewher else I read of someone doing the same and using used lead tire
weights in the concrete for higher density).
> --Gabriel
will stick up through your deadwood/keel/etc... and the fill the box
with concrete and scrap metal, or if you need a higher density lead
(I think somewher else I read of someone doing the same and using
used lead tire weights in the concrete for higher density).
> --Gabriel
> Sent via BlackBerry from T-Mobile
> -----Original Message-----
> From: "Bruce Hallman" <bruce@...>
> Date: Mon, 9 Oct 2006 11:09:22
> Subject: Re: [bolger] Re: Keel on the Micro
> On 10/9/06, BllFs6@...: <mailto:BllFs6%40aol.com> wrote:
> > And if you can't do that, I'm sure going the cut steel plating
would be a
> > pretty decent/cheap substitute....and probably much better than
the concrete
> > version..
> Just FYI, the Bolger design holds the lead casting to the hull by
sandwiching
> the lead between two sheets of plywood, and with nails. I used the
> short heavy guage nails they sell for use with 'Simpson Strong-
Ties'.
> Nail SS10D, available at local hardware store.
>http://www.strongti:
<http://www.strongtie.com/products/connectors/nails.html>
> A steel plate keel could work, but won't accept the nails.
and breadth,
Hi Bruce, There is; It is called a Peep Hen. Check them out at
peephens.org Sincerely,
Brian
> I don't think a commercial sailboat even exists that is only 15'4"
> long, and which is a comfortable cruiser that sleeps two.
sloops
is good.
good.
I would love to hear of one that is better!
Almost all the folks who built and sailed a Micro and then sold them
later, miss them very much which says a lot about the design.
Any modifications to the design will detract from it's synergetic
qualities
On 10/10/06,BllFs6@...wrote:
> Or in other words a nice commercial saiboat with similar length and breadth,
bruce@...writes:
> Hello,
sails
> made to see if that's the problem but I don't want to go to the expense if
> Buck
comfort and ease.
Hi guys..
This brings up a point I've wondered about given that old shoe and micro are
same token not a gold plated, state of the art, mega buck absolute best carbon
"normal" sail set up, and about the same all up weight and load carrying capacity....
Obviously, they can't so they tack back and forth, going from "side to side" but
And allow for a tacking angle that allows for the fasted NET upwind progress
Blll
Further to the C.O.G./C.O.B. discussion. The text Stability And Trim
For The Ship's Officer from Cornell Maritime Press is the standard
reference for stability calculations in the U.S. Merchant Marine. A
free source of information is in the U.S. Navy's training course
"Principles of Naval Engineering". I believe this is available from a
non-secure website. The long and short of the question, however, is
that for keel boats with the C.O.G. well below C.O.B., the righting
moment will always be positive. For boats with centerboards, power
boats, and cargo vessels with the C.O.G. above the C.O.B. it is very
important to avoid raising the C.O.G. too high. Loading low density
materials or large weights high in the hull can do this because the
center of volume moves up. With a keel made of materials less dense
than water, e.g. foam boards, the center of buoyancy is lowered more
than the center of gravity.
V/R
Chris
Kristine Bennett wrote:
> No I said nothing about the center of gravity. I was
> talking about CoB or Center of Buoyancy. No the two
> are not the same. Dave Geer has a great book call
> "Nature of Boats" and it has a very good chapter that
> covers CoG and CoB.
> Your Cob will change with the amount of heel to the
> boat and how it's loaded both with stuff and sail. It
> moves all the time some times a little sometimes a
> lot.
> Where as the CoG it changes with the load placement in
> the craft only. But the load can be people, gear and
> goods and free flowing water in the hull as well. You
> know bilge water.
> Blessings Krissie
> --- donm172001 <Don_Maurer@...> wrote:
>> Like I said, if the center of gravity stays the
>> same, it doesn't
>> matter what material you use for the ballast. You
>> are assuming the
>> center of gravity will be higher with feathers.
> Hello,
> through 130 degrees. That's not very good. I'm considering having new sails
> Buck
comfort and ease.
> Depending how far you ran you flange plate fwd and up
One other thing about the lead ballast, is it centered in the
forward-aft direction on the hull, keeping the bow and the stern free
of weight. The design intent to allow easy pitching. A full length
steel slab would not pitch as easily as a hunk-o-lead centered on the
hull.
You can consider the possibility also of use the berths of the Micro like cover of two water ballast tanks. They can contain around 100 liters of water and could give a big help to the insufficient weight of the concrete keel.
Marco
To :bolger@yahoogroups.com
Cc :
Date : Tue, 10 Oct 2006 13:32:37 -0000
Subject : [bolger] Re: Keel on the Micro
Riascolta i tuoi 33 e 45 giri con un bellissimo Giradischi Retrò
tecnologia HI-FI, collegamento PC e design anni '60 !
> AF2 and AF3 require a limited water line beam due to the
> choice of oar auxilliary, whereas Cynthia J is a (sharpie) cat boat
> rigged for moving in the least breath of air...
This raises a point not yet discussed in this thread, AFAIK. CJ is
very difficult to row, paddle, or scull in more than a breath of
breeze. The most powerful method I found was to kneel (one knee) on a
bench and paddle with an oar. (A typical canoe paddle is much too
short.) Someone other than the paddler has to steer. Two paddlers and
a helmsman can actually get somewhere, but it's not fun. I tried
sculling with an oar, and found it possible but slow. I didn't
experiment with a fancier purpose-built scull, not did I ever try an
outboard.
Another option might be what Buehler discusses in his book: weld up or get someone to weld up a steel "box" in the shape of the ballast portion of your keel, including a framework to hold the bolts that will stick up through your deadwood/keel/etc... and the fill the box with concrete and scrap metal, or if you need a higher density lead (I think somewher else I read of someone doing the same and using used lead tire weights in the concrete for higher density).
--Gabriel
On 10/9/06,BllFs6@...: <mailto:BllFs6%40aol.com> wrote:
> And if you can't do that, I'm sure going the cut steel plating would be a
> pretty decent/cheap substitute....and probably much better than the concrete
> version..
Just FYI, the Bolger design holds the lead casting to the hull by sandwiching
short heavy guage nails they sell for use with 'Simpson Strong-Ties'.
http://www.strongti:<http://www.strongtie.com/products/connectors/nails.html> e.com/products/connectors/nails.html
Looked at another way, the Micro keel is only just over half a cubic
foot of lead.
http://www.reade.com/Particle_Briefings/spec_gra2.html#L
On Oct 9, 2006, at 8:07 AM, Bruce Hallman wrote:
> On 10/9/06,BllFs6@...<BllFs6@...> wrote:
>> First..
>> Second method...
> Both these suggestions make something simple more complex.
> The genius of Phil Bolger is elegant simplicity.
> Here is a photo from my lead fin keel pour.
>http://sports.webshots.com/photo/1121100644051159125qadyRL
Bottom rocker makes a continuous flange redundant if there's three
spaced fastening points. One hanging from a strap before the rudder
post, one from the bow transom, ...now, how and where to place the
middle one in Micro? In water the steel keel would have an apparent
weight near 350 lbs (cf the lead at near 365lbs), so a light three
part tackle at each end could be used to easily lower it off, if
ever wanted (been thinking about this for Storm Petrel - allow one
end fastening to hinge, so only one end at a time need be offered
up - allow for a dolly attachment for ramp transport.)
> LOL that is true. But if you have a plate flange made
> to fit the hull then drill and countersink for your
> bolts. Then have your keel slab welded to the flange
> (my choise would be Coreweld) then you can have is
> blasted and seal it with epoxy or any number of paints
> then you are ready to bed it and bolt it in place.
> Deppending how far you ran you flange plate fwd and up
> the stem feel sorry for the poor sod that hits your
> bow!
> Blessings Krissie
> > nails.
> Do You Yahoo!?
Just to be clear, you are saying that your boat will point no higher than 65
degrees?
progress tacking through 90 degrees, i.e. tacking so the point dead abeam is
probably making ugly leeway. I don't have the GPS at hand to look at tracks,
Good luck
Derek
Chebacco, like any other, may be all round better if it were bigger
too - for some. "Bigger" implies certain things, eg. Bolger says a
longer boat of poor form beats a shorter boat of good form - for
speed that is; and it follows that any longer models of a form will
also beat the shorter. "Better" isn't just bigger, or speedier, or
cheaper, it depends on the weighting given each of a complex mix of
many factors - including intangibles. To say a boat is "better" may
be true, but, and without being pc, "different" is usually more apt.
Chebacco is great; different to a 14.5' sharpie box though.
Cynthia J carries her crew at near the same height as AF2. Cynthia J
though, carries her crew near the maximum beam, AF2 and AF3 do not.
This will allow CJ a relatively higher cabin if wanted. In
illustration of PCB's argument against the use of flare, for the
same overall beam, Cynthia J's plumb sides let her stand with her
feet further apart than AF2, and that form stability also further
allows a higher cabin if wanted. It must be said though, that PCB's
contrary argument for including the use of flare in the Otter
upgrade allows AF2 and AF3 a chance to right before shipping too
much water. AF2 and AF3 require a limited water line beam due to the
rigged for moving in the least breath of air (but emptying a water
ballasted, dead flat bottomed, pointed stern, box closewater might
help under oar ;).
> --- Inbolger@yahoogroups.com, "pvanderwaart" <pvanderwaart@>
> > The Chebacco is a much better boat, but also more of a building
> > project. The big question on the Cynthia J is about the cabin.
If you
> > don't need a cabin boat, you can build something much simpler.
If you
> > really want a cabin boat, CJ may not be good enough. The cabin
has a
> > lot of room, but it's not really very comfortable to use.
> If one wants simplicity then in this regard, the commentary on
> Michalak's AF2 and AF3 is of interest. Particularly regarding
raising
> cabin height.
>http://www.duckworksbbs.com/plans/jim/af2/index.htm
> Nels
bow!
Blessings Krissie
> nails.
Do You Yahoo!?
I have been reading this thing about pouring lead.
Well it's not that big of deal IF you set it up to be
easy for yourself and on you. I would bet I have help
pour 3 to 4 tons of the stuff over the years easy.
We were pouring cannon balls anywhere from 45 to 80lbs
each. These are the weights that are use on the
trolling lines to carry then down to 240 to 360 feet.
When you are fishing the rock piles in Alaska you tend
to loose them offen.
Have your molds up so there is no bending. When your
pot holds 120 lbs of lead at a time this is a bid
deal. We use two weed burners and a fire brick forge.
That we set the pot in for heating the lead. I was
shocked at how simple it was to set up and do. But if
you are pouring a lot of lead at one time it's a lot
of work.
Dad made sure we were useing the right cartridges in
the respirators and they were to be worn when ever
were were pouring or smelting.
Setup is a large part of working safely when doing any
pouring. If you don't think working with lead is with
in your skill range have someone else pour it for you.
Blessings Krissie
Do You Yahoo!?
Hello,
Buck
>From:BllFs6@...
>Date: Mon, 9 Oct 2006 12:30:11 EDT
>In a message dated 10/9/2006 10:22:58 AM Central Daylight Time,
>bruce@...writes:
>_http://sports.webshots.com/photo/1121100644051159125qadyRL_
>(http://sports.webshots.com/photo/1121100644051159125qadyRL)
>Yes. I agree.....
>Its just some folks have a real aversion to pouring molten lead.....not
>that
>it CANT be downright dangerous and unhealthy if you do it WRONG...
>Blll
> version..
In a message dated 10/9/2006 12:09:44 PM Central Daylight Time,
bruce@...writes:
This runs contrary to conventional wisdom, but when I did research I
found that lead at the temperatures involved does not emit significant
lead fumes. In any case wearing a mask is not a big deal. Smashing
your toes, or eating the lead, or sawing your fingers, or breathing
fumed silica and/pr acquired allergy to epoxy are bigger risks, IMO.
Per this OHSA site
http://www.osha.gov/SLTC/etools/leadsmelter/refiningcasting/casting.html
Yes....PURE molten lead probably is pretty fume free at melting
temps.....but I would still make sure of a good mask...and more importantly VERY good
ventilation (the solution to pollution is dilution)...and besides its always
nice to share with the neighbors...
However....start dealing with scrap lead, high temps, and gawd know what
else in the mix...and the fumes could be VERY serious indeed...
A side story....
Working on friends house after hurricane Ivan....some cheapo a block or two
away was burning his discarded roof shingles...and the smell really wasnt even
strong...you almost had to work to notice it...
Well, as the day goes on both of us start to feel not so good...we leave our
work early...and by that night we both feel like crap and even worse the
next day..and it was nearly a week before I feel normal again....
And I have in the past worked up close and person with molten tar and pitch
without any problems, and been around many debris/garbage/large campfires etc
etc...
So, I started wondering what about THOSE fumes could have been SOOOO
bad....then I remembered...that if I recall correctly.....galvanized metal at hight
temps is VERY bad for you and can even be fatal....
Roofing nails are galvanized!
Soo, better check whats in the lead you get...particularly if its scrap.....
Not trying to scare anybody into NOT using lead......I'd almost certainly
give it a go if needed...just never hurts to be careful or informed...
And if melting the lead is still scaring you, I've gotten the impression
over the internet that finding some commercial place to cast one for you aint
too bad/hard and doesnt cost too much...
version..
Need to run/lookup the numbers for a steel keel....
Bllll
> Its just some folks have a real aversion to pouring molten lead.....not that
Certainly. Molten lead flows like water.
Is VERY heavy and hot, you can squish your toes and burn yourself.
Wash your hands and keep your fingers out of your mouth.
Per this OHSA site
"Keep molten lead temperature below 1000°F to minimize lead fumes and
particulate emissions during lead transfer and drossing of castings
and molds."
Frankly, getting up to 1000°F is not easy. I heated it just to the
melting point, and no more.
bruce@...writes:
Yes. I agree.....
Blll
> project. The big question on the Cynthia J is about the cabin. If you
> don't need a cabin boat, you can build something much simpler. If you
> really want a cabin boat, CJ may not be good enough. The cabin has a
Michalak's AF2 and AF3 is of interest. Particularly regarding raising
cabin height.
> First..
> Second method...
Lead melting in a steel bucket. I moved the lead from the bucket to
the mold using a ladle.
The mold is made from cement 'Wonder Board' (the stuff they use when
building showers in houses). I really was simple and easy. I spent
much more time worring about it than it actually took to do it.
One thing to consider..
As others have pointed out....anything less dense than lead will need MORE
total mass given that some of its "mass/weight" will be negated by the fact
that it displaces some water...and more water than lead would....
IFFFF it was me and I was dead set against pouring or using a lead
keel.....I would do one of three things...in this order of preference...
First..Lead shot held together by epoxy.....remember spheres will only pack
together so much....for spheres of one uniform size....about 50-60 percent the
density of solid matter....if you want to up that percentage a fair bit, use
2 different sizes of spheres....one about 10-20 percent of diameter of the
larger size....but note if the small ones are TOO "big", your resulting
density will be LESS than if you you just stuck to one size...and if they are toooo
small, they wont help much...draw out circles on paper, dig out a geometry
textbook, or play with marbles to get this size relationship figured out....ie
you want the small ones to fill the voids created when you pack the big ones
together as tightly as possible
Also, if doing this, I would include a fair bit of steel rebar runing
fore/aft along the entire keel to give the structure some "guaranteed"
strength...and maybe even throw in some steel mesh as well.
Second method...just have a solid keel cut out of steel plating at the local
metal shop....a steel keel would not have to be ALOT heavier or "deeper"
than a lead one....and the metal shop could cut out thinner sheets and weld
them together to get the required thickness if neccessary.....you could even
have two thin steel sheets welded together, but you put in "sheets" of lead
between them before you weld them together..
And finally if doing the concrete thing, I'd pack in as much rebar as
possible to both up the average density and make sure the thing held together,
though you'd want to be cafeful to not include SOOO much rebar that the resulting
structer was WEAKER than concrete alone....my guess on that would be to not
get the rebar closer to any surface or other rebar than the size of the
largest pieces of rocks/aggregate in the concrete mix.....AND use the strongest
concrete you can find, make sure the concrete stays damp/moist for DAYS after
the pour (ie wet burlap over exposed surfaces etc etc).... AND make sure you
dont add ANY more water than the instructions say, as that can REALLY reduce
the strength of mix...
Just my thoughts...
Blll
> Anyone who is leery about pouring a lead keel, or interested in an
> improved Cynthia J should consider the basic plywood Chebacco. The $60
> plans from Dynamite Payson have to be the best bargain in the boat
> plans world today!
>http://www.instantboats.com/chebacco.html
> A simple 1 1/2" thick slab of lead is so simple, easy and elegant.
Not to mention immensely strong, acting as a supporting girder for the
hull bottom.
plans world today!
On 10/8/06, dustymick64 <dustymick64@...> wrote:
> I am not a designer by any means. But I have see boats with concrete
> and scrap iron in the keels.
Certainly.
The Micro, on the other hand, has a very thin 'fin' keel. The thin
keel provides the lateral plane that allows the boat to sail to
windward. To use a ballast less dense than lead would require the
keel to be made thicker. It probably could work, but you would have
to devote some careful though as to the taper and 'foil' shape.
> and scrap iron in the keels. The Tideway 14 for example, if I recall
> correctly, has a keel built like that. I fished on a 43 foot boat
> (homebuilt back in the 30's in Alaska) for awhile and the entire
> bottom of the boat was filled with it. Darn seaworthy boat I might
> add. But like I said, I don't know if it would work on this design
> and type of craft..
No doubt it would work after a fashion. This has been done to
thousands of boats for a hundred years or more.
But I would ask Bolger what he thinks before I went for it. Based on
comments I have read from him, I think that if he disagreed, then he
would not support any further building enquiries as it would no longer
be a Micro in his mind.
But I might be wrong too...
and type of craft..
> --- Inbolger@yahoogroups.com, "Robb" <Robb@> wrote:
> > Hi there. I don't know about concrete but I have heard of a few
> people using lead shot encased in epoxy. This eliminates melting
> the lead...but you have to make the keel a little longer or
thicker to
> account for the decrease in density of the epoxy. Robb
> Another option when using lead shot or lead billets enclased in
epoxy
> is to add a couple extra billets after launch to bring the boat
down
> to the designed waterline. This is what Dan Gonneau did in his Long
> Micro.
> He put them under the entrance step below the companionway. The
> advantage of this is that you can remove them if you want to carry
> additional stores or passengers. Also the weight is centered over
> CoB for more reliable tacking than extending the weight fore and
aft
> in the keel.
> Nels
people using lead shot encased in epoxy. This eliminates melting of
the lead...but you have to make the keel a little longer or thicker to
Another option when using lead shot or lead billets enclased in epoxy
is to add a couple extra billets after launch to bring the boat down
Micro.
additional stores or passengers. Also the weight is centered over the
CoB for more reliable tacking than extending the weight fore and aft
in the keel.
> Was wondering how difficult it would be to change the keel from the
> one designed for it to a box type filled with concrete? Messing around
> with the lead is a bit more than I want to fool with.
I would think the box keel would make it very iffy for tacking
reliabley in light winds, unless the motor was running to carry it
through stays.
There is an interesting keel building article in Duckworks by Peter
the Pirate. This is different than to standard plan, in that the keel
is bolted to a keelson in conventional fashion.
http://www.duckworksmagazine.com/00/DM1999/articles/micro/index.htm
> They are 2 different boats.
One being the most popular and well tested designs of Phil Bolger,
the other being an untested prototype.
That looks like a good keel to me.
Your English is much better than my <any foreign language>. The only problem I had was "krick." From the pictures, it's what we call a jack, or more technically a scissors jack.
Working molten lead has always been kind of fun for me. It's not that hot, but it is exciting:http://home.insightbb.com/~derbyrm/CBlead.htmlThe only time I've had trouble was soldering when I dripped some on my sock. (Later I learned that you lift the sock away from your ankle while the solder cools.)
Well, then there was the time I set the house on fire while removing a lead drain pipe inside a wall, but a gallon of water put that out quickly.
To: bolger
Sent: Saturday, October 07, 2006 6:08 AM
Subject: Re:[bolger] Keel on the Micro
The fusion of the lead is difficult more psycologically than practically. I have done it after have thought two months. I have found however an easy and comfortable solution, thank also a suggestion of Michalak: you divide in more depart the ballast. I have divided it in three parts. That makes simpler the fusion and makes then more manageable (but not easy) the assemblage of the ballasts on the keel.
The procedure for the fusion is very simple
no revolving pipe
no faucet
no complicated structure
only a big pipe of iron, two bricks, a cylinder of propan and a nozzle for join.
The pipe lie on the bricks with a light inclination toward the form in wood. You get warm the pipe from out or directly directing the flame on the wrecks of lead.
The wood is smeared first with water glass.
At the end doesn't need to smooth ballast. you have three perfect and rough pieces (excellent for the epoxy).
The assemblage of the three pieces happens using the rear of the form like slide and a krick for car. You make slip each piece against the keel, smear it with thickened glue, straight it and screw it from behind with bronze screw. I hope my terrible English is enough.
I have put in the forum some photos of the whole procedure.http://ph.groups.yahoo.com/group/bolger/photos/browse/277b
---------- Initial Header -----------
Cc :
Date : Fri, 06 Oct 2006 22:31:05 -0000
Subject : [bolger] Keel on the Micro
That only applies if you don't change the shape of the boat in the water. If you make the keel wider to allow use of cement instead of lead then the boat is larger and displaces more water if held to the same waterline. Otherwise it lifts out of the water. They are 2 different boats.
Gene T.
"A house ashore is but a boat, so poorly
built it will not float ---- "
To: bolger@yahoogroups.com
Sent: Saturday, October 7, 2006 5:09:11 AM
Subject: [bolger] Re: Keel on the Micro
It doesn't matter whether you use 300 lb. of lead or 300 lbs of
feathers. As long as the center of gravity is in the same place, you
will have the same righting moment. Of course the keel also acts as
a foil underwater, so you will pick up some secondary stability from
the keel with the lighter ballast due to the necessary size increase.
--- In bolger@yahoogroups. com, "Jon & Wanda(Tink)" <windyjon@.. .>
> I don't think that is quite right. What ever you use it will be
> lighter by the amount of water it displaces that is what makes
boats
> float. So what is commen is to keep the shape but give it more
depth
> ie leverage so the same weight has the same efect with the
leverage
> helping useing concreat rather then lead.
> Jon
> --- In bolger@yahoogroups. com, Kristine Bennett <femmpaws@> wrote:
> > Dusty I don't think it would be that hard but the
> > thing you are going to need to keep in mind is,
> > concrete looses about half it mass when it is in salt
> > water.
> > It you have a 2000 lb block of the stuff and hang it
> > by a scale in seawater it would be just over 1000 lbs.
> > I was told this by a number of people that set
> > moorings here in the islands.
> > To support this concrete with stone is 120 to 150 lbs
> > per cubic ft. and seawater is 64 lbs per cubic ft.
> > So with that said if you need 300 lbs of lead you are
> > going to need 600 lbs of crete at the same place from
> > the CoB. You could get away with less if you made the
> > keel deeper so it would have a longer lever arm from
> > CoB.
> > Krissie
> > > the keel from the
> > > with.
> > ____________ _________ _________ _________ _________ __
> > Do You Yahoo!?
> > http://mail. yahoo.com
#ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;
#ygrp-tpmsgs{
font-family:Arial;
clear:both;
#ygrp-vitnav{
padding-top:10px;
font-family:Verdana;
font-size:77%;
margin:0;
#ygrp-vitnav a{
padding:0 1px;
#ygrp-actbar{
clear:both;
margin:25px 0;
white-space:nowrap;
color:#666;
text-align:right;
#ygrp-actbar .left{
float:left;
white-space:nowrap;
.bld{font-weight:bold;}
#ygrp-grft{
font-size:77%;
padding:15px 0;
#ygrp-ft{
font-family:verdana;
font-size:77%;
border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;
#ygrp-vital{
background-color:#e0ecee;
margin-bottom:20px;
padding:2px 0 8px 8px;
#ygrp-vital #vithd{
font-size:77%;
font-weight:bold;
color:#333;
text-transform:uppercase;
#ygrp-vital ul{
padding:0;
margin:2px 0;
#ygrp-vital ul li{
list-style-type:none;
clear:both;
border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;
color:#ff7900;
float:right;
width:2em;
text-align:right;
padding-right:.5em;
#ygrp-vital ul li .cat{
font-weight:bold;
#ygrp-vital a {
text-decoration:none;
#ygrp-vital a:hover{
text-decoration:underline;
#ygrp-sponsor #hd{
color:#999;
font-size:77%;
#ygrp-sponsor #ov{
padding:6px 13px;
margin-bottom:20px;
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;
margin:0;
#ygrp-sponsor #ov li{
list-style-type:square;
padding:6px 0;
font-size:77%;
#ygrp-sponsor #ov li a{
font-size:130%;
#ygrp-sponsor #nc {
background-color:#eee;
margin-bottom:20px;
padding:0 8px;
#ygrp-sponsor .ad{
padding:8px 0;
#ygrp-sponsor .ad #hd1{
font-family:Arial;
font-weight:bold;
color:#628c2a;
font-size:100%;
line-height:122%;
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;
#ygrp-text tt{
font-size:120%;
blockquote{margin:0 0 0 4px;}
.replbq {margin:4;}
To keep the whole boat COG the same when using material of somewhat
lesser density in the Micro keel you might consider doing in part what
Jason Stancil did a year or two ago (see archives). I say "in part" as
Jason left off the keel altogether, and put lead and steel scrap
(IIRC) in concrete (or was it epoxy?) inside. To get the boat as stiff
as designed (which Jason didn't require) would require an awful lot of
down low, heavy, inside ballast alone, and this would reduce space.
However, a bit of inside ballast up to, say, the level of the sleeping
flats, such as a concrete floor with lots of steel in the mix, would
keep the hull COG where it was if the outside keel lead ballast were
substituted with a somewhat lighter material. To get it exact requires
calculation, somewhat ;)
covers CoG and CoB.
lot.
know bilge water.
Blessings Krissie
> same, it doesn't
> are assuming the
Do You Yahoo!?
The old weight vs. density argument. To "sink " a boat down to her designed lines takes a given amount of weight and any material that generates the required weight will do the trick. The problem here is that the volume avilable to hold the material providing the weight is finite (specifically the keel of a Micro). As PCB drew her, the middle of the keel is filled with lead. If you fill the same space with a less dense material (such as steel, concrete, or feathers) there will be less weight in the keel than PCB intended. Such a boat would not float on her designed lines and would have less righting force than the designed lead.
It might be possible to fill the length of the keel with a less dense material by extending the ballast material for the entire length of the keel (which would produce a less lively, somewhat slower boat). It is also possible to build a bigger, more voluminous keel to achieve the same weight with less dense ballast material, but this increases draft and wetted surface.
Or you could follow the plan and use lead.
JohnT
Sent: Saturday, October 07, 2006 11:11 PM
Subject: [bolger] Re: It doesn't matter whether you use 300 lb. of lead or 300 lbs of feathers
Like I said, if the center of gravity stays the same, it doesn't
matter what material you use for the ballast. You are assuming the
> Yes it does matter what you use for keel weight!
> Lead is 707 lbs per cu.ft.
> Steel is 489 lbs percu.ft.
> cast iron is 442 lbs per cu.ft.
> I don't have a listing for feathers in my book but it
> would all deppend on how much it weighted per cu.ft.
> but I would guess it would be lighter then seawater at
> 64 lbs per cu.ft. So feathers would not be a good use
> for ballest if it was was placed underwater.
> If you want the most bang per cu.ft. you have gold at
> 1206 lbs per cu.ft.
> Tungsten at 1204 lbs per cu.ft.
> And the very best would be Platinum at 1339 lbs per
> cu.ft.
> Waight inside a hull is one thing but when it's in
> direct contact with water as in a keel (swing keel,
> bulb keel, fin keel or even a straight keel) it all
> comes down to how much waight you put in a given space
> (as in lbs per cu.ft) over the amount of water you are
> displaceing for that same number of cu.ft. Then the
> other thing is the lever arm it has over the Cob of
> the hull. The two work together to right to boat.
> I know Phil Bolger can explane the whole thing better
> then I can.
> Krissie
> > 300 lbs of
> > same place, you
> > keel also acts as
> Do You Yahoo!?
Checked by AVG Free Edition.
Version: 7.1.407 / Virus Database: 268.13.0/465 - Release Date: 10/6/2006
For ballast down below the waterline, it very much matters,
especially if we are talking about keels. 300 pounds of feathers
would be a huge draggy keel while a 300 lb lead keel can be small
and streamlined. There would be no way to keep both the same center
of gravity and the same underwater profile if you go from lead to
feathers. The same of course applies no matter what you change the
lead for. Denser materials will allow a smaller keel, less dense a
larger keel.
if you are talking payload, it makes no difference, but when talking
about deep ballast to provide additional stiffness, density makes a
huge difference.
Paul H
> > 1206 lbs per cu.ft.
> > cu.ft.
> > then I can.
> > Krissie
> > > 300 lbs of
> > > same place, you
> > > keel also acts as
> > Do You Yahoo!?
> 1206 lbs per cu.ft.
> cu.ft.
> then I can.
> Krissie
> > 300 lbs of
> > same place, you
> > keel also acts as
> Do You Yahoo!?
I found this useful. It is a great weights calculator. Just use
rectangle as the shape.
http://www.matweb.com/tools/weight-calculator.asp
<http://www.matweb.com/tools/weight-calculator.asp>
Mike
P.S Off topic Wanted Rowboat, Queensland AU
http://groups.yahoo.com/group/Bolger4Sale/message/445
<http://groups.yahoo.com/group/Bolger4Sale/message/445>
I think that pouring a lead 'fin' keel like Bolger designed would be
easier than building the curved formwork and pouring a concrete keel.
(By far!)
I poured my own lead keel, it was easy. I used a left over steel
paint bucket, set on bricks. BBQ coals for the fire, and an electric
leaf blower to 'hot it up'. I moved the molten lead from the bucket
to the form (pour it flat on it's side) using a home made ladle (a
can, nailed to a stick). Total time, including head scratching, about
6 hours.
It is hot, so wear gloves, and boots, and keep the kids away.
1206 lbs per cu.ft.
cu.ft.
then I can.
Krissie
> 300 lbs of
> same place, you
> keel also acts as
Do You Yahoo!?
http://mail.yahoo.com
A good idea. There are some steel fabricators that have computer controlled cutters that could cut out the exact shape needed, given an accurate layout. Such thigs are done often for highway overpasses, as well as ships.
You might consider extending the bottom edge forward and aft, to make up for the lower weight of steel as compared to lead. It would allow you to ground on anything with impunity. I used to sail on an Alden yawl with a cast iron ballast keel that bounced unscratched off Maine rocks that might have done serious damage to a fiberglass or wood keel.
You might also consider getting the steel hot dip galvanized, if there is a company in your area that can handle it.
Allan
in the hills
---- Kristine Bennett <femmpaws@...> wrote:
> There may be a better way yet. Use steel plate, 1" is
> 40.8 lbs per sq.ft. 1 1/4" is 51 lbs per sq.ft. 1 1/2"
> is 61.2 lbs per sq.ft and 2" is 81.6 lbs per sq.ft.
> And the nice thing most steel warehouses will cut the
> plate to your drawings
> Krissie
> > the keel from the
> > with.
> Do You Yahoo!?
I'm currently building Bolger's Old Shoe. I have elected to have
the professionals do my lead. Had to make a wood plug, as the
foundry will do a sand casting. 200lbs of lead ballast will
probably cost around $400. Just my way of doing it.
Fairwinds and smooth seas,
Dennis
Bellngham, Wa.
-- Inbolger@yahoogroups.com, "marcoviniciomasoni"
> no revolving pipe
> no faucet
nozzle for join.
is enough.
> From :bolger@yahoogroups.com
> Cc :
around
no revolving pipe
no faucet
Cc :
--- Inbolger@yahoogroups.com, "Jon & Wanda(Tink)" <windyjon@...>
boats
depth
leverage
> Jon
> > water.
> > CoB.
> > Krissie
> > > the keel from the
> > > with.
> > Do You Yahoo!?
lighter by the amount of water it displaces that is what makes boats
float. So what is commen is to keep the shape but give it more depth
ie leverage so the same weight has the same efect with the leverage
Jon
> water.
> CoB.
> Krissie
> > the keel from the
> > with.
> Do You Yahoo!?
Krissie
> the keel from the
> with.
Do You Yahoo!?
water.
CoB.
Krissie
> the keel from the
> with.
Do You Yahoo!?
Maybe I will try a camp stove rather than the turkey cooker. The
electric hotplate is what I used for bullet making so I tried it
first with poor results.
If all goes well, I will be pouring the bilge board ballast in the
next week.
Paul H
--- In bolger@yahoogroups.com, "Gene T." <goldranger02-boats@...>
> Paul,
> I found that a simple Coleman propane camp stove melted the lead
in a galvanized bucket just fine. Did 100 pounds of wheel weights
and lead shot with less than 1 16 oz tank. I did the 100 lbs twice
for a Single Handed Schooner. The first one bulged on me and there
was no way to shave it down to shape. Melting the 100 lb block with
propane torches was a real chore, dirpping it into the buckets....
The second form was better plywood with reinforcements added...
> Sincerely,
> Gene T.
> From: Paul <p_hardy@...>
> Sent: Friday, October 6, 2006 9:24:03 PM
> A few pounds melts easily but large amounts get
progressively
> harder. For the Super Brick I was melting weights to make the the
> ballast for the rudder. Small pots - 8 pounds or so each - took a
> long time with a hot plate. For the larger weight on the bilge
> board I am looking for a high powered propane burner, I am
thinking
> about a unit designed for turkey frying.
> And pure lead is very hard to machine well. It is very soft and
> tends to deform rather than cut or shape. I know antimony was
often
> added to the casting blocks I used years ago for making bullets.
> Its supposed to make the lead harder which should help machining
> greatly.
> Paul H
> --- In bolger@yahoogroups. com, Mark Albanese <marka@> wrote:
> > The difference in weight will make a difference in the power to
> carry
> > sail. Check this, but I think lead weighs about 5 times more
than
> > concrete.
> > Often, people find that, well prepared, lead is not so horrible
> to
> > do. My own little experiments with a few pounds went pretty
well.
> > It's amazing how easily it melts.
> > They say a little antimony helps later with machining it.
> > If you wanted to skip the keel entirely and if it they'd work
for
> > your cruising ground, either the recently mentioned Cynrthia J
or
> Jim
> > M's Musicbox2 would be similar, straight sided alternatives.
> > http://groups. yahoo.com/ group/bolger/ files/CynthiaJ/
> > http://www.duckwork sbbs.com/ plans/jim/ musicbox2/ index.htm
> > Mark
from
> the
Messing
> around
> > > Bolger rules!!!
> flogging
> > > dead horses
> Fred'
> > > posts
> away
> > > - Unsubscribe: bolger-unsubscribe@ yahoogroups. com
> > > - Open discussion: bolger_coffee_ lounge-subscribe
@yahoogroups. com
> > > Yahoo! Groups Links
serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;
> #ygrp-vitnav{
> padding-top:10px;
> font-size:77%;
> margin:0;
> #ygrp-vitnav a{
> padding:0 1px;
> #ygrp-actbar{
> clear:both;
> margin:25px 0;
> white-space:nowrap;
> color:#666;
> text-align:right;
> #ygrp-actbar .left{
> float:left;
> white-space:nowrap;
> #ygrp-grft{
> font-size:77%;
> padding:15px 0;
> #ygrp-ft{
> font-size:77%;
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-vital{
> margin-bottom:20px;
> #ygrp-vital #vithd{
> font-size:77%;
> font-weight:bold;
> color:#333;
> #ygrp-vital ul{
> padding:0;
> margin:2px 0;
> #ygrp-vital ul li{
> clear:both;
> font-weight:bold;
> color:#ff7900;
> float:right;
> width:2em;
> text-align:right;
> padding-right:.5em;
> font-weight:bold;
> #ygrp-vital a {
> #ygrp-sponsor #hd{
> color:#999;
> font-size:77%;
> #ygrp-sponsor #ov{
> padding:6px 13px;
> margin-bottom:20px;
> padding:0 0 0 8px;
> margin:0;
> padding:6px 0;
> font-size:77%;
> font-size:130%;
> #ygrp-sponsor #nc {
> margin-bottom:20px;
> padding:0 8px;
> #ygrp-sponsor .ad{
> padding:8px 0;
> font-family:Arial;
> font-weight:bold;
> color:#628c2a;
> font-size:100%;
> line-height:122%;
> margin:0;
> o {font-size:0;}
> .MsoNormal {
> margin:0 0 0 0;
> #ygrp-text tt{
> font-size:120%;
> .replbq {margin:4;}
Paul,
I found that a simple Coleman propane camp stove melted the lead in a galvanized bucket just fine. Did 100 pounds of wheel weights and lead shot with less than 1 16 oz tank. I did the 100 lbs twice for a Single Handed Schooner. The first one bulged on me and there was no way to shave it down to shape. Melting the 100 lb block with propane torches was a real chore, dirpping it into the buckets.... The second form was better plywood with reinforcements added...
Gene T.
A few pounds melts easily but large amounts get progressively
board I am looking for a high powered propane burner, I am thinking
tends to deform rather than cut or shape. I know antimony was often
greatly.
Paul H
carry
> sail. Check this, but I think lead weighs about 5 times more than
> concrete.
> do. My own little experiments with a few pounds went pretty well.
> If you wanted to skip the keel entirely and if it they'd work for
> your cruising ground, either the recently mentioned Cynrthia J or
Jim
> Mark
around
flogging
> > dead horses
Fred'
> > posts
away
> > - Open discussion: bolger_coffee_ lounge-subscribe @yahoogroups. com
> > Yahoo! Groups Links
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;
#ygrp-tpmsgs{
font-family:Arial;
clear:both;
#ygrp-vitnav{
padding-top:10px;
font-size:77%;
margin:0;
#ygrp-vitnav a{
padding:0 1px;
#ygrp-actbar{
clear:both;
margin:25px 0;
white-space:nowrap;
color:#666;
text-align:right;
#ygrp-actbar .left{
float:left;
white-space:nowrap;
#ygrp-grft{
font-size:77%;
padding:15px 0;
#ygrp-ft{
font-size:77%;
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-vital{
margin-bottom:20px;
#ygrp-vital #vithd{
font-size:77%;
font-weight:bold;
color:#333;
#ygrp-vital ul{
padding:0;
margin:2px 0;
#ygrp-vital ul li{
clear:both;
font-weight:bold;
color:#ff7900;
float:right;
width:2em;
text-align:right;
padding-right:.5em;
font-weight:bold;
#ygrp-vital a {
#ygrp-sponsor #hd{
color:#999;
font-size:77%;
#ygrp-sponsor #ov{
padding:6px 13px;
margin-bottom:20px;
padding:0 0 0 8px;
margin:0;
padding:6px 0;
font-size:77%;
font-size:130%;
#ygrp-sponsor #nc {
margin-bottom:20px;
padding:0 8px;
#ygrp-sponsor .ad{
padding:8px 0;
font-family:Arial;
font-weight:bold;
color:#628c2a;
font-size:100%;
line-height:122%;
margin:0;
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;
#ygrp-text tt{
font-size:120%;
.replbq {margin:4;}
greatly.
Paul H
carry
> concrete.
Jim
>http://groups.yahoo.com/group/bolger/files/CynthiaJ/
>http://www.duckworksbbs.com/plans/jim/musicbox2/index.htm
> Mark
around
flogging
> > dead horses
Fred'
> > posts
away
> > Yahoo! Groups Links
One of the boats I am working on is a Sam Devlin Winter Wren and it
gives two keel options - cast lead or lead weights set in cement. I
plan to use the latter with wheel weights as the lead, packed into the
keel box then filled with portland cement. This does not result in the
same amount of ballast - 500 pounds vs 700 for cast lead - but some
simple adjustment in size should provide proper ballast on a micro
Paul H.
around
The difference in weight will make a difference in the power to carry
concrete.
Often, people find that, well prepared, lead is not so horrible to
your cruising ground, either the recently mentioned Cynrthia J or Jim
> dead horses
> posts
Hi there. I don't know about concrete but I have heard of a few people using lead shot encased in epoxy. This eliminates melting of the lead...but you have to make the keel a little longer or thicker to account for the decrease in density of the epoxy. Robb
Sent: Friday, October 06, 2006 6:31 PM
Subject: [bolger] Keel on the Micro
