Re: [bolger] Ready to start a Micro
>No posts that contemplate greater than quarter inch
>construction seem worried about the trailoring, I've noticed.
>Instead of 875#, 3/8ths uppers w/ a 1/2" bottom comes out
>at about 1250#, I think.
I don't think it will be that bad.http://www.edensaw.com/f_marine.htmlists
Occume 3/8"s at 30lbs/sheet and 1/4" marine fir at 26lbs, so for 12 sheets, the
additional weight only adds up to 48 pounds, and because I won't have to add any
additional bracing for cabin tops, etc, it might actually be less then that. I
can live with an additional 50 pounds or so and feel happier that my boat is
stronger and safer...
Glen
Mark Albanese <marka@...> on 06/12/2000 06:49:28 PM
Please respond tobolger@egroups.com
Sent by: Mark Albanese <marka@...>
To:bolger@egroups.com
cc: (Glen Gibson/HQ/3Com)
Subject: Re: [bolger] Ready to start a Micro
glen_gibson@...wrote:
> ***** I'm going with BS1088 marine Occume plywood in 3/8" everywhere, with
> either
> a 3/4" (double 3/8") or 5/8" (3/8" + 1/4") for the bottom. The imported
> plywood is lighter than douglas fir, so the weight won't be much more...
You were probably smart to pass up that deal on Finnish
Birch, Glenn.
Though a heavy boat for its waterline length, the Micro
still has tremendous weight carrying capacity. If you add
thickness to the outside rather than the inside of the
designed lines, the extra displacement floats you about the same.
I notice Jim Michalak points out that the manufacturers
don't much care how long your car lasts when they make the
towing recommendations. He says figure 1/2 what they say is best.
Les Lampman wrote:
>This boat will sit at our county dock amongst the
commercial boats.
This surprises me. I can't think of anything worse for any
thickness plywood construction then constant banging around
at the mercy of an endless line of heedless fisherman in a
hurry. I'd worry every night about having to hire a diver
tomorrow in order to resurrect the boat. Hurray for mooring
whips and fenders, but doesn't your county dock have a time
limit?
BTW for the NW grayshine weather, I rather like the Micro
Navigator version at
http://members.xoom.com/_XMCM/merrellc1/Files/navigator1.pdf
Is that what is meant by the, "Enclosed cockpit" version?
Get a FREE "YourName.Com" Web Address,
E-Mail, and Home Page...TODAY! CLICK HERE!
http://click.egroups.com/1/5460/10/_/3457/_/960860724/
Posting rules:
- please stay on topic
- add your comments at the top and sign your name
- check for "content" before sending: please take "thanks" and "me too!" posts
off-list.
Hi Mark,
Thanks for the reply.
I don't plan to trailer the Micro much. A quarter mile to the launch ramp
and back when she needs to go in or out. And I'm set up to tow about 6,000
pounds so even at 1500 pounds or more including the trailer Micro won't
present much problem.
>>commercial boats.
>limit?
Our county dock is not very active anymore with commercial boats, they
mostly sit derelict alongside. The boats I moor there fare well and I use
the big round commercial style fenders (attached to the dock so they don't
go with me into posher settings). There is no time limit, I pay $200 a year
for moorage. No power or water and no security (although I'm across the
street and can see the dock from my front window) which is why I don't want
a real "yachty" looking boat.
Well, I agree but my wife doesn't. She wants the open cockpit to lounge in
when we're sailing in nice weather. I'm contemplating something in between
if I can make it work. Maybe the Navigator with a folding top (I do custom
canvas work at the shop). Still working on it.
No, what I meant is not utilizing the footwell hatch but instead building a
rather traditional seat & footwell arrangement where there are sides to the
footwell and everything is sealed against water entering the interior of the
boat. The footwell is drained overboard by extending to the transom
(bulkhead "D" in the Micro), basically making it into a cockpit, where the
open end freely drains or by putting in cockpit drains if it is kept at
original size and location.
Best regards,
Les
Posting rules:
posts off-list.
Vance,
My Micro "Firefly" is well under way, and I have officially
reached the no turning back stage. I am going to use a double bottom
total 1/2" as I have found this sufficient in Diablo, and Pointy
skiff.
My Diablo has 1/4" sides that have been sheathed in glass set in WEST
resin. It is quite stiff. The decks will be 3/8th to save on having
to install extra framing. I am sure that the 1/4" would be ok, but I
know that my kids will be crawling all over it and therefore want a
little extra security and a little less work in this area.
So far, I have:
built the sides - clench nails from Strawberry Banke in Portsmouth NH
built the frames - be careful doing the bow transom bevel, visualize
first. cut later
built the spars - What? There is a spar building manual now? I have
older plans. (bought 11 years ago, and they sat in a drawer until
now!)
have all rigging and sails - thanks Stan!
have a borrowed foundry and 1/2 the lead on hand, - Carl, I promise I
will return it soon!
Hoping to go 3 D this weekend! weather permitting.
You can follow my progress athttp://www.ultranet.com/~djost/
Micro.htm. Pictures should be up by this evening.
> either
Birch, Glenn.
commercial boats.
limit?
--- Inbolger@egroups.com, glen_gibson@3... wrote:
> I haven't started on the hull yet ...
And neither have I. Long ago I bought my plans through Elrow
LaRowe's advertisement in Woodenboat,and received them
from Bernie Wolford, so it was just as the CSD change took
place. I got the basic set of plans, no "spar making pamphlet",
etc., and have seen no upgrades.
I learned about Bolger's new ply thickness recommendations
from this group and other sources, but I am still unclear about
how these should be applied.
The lines are drawn to the outside of planking. Conventional
practice when adding thickness is to reduce the size of the
molds (in this case the bulkheads/frames) thus keeping volume
the same. Is this necessary with Micro?
I may never build the boat, but I am curious about this and
suppose that others are too.
Vance,
Kiln drying in Tucson
Thanks Glen, Good info and it's much appreciated.
Les
Sent: Monday, June 12, 2000 3:04 PM
I haven't started on the hull yet (within a couple of weeks) but below are
my
plans.
Good luck!
Glen Gibson
1) Is the 1/4" construction really enough? Or should I go to 3/8"?
Should the bottom be heavier still? What about the sides? I want to
strike a balance between two building extremes (as I see it, cheap
and maybe flimsy or tank and expensive). This boat will sit at our
county dock amongst the commercial boats. I'm not after a 'yacht'
but I do want a safe and nice looking boat.
either
Pertaining to the layout:
1) I am undecided about closing in the bow for more inside storage or
leaving it open (free flooding) for anchor, rode, lines, fenders,
etc. Any thoughts on this?
***** I'm going with the bow as it, don't really need any more room
2) Quite a few of you seem to prefer a more traditional closed
cockpit and I'm leaning this direction as well. Any big negatives?
***** I've heard great things about the cockpit as designed, so I'm sticking
with it. Remember, if the weather get's rough, just close up the
footwell, and the cockpit IS self draining...
I've gained much from the list already and want to thank you all for
taking the time to post and share your ideas and thoughts.
Any chance that someone on the list has a Micro within a reasonable
distance of me (maybe 100 to 150 miles) that I could see in person.
I've only seen the boat in pictures and plans and at this point
contruction is a leap of faith; one I'll take BTW :-)
Best to all and thanks,
Les Lampman
Porsche Boxter. You and a friend. Nine dream days from
Napa Valley to Beverly Hills. Provided by CarsDirect.com.
Click to enter.
http://click.egroups.com/1/4882/10/_/3457/_/960747922/
Accurate impartial advice on everything from laptops to table saws.
http://click.egroups.com/1/4634/10/_/3457/_/960840296/
Posting rules:
posts off-list.
I haven't started on the hull yet (within a couple of weeks) but below are my
plans.
Good luck!
Glen Gibson
either
Les Lampman
Click to enter.
Les:
Glad you enjoyed the articles. The Tennessee is a great boat, and at 29'
has the ability to stretch across the tops of the wavetops in a short chop.
I have had her out in 4 ft. waves with not much trouble. Downwind she is a
little squirrelly, and upwind a little wet, but pretty smooth in both cases.
The only problem is that she is lightly built, and would not want to take a
lot of pounding on her flat bottom.
> Chuck,
> Thanks! I understand "more is better" and we have lots of debris floating
> around out here.
> BTW, I read your article about building Tennessee and your wife's "Help I
> Married a Boatbuilder" and spring break articles. Also one by a friend of
> Bonham's I believe. She's a really neat boat. In fact, Tennessee was
(and
> is) high on my list of wanna do projects. I am a little concerned about
her
> ability to handle out water conditions here. Steep waves with short
> intervals coupled with mean tide rips. Sorta ugly sometimes.
> Regards,
> Les
Les:
I guess What I mean is the more the better. I have built two boats larger
that Micro that had 1/4 inch sides, and I did not feel that was too little.
I do, however feel that a 3/4 " bottom is only adequate. At least that was
my experience on the Tennessee that I built. Micro has more rocker, and is
supposed to sail on her chine, so perhaps a 1/2" bottom (two layers or 1/4"
each) would be OK. In any case, I feel the designed 1/4" bottom is too
light.
> Did you mean 3/8" for the complete hull or just the bottom. And if the
> bottom, when you suggested doubling it did you mean double only if using
> 1/4" or double with 3/8" (if I can afford it)?
> Thanks,
> Les
Chuck,
around out here.
Bonham's I believe. She's a really neat boat. In fact, Tennessee was (and
is) high on my list of wanna do projects. I am a little concerned about her
Les
Sent: Sunday, June 11, 2000 5:37 PM
Les:
light.
> Thanks,
> Les
Take 20 friends to Vegas on New Year's courtesy of Expedia.com.
Win the airfare, a suite at Bellagio and $15,000. Or win 2 roundtrip
tickets anywhere in the U.S. given away daily. Click for a chance to win.
http://click.egroups.com/1/5294/10/_/3457/_/960763101/
Hi Les,
In answer to your questions, I went with 1/4 inch sides and 1/2 inch
bottom, Two layers of 1/4 inch epoxied together. All of the exterior of
the hull is covered with two layers of 4 oz fiberglass, and cabin top
etc. is one layer. If you check my web site, you will see the interior
layout where such things as the counter top etc. stiffen the sides, and
the ribs I used on the cabin top did the same for it. Even though My
Micro is no longer a sail boat, (long story) the cabin layout and
general construction is still applicable to any Micro. See;
http://www.iland.net/~pmuller/
Below are other Micro sites that have been an inspiration to me, and
you can glean many good ideas from them.
http://www.jersey.net/~tetherin/micro.htm
http://space.tin.it/io/jfwbi/micro.html
http://www.boatdesign.com/micro/
http://www.carlsondesign.com/projects.html#Micro
http://web.wt.net/~tbertw/micro.htm
http://web.wt.net/~tbertw/micro2.htm
http://www.realtime.net/~ourhouse/
Good luck, and enjoy the building, Stan, Micro Tugger, Snow Goose.
Les:
I haven't built a Micro, but I have sailed in one, and I have built several
other boats - any way here is my two cents worth:
If nothing else, double the bottom. If you can afford it, use 3/8ths.
IMHO, the open well forward is very handy. If you need more space, consider
the Long Micro. It will be a little faster too.
Hi Chuck,
Thanks for your reply. I do have a question or two ...
My apologies for the confusion.
And for the group in general, what about the Long Micro? I don't see much
about it other than the one excellent site I visited. Might it be a better
choice for the open sound here? Comments most welcome.
Les
Sent: Sunday, June 11, 2000 2:02 PM
Les:
Click to enter.
http://click.egroups.com/1/4882/10/_/3457/_/960750200/
