Re: latex paint question
What kind of polyester did you use? Some kinds have wax in them
which comes to the surface to keep air out so they cure all the way
the outside. If yours felt completely cured (not sticky) on the
outside before painting, I bet it was that type. Needs to have this
wax scrubbed off for good paint adhesion, I think. But someone else
with more experience may have a better idea, and I don't know
anything
about Zinzer.
P.S. You can get polyester resin without this wax, but I don't recall
what it's called. Makes it much easier if you want to put on another
layer later.
anything
about Zinzer.
layer later.
--- Inbolger@egroups.com, "Brad Boerger" <bradboerger@h...> wrote:
> Hi,
> We just launched my son's 6 hour canoe. The paint rubs right off
on
> the taped areas- (chine seams). Its glass tape with polyester
resin,
> primed with Zinzer, water based, 1 coat, with 2 coats of exterior
> latex. The luan ply holds the paint just fine, its the taped areas
> that are the problem. It sat for a week before launching, so it
> should've had time to harden up. What do I do?
> thanks,
> Brad
Scuff up the polyester before painting.
Gregg Carlson
Gregg Carlson
>Hi,
>We just launched my son's 6 hour canoe. The paint rubs right off on
>the taped areas- (chine seams). Its glass tape with polyester resin,
>thanks,
>Brad
>Free @Backup service! Click here for your free trial of @Backup.
>@Backup is the most convenient way to securely protect and access
>your files online. Try it now and receive 300 MyPoints.
>http://click.egroups.com/1/4935/10/_/3457/_/960815346/
Hi,
thanks,
Brad
thanks,
Brad
